v1.11.0 change, the docs claimed the apostrophe strings are not parsed for escape chars, so I fixed the assembler.. and added the double apostrophe as extra escape sequence: http://z00m128.github.io/sjasmplus/d...html#s_numeric (a bit down, Example 4.1)
Sorry for the inconvenience. (in the distant future, in v2.x version - if it ever happens - I plan to align the assembler even more with C++, bringing back the backslash escaping of single apostrophe, but I'm not planning to modify this further for v1.x versions)
But in this case you can just use double quotes (this should be compatible with all different variants of sjasmplus):
Код:cad82 defb "Input machine's name", 0
