Yes I know that NemoIDE works with "Byte" (this Prusak site).
To BYTEMAN: I test DivIDE roms (Fatware012) with your "Byte" ROMS in emulator EightyOne and working OK but only with BYTE2-ZX.ROM (switched ON СОВМЕСТ).
Ok, this means, that if you connect DivIDE to real Byte, you'll need to switch it to "СОВМЕСТ" compatibility mode, and it will work fine :) All signals of Z80 bus are present on system port connector СИСТ. Pinouts could be found here: http://zxbyte.ru/doc/byte_instr.zip. Refer to last pages of this manual.
I think so too :-). This is video with working ROM "Byte" in EightyOne and my pinout ZX Spectrum<>Byte :-)
