Разговор о современниках. Фирменные игры отдельная тема.
---------- Post added at 04:08 ---------- Previous post was at 03:57 ----------
В музыкально плане может быть. Технически это спектрум 95-96 года.
http://dl.dropbox.com/u/33485444/YM2Tap.zip
This thread fascinates me!!!… Thank you to all who have contributed to it… I have been curious for a while about trying to convert .YM files into something that can be run on a ZX machine, and now, thanks to you guys, I have tools for the job…
For those who don’t know what Im talking about, you can download the tools talked about here, arranged with a simple Windows DOS bat file. Drag the .YM file on to the .BAT file called STANDARD.bat, and the tools will output a .MYM file with a .TAP file. When you run the .TAP file, you can press ENTER, to load the converted song, to hear it play… More details are in the enclosed zip folder… I have done little other than arrange the tools, and compile the C souce code referenced in this thread.. Iv made a minor alteration to one of the C source files to trick the YM2MYM tool into treating YM6 format just like YM5… It shouldn’t work, but it does… Which is just as well, since both Ay_Emul & ArkosTracker both only output this format (pity they can’t add the option to output YM2-YM5 after item adjusting)… I guess many tools outputting YM6 aren’t necessarily using that format to its full capacity, hence treating it as YM5 seems to work for most pieces Im converting…
Incidentally, if anyone feels inclined to convert the music player itself (mymplay.asm) into something that can be compiled by Pasmo, Id appreciate that!!!…
Now.. Does anyone know of any other useful tools that can convert between formats to give us more YM files to play with?… (are there any XM2YM tools, or MIDI2YM tools out there?)…
Этот поток увлекает меня! ... Спасибо всем, кто внес вклад в это ... Я был любопытным на некоторое время о попытке преобразовать. Ю.М. файлы в то, что можно работать на ZX машины, и теперь, благодаря вам, ребята , у меня есть инструменты для работы ...
Для тех, кто не знает, что им говорили, вы можете загрузить инструментов говорили здесь, договорился с простой файл Windows, DOS, летучая мышь. Перетащите. Ю.М. файла на. BAT файл STANDARD.bat и инструменты выведет. MYM файл с расширением. TAP файлов. При запуске. TAP файл, вы можете нажать кнопку ENTER, чтобы загрузить преобразованные песни, чтобы послушать его играть ... подробнее находятся в закрытом папку почтовый ... Я сделал немного другим, чем организовать инструменты и компиляции кода C соусом ссылки в этой теме .. IV сделал незначительные изменения в один из файлов с исходным текстом, чтобы обмануть YM2MYM инструмент в лечении YM6 формат как YM5 ... Она не должна работать, но это ... Что так же хорошо, так как Ay_Emul и ArkosTracker как только этот выход Формат (жаль, что они не могут добавить опцию для вывода YM2-YM5 после пункта настройки) ... Я думаю, многие инструменты вывода YM6 не обязательно в этом формате на полную мощность, поэтому рассматривать ее как YM5, кажется, работает в большинстве частей Im, преобразование ...
Кстати, если кто-то чувствует склонны конвертировать музыку сам проигрыватель (mymplay.asm) в то, что может быть составлен по PASMO, Id понимаем, что! ...
Теперь .. Кто-нибудь знает о любых других полезных инструментов, который может конвертировать между форматами, чтобы дать нам больше Ю.М. файлы играть? ... (Есть ли XM2YM инструментов или MIDI2YM инструментов там?) ...
В настоящее время плеер для этой музыки дорабатывается -оптимизируется. Кто может помочь с отборными мелодиями для первой дискеты, милости просим в личку с треками.
Всего на диск влезет 2544 сектора, не считая секторов 100 для плеера, который уже пишется. Графика отрисована и даже уже кое что работает.
Мы должны не упустить ни одного хорошего трека. Сколько потребуется, столько образов сделаем.
---------- Post added at 14:23 ---------- Previous post was at 14:13 ----------
Ужасно неудобный плеер. На дворе 22 век! Этот плеер напоминает затонувшию конкордию!!!
Будем свой делать, с плейлистом и дизайном, эквалайзерами. писать имена музонов и выбирать их из каталога диска - это утопия.
Играет то играет. Но перелистывание мелодий не должно прерывать проигрывание.
Листание это листание. А проигрывание должно запускаться по Enter.
---------- Post added at 11:58 ---------- Previous post was at 11:32 ----------
Куда исчезает бегущая строка после начала проигрывания?
Итак, тибоха полностью завершил проект АТАРИ ПЛЕЕРА!!!
Получилось круто. Примерно 10 образов с музыкой. Есть хорошая, есть плохая, короче говоря вся. Плеер классный, на реале работает. Я сейчас слушаю на пентева и тащусь. Сразу столько много новой музыки да еще на реале.
Ждите после фестиваля ФОРЕВА.
Ссылка на мп3 мелодий с реала!!!
http://files.mail.ru/OHFI9P
http://vk.com/wall-5010876_9441
