Screens of 128K are in pages 5 and 7. If A17', A18' and A19' are not zero you cannot access these pages in upper CPU window. This means incompatibility.
:) Dima, is incorrect remark. Selection of upper adress lines is determined by the logic of the program. If the program does not use both screens, then A17'-A19' can be arbitrary. Otherwise they should be set to zero. As you can see no incompatibility there. :)
---------- Post added at 15:05 ---------- Previous post was at 14:39 ----------
Dima, before making the statement, first carefully studied the scheme for memory expansion up to 1Mb in the Pentagon-128. :) From this scheme follows that the management of Pentagon-1024SL v2.2 and Unreal implemented incorrectly. If the management is implemented correctly, the result should be as follows:
82
82
82
80
81
81
81
This bit comes from a compatibility switch-button, and I had it in my old Pentagon. Compatibility means ability of working not under some 'if' condition, but every time. I don't need your crazy paging. Deathsoft doesn't too. The same for your DOS D7 trigger. If you want it, write software for it. And get f**s if it does not work in existing hardware.
Yes, this mode A17'-A19'=0 is chosen manually.
---------- Post added at 16:11 ---------- Previous post was at 15:44 ----------
It all depends on how you write a program. Correct operation depends on this, and not from an electronic circuit :).
---------- Post added at 16:33 ---------- Previous post was at 16:11 ----------
Дима, или ты хочешь сказать, что в Pentagon-1024SL v2.2 вы с КоЕм изменили назначение и этого бита порта #EFF7? :v2_scare: ..бедный порт #EFF7.. от его исходного состояния остался неизменным только один бит :v2_devil: ..всё остальное переиначил злой AlCo на пару с КоЕм :) ..и за 5 лет даже мануала что на что заменено не оставил.. :) ..а ведь кто-то ещё ориентируется на старые доработки Пента, не ведая, что благодаря AlCo и КоЕ почти все биты порта #EFF7 уже имеют совсем иное назначение.. при том многократно иное :v2_devil:
Дима, ты хоть в вашей вики опиши всю историю изменений, а то даже в Unreal не всё что вы переиначили внесено.. :) . И ты после этого ещё катишь бочку на D7 #EFF7 :v2_devil: ..ужос..
---------- Post added at 17:10 ---------- Previous post was at 16:33 ----------
Summary for VELESOFT: 5 years ago AlCo & KoE changed the designation of bits port #EFF7, but forgot to make an announcement about it :). Therefore Unreal does not work correctly. Results DDp are correct.
TEST FOR REAL PENTAGON 1024SL 2.2
LET P1=32765:LET P2=61431
OUT P2,0 ;enable 1MB
OUT P1,16:POKE 49152,16 ;signed page 16
OUT P1,17:POKE 49152,17 ;signed page 17
OUT P1,32+16:POKE 49152,32+16 ;extra memory page
OUT P2,4 ;switch to 128 mode
OUT P1,17:PRINT PEEK 49152 ;show active page
If I set D5 in 1MB mode, will after switch to 128kB mode disabled port 7FFD ? My program return value 16 if will disabled port 7FFD, or 17 if will enabled. :v2_conf2:
OUT P1,32+16:POKE 49152,32+16 ;extra memory page (D5=1 !!!)
OUT P2,4 ;switch to 128kB mode (but D5 on 128 mode is used for block 7FFD)
I am in Pentagon 1024SL 2.2 in 128mode and set OUT 32765,48 then will set page ram 0 and disable port 7FFD. After switch to 1MB mode will active page ram 8. Anf after switch back to 128mode via OUT 61431,4 is also port disabled ?
Yes.
Oh, my God! 16!!!
OUT P2,4 ;disable memory above 128K
But, 5 bit in 7FFD-port is ON. --> Now, it are disable write to 7FFD-port (lock48K).
"17" has not written to port. Previous value - "16".
