Parameters for your wireless networks are specified in the file
'ENVARC:Sys/Wireless.prefs'. You can choose to have this file created
automatically while running the 'Install' script. The installer lets you
create a configuration for a single WPA/WPA2-encrypted network. If you need
other options, or want to configure more than one network, you will need to
edit 'ENVARC:Sys/Wireless.prefs' in a text editor. Below are some examples
of network configurations that can be used.
# A WPA/WPA2-encrypted network with a textual passphrase
# (using a textual WPA/WPA2 passphrase will cause a start-up delay of up to
# several minutes on a slow CPU)
network={
ssid="mynet1"
key_mgmt=WPA-PSK
psk="yOuRsEcRetwpAKeY"
# A WEP-encrypted network with a hexadecimal password
network={
ssid="mynet2"
key_mgmt=NONE
wep_key0=123456789abcdef123456789ab
wep_tx_keyidx=0
# A WEP-encrypted network with a textual password
network={
ssid="mynet3"
key_mgmt=NONE
wep_key0="yourpassword1"
wep_tx_keyidx=0
# Match any unencrypted network
network={
key_mgmt=NONE
