https://github.com/z00m128/sjasmplus...es/tag/v1.14.2
v1.14.2 changelog:
- added i8080 mode (--i8080 CLI option) (it's still Z80 Zilog syntax, just limited instruction set)
- added Sharp LR35902 mode (--lr35902 CLI option) (100% syntax compatibility with IDA, 95% bgb)
- new $$label operator to retrieve page of label
- 1.14.0 include-path bugfix reverted, the "." is again automatically added (did break projects)
- small improvements/polish/extra-info in docs, INSTALL, README, few new tests added
- cmake script fix of SYSTEM_LUA=ON option, CirrusCI configs added for macOS and FreeBSD
- few fixes of memory leaks, invalid memory access, double free/delete
Documentation http://z00m128.github.io/sjasmplus/documentation.html (or in the package/cloned source).
Should "just work".
If you have any issue with it, and the docs doesn't explain why the assembler is doing what it is doing, please report it, so I can take a look
(before I will forget how it works).
