You need to connect wires
Tidied up on perfboard ... PCBs would look very similar (unused perfboard is for a future modification):
https://i.imgur.com/22bCo3W.jpg
Revisting the ROM topic.
https://cloud.mail.ru/public/2kgx/XbvZ2txr9 (ShadowMon 2.7c, TRDOS 5.03) seems to have broken Magic Button routines?
https://speccy4ever.speccy.org/rom/Com-glk.rom (GLUK 6.63, TRDOS 5.04T) writes valid snapshots but crashes when trying to return to the program.
Reorganizing a Scorpion ROM with ShadowMon 2.95 results in the same behaviour as the first - except that starting TRDOS 128 doesn't work.
Edit: Further issues. Selecting TRDOS from GLUK (6.61 is recommended, 6.63 crashes on the "I know everything"-Message) results in "out of memory" when using TRDOS 5.03/5.04 (it's known behaviour) - this can be fixed by using TRDOS 5.12F or 6.11E, sadly those versions hang instantly when pressing the magic button when a program is running.
Edit2: Returning to TRDOS from Test 4.3 also doesn't seem to work and the fault remains even reset persistent. I'll check into Gate 68.2 and related signals whether that behaviour can be fixed.
I've implemented the second solution shown here: http://sblive.narod.ru/ZX-Spectrum/P...eudoTR-DOS.htm
This fixes TRDOS 6.11E (albeit with no RAMdisk, I guess 5.13F might be a better choice - programs no longer crash after creating a snapshot and snapshots are functional) and resets to GLUK Reset Service.
If you disconnect D68-9 from the board, it can be done as a plug in card for the expansion bus that feeds it back ... it's a bit messy in the current state, but trust me, it works https://i.imgur.com/DSfdGrh.jpg
I guess this is also one of the first Compact 256 specific expansion cards? :D
EDIT: This modification "breaks" the Infarct Megademo ... the computer gets detected as a Pentagon - this can be overwritten by holding <S> when booting the demo.
Possible fix for Shadow Monitor / Magic Button when using Scorpion ROM.
This basically adds back the !DOS and !NMI generation as done on yellow Scorpion boards.
UNTESTED!
https://i.imgur.com/iWj3AeT.png
Does not work and abandoning to get Scorpion ROMs fully working again.
I've managed to get to a state where returning from the NMI Menu is possible, "something" gets written when selecting Magic Button and occasionally the computer doesn't crash. Snapshots don't work tho. Slight improvement, but not by too much.
2.92 or later still can't boot from TRDOS 128 (I guess due to attempting to switch to turbo mode via a port) going via BASIC 128 -> USR0 -> Randomize USR 15616 still works.
Turns out Snapshots and leaving ShadowMonitor works fine when in 48K mode?! Oh well.
https://i.imgur.com/JKBR4gZ.png
Another small modification that can be done as an expansion card (but still needs 2 additional wires). This adds back a Scorpion style button for switching the CPU speed and allows the Turbo to be enabled/disabled in ShadowMonitor/Software.
Sadly doesn't fix the TRDOS128 option with the 2.95 RAM, that still crashes after enabling turbo.
https://pic.maxiol.com/?v=1675402091...21840.jpg&dp=2 х4 Bios переключается переключателями, ноги поменять местами 30 и 32.
Доброго времени суток! Собрал Compact 256 Turbo на плате с черной маской, в принципе почти все сразу заработало за исключением одной из ИЕ19 о чем тут уже писали и схемы контроллера дисковода. С контроллером засада, при обращении к диску из TR-DOS выдает ошибку r tape loading error 0 1 а при попытке тестового чтения из теневого монитора ошибок нет тест проходит. Осликом проследил сигнал RDATA c флопика он в режиме TR-DOS доходит до триггера D61.1 но ввиду того что сигнал -WD-DE имеет высокий уровень на выходе триггера уже ни чего нет, в то же время в режиме тестовой утилиты теневого монитора сигнал -WD-DE имеет низкий уровень соответственно сигнал чтения с вывода 5 D61.1 приходит на схему ФАПЧ обрабатываеться ей и в виде сигнала -RAWR идет на вг93 НО! при этом на 15 ноге 155ИМ3 (выход S4 сумматора) присутствует постоянно лог.1 соответственно на выводе 15 триггера D55 не образуеться сигнал синхронизации и VG-SYN отсутствует. Есть подозрение что не работает 4 сумматор 155им3 но смущает тот факт что микросхема совершенно новая, заказывал в чипдипе а они вроде брак не рассылают. В схемотехнике данного пк не силен, может местные гуру смогут подсказать где и что проверить что бы данный глюк устранить? За ранее благодарен откликнувшимся!
Здравствуйте!В одной из версий (d56 к155им3 12 нога с 13 нужно соединить}, может попалась эта версия?
