Код:.RUN ASH1
ASH1 - v1.0
Memory Top: 116334
BUF words: 18266
CPU KHz: 5300 > 18000
CPU KHz: 18000
2: ASh #00., R0 Evt: 3 ; Run: 10581 ; Res: 10584 ; CLC: 34.0
2: ASh #01., R0 Evt: 5 ; Run: 9467 ; Res: 9472 ; CLC: 38.0
1: ASh #02., R0 Evt: 3 ; Run: 8566 ; Res: 8569 ; CLC: 42.0
1: ASh #03., R0 Evt: 2 ; Run: 7822 ; Res: 7824 ; CLC: 46.0
1: ASh #04., R0 Evt: 2 ; Run: 7196 ; Res: 7198 ; CLC: 50.0
1: ASh #05., R0 Evt: 2 ; Run: 6663 ; Res: 6665 ; CLC: 54.0
1: ASh #06., R0 Evt: 2 ; Run: 6203 ; Res: 6205 ; CLC: 58.0
1: ASh #07., R0 Evt: 1 ; Run: 5803 ; Res: 5804 ; CLC: 62.0
1: ASh #08., R0 Evt: 1 ; Run: 5451 ; Res: 5452 ; CLC: 66.0
1: ASh #09., R0 Evt: 1 ; Run: 5140 ; Res: 5141 ; CLC: 70.0
1: ASh #10., R0 Evt: 1 ; Run: 4862 ; Res: 4863 ; CLC: 74.0
1: ASh #11., R0 Evt: 0 ; Run: 4613 ; Res: 4613 ; CLC: 78.0
1: ASh #12., R0 Evt: 1 ; Run: 4388 ; Res: 4389 ; CLC: 82.0
1: ASh #13., R0 Evt: 0 ; Run: 4184 ; Res: 4184 ; CLC: 86.0
1: ASh #14., R0 Evt: 0 ; Run: 3998 ; Res: 3998 ; CLC: 90.0
1: ASh #15., R0 Evt: 0 ; Run: 3828 ; Res: 3828 ; CLC: 94.0
1: ASh #16., R0 Evt: 0 ; Run: 3672 ; Res: 3672 ; CLC: 98.0
1: ASh #17., R0 Evt: 0 ; Run: 3528 ; Res: 3528 ; CLC: 102.0
1: ASh #20., R0 Evt: 0 ; Run: 3156 ; Res: 3156 ; CLC: 114.1
1: ASh #30., R0 Evt: 0 ; Run: 2336 ; Res: 2336 ; CLC: 154.1
1: ASh #31., R0 Evt: 0 ; Run: 2277 ; Res: 2277 ; CLC: 158.1
.RUN ASH2
ASH2 - v1.0
Memory Top: 116334
BUF words: 18262
CPU KHz: 18000
2: ASh #000., R0 Evt: 4 ; Run: 10581 ; Res: 10585 ; CLC: 34.0
2: ASh #-01., R0 Evt: 5 ; Run: 9467 ; Res: 9472 ; CLC: 38.0
1: ASh #-02., R0 Evt: 3 ; Run: 8566 ; Res: 8569 ; CLC: 42.0
1: ASh #-03., R0 Evt: 1 ; Run: 7821 ; Res: 7822 ; CLC: 46.0
1: ASh #-04., R0 Evt: 2 ; Run: 7196 ; Res: 7198 ; CLC: 50.0
1: ASh #-05., R0 Evt: 2 ; Run: 6663 ; Res: 6665 ; CLC: 54.0
1: ASh #-06., R0 Evt: 1 ; Run: 6203 ; Res: 6204 ; CLC: 58.0
1: ASh #-07., R0 Evt: 1 ; Run: 5803 ; Res: 5804 ; CLC: 62.0
1: ASh #-08., R0 Evt: 1 ; Run: 5451 ; Res: 5452 ; CLC: 66.0
1: ASh #-09., R0 Evt: 1 ; Run: 5140 ; Res: 5141 ; CLC: 70.0
1: ASh #-10., R0 Evt: 0 ; Run: 4862 ; Res: 4862 ; CLC: 74.0
1: ASh #-11., R0 Evt: 0 ; Run: 4613 ; Res: 4613 ; CLC: 78.0
1: ASh #-12., R0 Evt: 0 ; Run: 4388 ; Res: 4388 ; CLC: 82.0
1: ASh #-13., R0 Evt: 1 ; Run: 4184 ; Res: 4185 ; CLC: 86.0
1: ASh #-14., R0 Evt: 0 ; Run: 3998 ; Res: 3998 ; CLC: 90.0
1: ASh #-15., R0 Evt: 0 ; Run: 3828 ; Res: 3828 ; CLC: 94.0
1: ASh #-16., R0 Evt: 0 ; Run: 3671 ; Res: 3671 ; CLC: 98.1
1: ASh #-17., R0 Evt: 0 ; Run: 3528 ; Res: 3528 ; CLC: 102.0
1: ASh #-20., R0 Evt: 0 ; Run: 3156 ; Res: 3156 ; CLC: 114.1
1: ASh #-30., R0 Evt: 0 ; Run: 2337 ; Res: 2337 ; CLC: 154.0
1: ASh #-31., R0 Evt: 0 ; Run: 2278 ; Res: 2278 ; CLC: 158.0
.VDT
VDT V05.07
*177746/000000 14
*^C
.RUN ASH1
ASH1 - v1.0
Memory Top: 116334
BUF words: 18266
CPU KHz: 18000 >
1: ASh #00., R0 Evt: 3 ; Run: 7459 ; Res: 7462 ; CLC: 48.2
1: ASh #01., R0 Evt: 3 ; Run: 6908 ; Res: 6911 ; CLC: 52.1
1: ASh #02., R0 Evt: 3 ; Run: 6389 ; Res: 6392 ; CLC: 56.3
1: ASh #03., R0 Evt: 2 ; Run: 5963 ; Res: 5965 ; CLC: 60.4
1: ASh #04., R0 Evt: 3 ; Run: 5584 ; Res: 5587 ; CLC: 64.4
1: ASh #05., R0 Evt: 2 ; Run: 5263 ; Res: 5265 ; CLC: 68.4
1: ASh #06., R0 Evt: 2 ; Run: 4968 ; Res: 4970 ; CLC: 72.4
1: ASh #07., R0 Evt: 1 ; Run: 4709 ; Res: 4710 ; CLC: 76.4
1: ASh #08., R0 Evt: 1 ; Run: 4470 ; Res: 4471 ; CLC: 80.5
1: ASh #09., R0 Evt: 1 ; Run: 4255 ; Res: 4256 ; CLC: 84.6
1: ASh #10., R0 Evt: 1 ; Run: 4064 ; Res: 4065 ; CLC: 88.6
1: ASh #11., R0 Evt: 1 ; Run: 3887 ; Res: 3888 ; CLC: 92.6
1: ASh #12., R0 Evt: 0 ; Run: 3723 ; Res: 3723 ; CLC: 96.7
1: ASh #13., R0 Evt: 1 ; Run: 3574 ; Res: 3575 ; CLC: 100.7
1: ASh #14., R0 Evt: 1 ; Run: 3439 ; Res: 3440 ; CLC: 104.7
1: ASh #15., R0 Evt: 0 ; Run: 3310 ; Res: 3310 ; CLC: 108.8
1: ASh #16., R0 Evt: 0 ; Run: 3192 ; Res: 3192 ; CLC: 112.8
1: ASh #17., R0 Evt: 0 ; Run: 3081 ; Res: 3081 ; CLC: 116.8
1: ASh #20., R0 Evt: 0 ; Run: 2791 ; Res: 2791 ; CLC: 129.0
1: ASh #30., R0 Evt: 0 ; Run: 2127 ; Res: 2127 ; CLC: 169.3
1: ASh #31., R0 Evt: 0 ; Run: 2078 ; Res: 2078 ; CLC: 173.2
.RUN ASH2
ASH2 - v1.0
Memory Top: 116334
BUF words: 18262
CPU KHz: 18000 >
1: ASh #000., R0 Evt: 3 ; Run: 7459 ; Res: 7462 ; CLC: 48.2
1: ASh #-01., R0 Evt: 4 ; Run: 6908 ; Res: 6912 ; CLC: 52.1
1: ASh #-02., R0 Evt: 2 ; Run: 6388 ; Res: 6390 ; CLC: 56.3
1: ASh #-03., R0 Evt: 2 ; Run: 5963 ; Res: 5965 ; CLC: 60.4
1: ASh #-04., R0 Evt: 2 ; Run: 5584 ; Res: 5586 ; CLC: 64.4
1: ASh #-05., R0 Evt: 3 ; Run: 5263 ; Res: 5266 ; CLC: 68.4
1: ASh #-06., R0 Evt: 3 ; Run: 4968 ; Res: 4971 ; CLC: 72.4
1: ASh #-07., R0 Evt: 2 ; Run: 4709 ; Res: 4711 ; CLC: 76.4
1: ASh #-08., R0 Evt: 2 ; Run: 4470 ; Res: 4472 ; CLC: 80.5
1: ASh #-09., R0 Evt: 1 ; Run: 4255 ; Res: 4256 ; CLC: 84.6
1: ASh #-10., R0 Evt: 1 ; Run: 4064 ; Res: 4065 ; CLC: 88.6
1: ASh #-11., R0 Evt: 1 ; Run: 3887 ; Res: 3888 ; CLC: 92.6
1: ASh #-12., R0 Evt: 2 ; Run: 3723 ; Res: 3725 ; CLC: 96.6
1: ASh #-13., R0 Evt: 1 ; Run: 3574 ; Res: 3575 ; CLC: 100.7
1: ASh #-14., R0 Evt: 0 ; Run: 3439 ; Res: 3439 ; CLC: 104.7
1: ASh #-15., R0 Evt: 0 ; Run: 3310 ; Res: 3310 ; CLC: 108.8
1: ASh #-16., R0 Evt: 1 ; Run: 3192 ; Res: 3193 ; CLC: 112.7
1: ASh #-17., R0 Evt: 0 ; Run: 3081 ; Res: 3081 ; CLC: 116.8
1: ASh #-20., R0 Evt: 0 ; Run: 2791 ; Res: 2791 ; CLC: 129.0
1: ASh #-30., R0 Evt: 0 ; Run: 2127 ; Res: 2127 ; CLC: 169.3
1: ASh #-31., R0 Evt: 0 ; Run: 2078 ; Res: 2078 ; CLC: 173.2
---------- Post added at 02:02 ---------- Previous post was at 01:53 ----------
Еще бы эти тесты коль уж претендуют на возможность возврата в систему после выполнения, позволяли запускать их в любом мониторе, что требует страшно трудной переделки - добавки трех строчек кода :)
А то блин всегда перегружаться приходится...
