А что это за глюки ?
Вот то же самое, что в ASH1, ASH2, ASHC1 и ASHC2, но первый операнд не в памяти, а в регистре:
ASH3_&_ASH4 и ASHC3_&_ASHC4.
Код:.RU ASH3
ASH3 - v1.0
Memory Top: 116334
BUF words: 18269
CPU KHz: 5300 > 18000
CPU KHz: 18000
1: 0: ASh R2,R0 Evt: 0 ; Run: 15641 ; Res: 15641 ; CLC: 23.0
1: 1: ASh R2,R0 Evt: 2 ; Run: 13325 ; Res: 13327 ; CLC: 27.0
1: 2: ASh R2,R0 Evt: 0 ; Run: 11606 ; Res: 11606 ; CLC: 31.0
1: 3: ASh R2,R0 Evt: 1 ; Run: 10279 ; Res: 10280 ; CLC: 35.0
1: 4: ASh R2,R0 Evt: 0 ; Run: 9225 ; Res: 9225 ; CLC: 39.0
1: 5: ASh R2,R0 Evt: 1 ; Run: 8366 ; Res: 8367 ; CLC: 43.0
1: 6: ASh R2,R0 Evt: 1 ; Run: 7655 ; Res: 7656 ; CLC: 47.0
1: 7: ASh R2,R0 Evt: 0 ; Run: 7055 ; Res: 7055 ; CLC: 51.0
1: 8: ASh R2,R0 Evt: 2 ; Run: 6541 ; Res: 6543 ; CLC: 55.0
1: 9: ASh R2,R0 Evt: 0 ; Run: 6098 ; Res: 6098 ; CLC: 59.0
1: 10: ASh R2,R0 Evt: 0 ; Run: 5711 ; Res: 5711 ; CLC: 63.0
1: 11: ASh R2,R0 Evt: 1 ; Run: 5370 ; Res: 5371 ; CLC: 67.0
1: 12: ASh R2,R0 Evt: 0 ; Run: 5067 ; Res: 5067 ; CLC: 71.0
1: 13: ASh R2,R0 Evt: 0 ; Run: 4797 ; Res: 4797 ; CLC: 75.0
1: 14: ASh R2,R0 Evt: 0 ; Run: 4554 ; Res: 4554 ; CLC: 79.1
1: 15: ASh R2,R0 Evt: 0 ; Run: 4335 ; Res: 4335 ; CLC: 83.0
1: 16: ASh R2,R0 Evt: 0 ; Run: 4136 ; Res: 4136 ; CLC: 87.0
1: 17: ASh R2,R0 Evt: 2 ; Run: 3954 ; Res: 3956 ; CLC: 91.0
1: 20: ASh R2,R0 Evt: 0 ; Run: 3493 ; Res: 3493 ; CLC: 103.1
1: 30: ASh R2,R0 Evt: 1 ; Run: 2516 ; Res: 2517 ; CLC: 143.0
1: 31: ASh R2,R0 Evt: 1 ; Run: 2437 ; Res: 2438 ; CLC: 147.7
.RU ASH3
ASH3 - v1.0
Memory Top: 116334
BUF words: 18269
CPU KHz: 18000 >
1: 0: ASh R2,R0 Evt: 1 ; Run: 11990 ; Res: 11991 ; CLC: 30.0
1: 1: ASh R2,R0 Evt: 1 ; Run: 10580 ; Res: 10581 ; CLC: 34.0
1: 2: ASh R2,R0 Evt: 1 ; Run: 9466 ; Res: 9467 ; CLC: 38.0
1: 3: ASh R2,R0 Evt: 1 ; Run: 8565 ; Res: 8566 ; CLC: 42.0
1: 4: ASh R2,R0 Evt: 1 ; Run: 7820 ; Res: 7821 ; CLC: 46.0
1: 5: ASh R2,R0 Evt: 1 ; Run: 7194 ; Res: 7195 ; CLC: 50.0
1: 6: ASh R2,R0 Evt: 1 ; Run: 6661 ; Res: 6662 ; CLC: 54.0
1: 7: ASh R2,R0 Evt: 1 ; Run: 6202 ; Res: 6203 ; CLC: 58.0
1: 8: ASh R2,R0 Evt: 1 ; Run: 5802 ; Res: 5803 ; CLC: 62.0
1: 9: ASh R2,R0 Evt: 1 ; Run: 5450 ; Res: 5451 ; CLC: 66.0
1: 10: ASh R2,R0 Evt: 1 ; Run: 5139 ; Res: 5140 ; CLC: 70.0
1: 11: ASh R2,R0 Evt: 1 ; Run: 4861 ; Res: 4862 ; CLC: 74.0
1: 12: ASh R2,R0 Evt: 1 ; Run: 4612 ; Res: 4613 ; CLC: 78.0
1: 13: ASh R2,R0 Evt: 1 ; Run: 4387 ; Res: 4388 ; CLC: 82.0
1: 14: ASh R2,R0 Evt: 1 ; Run: 4183 ; Res: 4184 ; CLC: 86.0
1: 15: ASh R2,R0 Evt: 1 ; Run: 3997 ; Res: 3998 ; CLC: 90.0
1: 16: ASh R2,R0 Evt: 1 ; Run: 3827 ; Res: 3828 ; CLC: 94.0
1: 17: ASh R2,R0 Evt: 1 ; Run: 3671 ; Res: 3672 ; CLC: 98.0
1: 20: ASh R2,R0 Evt: 1 ; Run: 3270 ; Res: 3271 ; CLC: 110.1
1: 30: ASh R2,R0 Evt: 1 ; Run: 2398 ; Res: 2399 ; CLC: 150.1
1: 31: ASh R2,R0 Evt: 1 ; Run: 2336 ; Res: 2337 ; CLC: 154.0
---------- Post added at 16:26 ---------- Previous post was at 16:25 ----------
Код:.RU ASH4
ASH4 - v1.0
Memory Top: 116334
BUF words: 18263
CPU KHz: 18000
1: 0: ASh R2,R0 Evt: 0 ; Run: 15642 ; Res: 15642 ; CLC: 23.0
1: -1: ASh R2,R0 Evt: 0 ; Run: 13325 ; Res: 13325 ; CLC: 27.0
1: -2: ASh R2,R0 Evt: 0 ; Run: 11605 ; Res: 11605 ; CLC: 31.0
1: -3: ASh R2,R0 Evt: 0 ; Run: 10279 ; Res: 10279 ; CLC: 35.0
1: -4: ASh R2,R0 Evt: 0 ; Run: 9225 ; Res: 9225 ; CLC: 39.0
1: -5: ASh R2,R0 Evt: 0 ; Run: 8367 ; Res: 8367 ; CLC: 43.0
1: -6: ASh R2,R0 Evt: 0 ; Run: 7655 ; Res: 7655 ; CLC: 47.0
1: -7: ASh R2,R0 Evt: 0 ; Run: 7054 ; Res: 7054 ; CLC: 51.0
1: -8: ASh R2,R0 Evt: 0 ; Run: 6541 ; Res: 6541 ; CLC: 55.0
1: -9: ASh R2,R0 Evt: 2 ; Run: 6098 ; Res: 6100 ; CLC: 59.0
1: -10: ASh R2,R0 Evt: 1 ; Run: 5711 ; Res: 5712 ; CLC: 63.0
1: -11: ASh R2,R0 Evt: 0 ; Run: 5370 ; Res: 5370 ; CLC: 67.0
1: -12: ASh R2,R0 Evt: 0 ; Run: 5067 ; Res: 5067 ; CLC: 71.0
1: -13: ASh R2,R0 Evt: 0 ; Run: 4797 ; Res: 4797 ; CLC: 75.0
1: -14: ASh R2,R0 Evt: 2 ; Run: 4554 ; Res: 4556 ; CLC: 79.0
1: -15: ASh R2,R0 Evt: 0 ; Run: 4335 ; Res: 4335 ; CLC: 83.0
1: -16: ASh R2,R0 Evt: 1 ; Run: 4136 ; Res: 4137 ; CLC: 87.0
1: -17: ASh R2,R0 Evt: 0 ; Run: 3954 ; Res: 3954 ; CLC: 91.0
1: -20: ASh R2,R0 Evt: 1 ; Run: 3493 ; Res: 3494 ; CLC: 103.0
1: -30: ASh R2,R0 Evt: 0 ; Run: 2516 ; Res: 2516 ; CLC: 143.1
1: -31: ASh R2,R0 Evt: 0 ; Run: 2437 ; Res: 2437 ; CLC: 147.7
.VDT
VDT V05.07
*177746/000000 14
*^C
.RU ASH4
ASH4 - v1.0
Memory Top: 116334
BUF words: 18263
CPU KHz: 18000 >
1: -1: ASh R2,R0 Evt: 1 ; Run: 10580 ; Res: 10581 ; CLC: 34.0
1: -2: ASh R2,R0 Evt: 1 ; Run: 9466 ; Res: 9467 ; CLC: 38.0
1: -3: ASh R2,R0 Evt: 1 ; Run: 8564 ; Res: 8565 ; CLC: 42.0
1: -4: ASh R2,R0 Evt: 1 ; Run: 7820 ; Res: 7821 ; CLC: 46.0
1: -5: ASh R2,R0 Evt: 1 ; Run: 7194 ; Res: 7195 ; CLC: 50.0
1: -6: ASh R2,R0 Evt: 1 ; Run: 6661 ; Res: 6662 ; CLC: 54.0
1: -7: ASh R2,R0 Evt: 1 ; Run: 6202 ; Res: 6203 ; CLC: 58.0
1: -8: ASh R2,R0 Evt: 1 ; Run: 5802 ; Res: 5803 ; CLC: 62.0
1: -9: ASh R2,R0 Evt: 1 ; Run: 5450 ; Res: 5451 ; CLC: 66.0
1: -10: ASh R2,R0 Evt: 1 ; Run: 5139 ; Res: 5140 ; CLC: 70.0
1: -11: ASh R2,R0 Evt: 1 ; Run: 4861 ; Res: 4862 ; CLC: 74.0
1: -12: ASh R2,R0 Evt: 1 ; Run: 4612 ; Res: 4613 ; CLC: 78.0
1: -13: ASh R2,R0 Evt: 1 ; Run: 4387 ; Res: 4388 ; CLC: 82.0
1: -14: ASh R2,R0 Evt: 1 ; Run: 4183 ; Res: 4184 ; CLC: 86.0
1: -15: ASh R2,R0 Evt: 1 ; Run: 3997 ; Res: 3998 ; CLC: 90.0
1: -16: ASh R2,R0 Evt: 1 ; Run: 3827 ; Res: 3828 ; CLC: 94.0
1: -17: ASh R2,R0 Evt: 1 ; Run: 3671 ; Res: 3672 ; CLC: 98.0
1: -20: ASh R2,R0 Evt: 1 ; Run: 3270 ; Res: 3271 ; CLC: 110.1
1: -30: ASh R2,R0 Evt: 1 ; Run: 2398 ; Res: 2399 ; CLC: 150.1
1: -31: ASh R2,R0 Evt: 1 ; Run: 2336 ; Res: 2337 ; CLC: 154.0
Код:.RU ASHC4
ASHC4 - v1.0
Memory Top: 116334
BUF words: 18262
CPU KHz: 18000
1: 0: AShC R2,R0 Evt: 1 ; Run: 13325 ; Res: 13326 ; CLC: 27.0
1: -1: AShC R2,R0 Evt: 1 ; Run: 10280 ; Res: 10281 ; CLC: 35.0
1: -2: AShC R2,R0 Evt: 1 ; Run: 8367 ; Res: 8368 ; CLC: 43.0
1: -3: AShC R2,R0 Evt: 1 ; Run: 7655 ; Res: 7656 ; CLC: 47.0
1: -4: AShC R2,R0 Evt: 1 ; Run: 7055 ; Res: 7056 ; CLC: 51.0
1: -5: AShC R2,R0 Evt: 1 ; Run: 6542 ; Res: 6543 ; CLC: 55.0
1: -6: AShC R2,R0 Evt: 1 ; Run: 6098 ; Res: 6099 ; CLC: 59.0
1: -7: AShC R2,R0 Evt: 1 ; Run: 5711 ; Res: 5712 ; CLC: 63.0
1: -8: AShC R2,R0 Evt: 1 ; Run: 5370 ; Res: 5371 ; CLC: 67.0
1: -9: AShC R2,R0 Evt: 1 ; Run: 5068 ; Res: 5069 ; CLC: 71.0
1: -10: AShC R2,R0 Evt: 1 ; Run: 4797 ; Res: 4798 ; CLC: 75.0
1: -11: AShC R2,R0 Evt: 1 ; Run: 4554 ; Res: 4555 ; CLC: 79.0
1: -12: AShC R2,R0 Evt: 1 ; Run: 4335 ; Res: 4336 ; CLC: 83.0
1: -13: AShC R2,R0 Evt: 1 ; Run: 4136 ; Res: 4137 ; CLC: 87.0
1: -14: AShC R2,R0 Evt: 1 ; Run: 3954 ; Res: 3955 ; CLC: 91.0
1: -15: AShC R2,R0 Evt: 1 ; Run: 3788 ; Res: 3789 ; CLC: 95.0
1: -16: AShC R2,R0 Evt: 1 ; Run: 3634 ; Res: 3635 ; CLC: 99.0
1: -17: AShC R2,R0 Evt: 1 ; Run: 3493 ; Res: 3494 ; CLC: 103.0
1: -20: AShC R2,R0 Evt: 1 ; Run: 3129 ; Res: 3130 ; CLC: 115.0
1: -30: AShC R2,R0 Evt: 1 ; Run: 2309 ; Res: 2310 ; CLC: 155.8
1: -31: AShC R2,R0 Evt: 1 ; Run: 2225 ; Res: 2226 ; CLC: 161.7
.VDT
VDT V05.07
*177746/000000 14
*^C
.RU ASHC4
ASHC4 - v1.0
Memory Top: 116334
BUF words: 18262
CPU KHz: 18000 >
1: 0: AShC R2,R0 Evt: 1 ; Run: 10580 ; Res: 10581 ; CLC: 34.0
1: -1: AShC R2,R0 Evt: 1 ; Run: 8565 ; Res: 8566 ; CLC: 42.0
1: -2: AShC R2,R0 Evt: 2 ; Run: 7194 ; Res: 7196 ; CLC: 50.0
1: -3: AShC R2,R0 Evt: 1 ; Run: 6661 ; Res: 6662 ; CLC: 54.0
1: -4: AShC R2,R0 Evt: 2 ; Run: 6202 ; Res: 6204 ; CLC: 58.0
1: -5: AShC R2,R0 Evt: 2 ; Run: 5802 ; Res: 5804 ; CLC: 62.0
1: -6: AShC R2,R0 Evt: 2 ; Run: 5450 ; Res: 5452 ; CLC: 66.0
1: -7: AShC R2,R0 Evt: 1 ; Run: 5139 ; Res: 5140 ; CLC: 70.0
1: -8: AShC R2,R0 Evt: 2 ; Run: 4861 ; Res: 4863 ; CLC: 74.0
1: -9: AShC R2,R0 Evt: 2 ; Run: 4612 ; Res: 4614 ; CLC: 78.0
1: -10: AShC R2,R0 Evt: 2 ; Run: 4387 ; Res: 4389 ; CLC: 82.0
1: -11: AShC R2,R0 Evt: 2 ; Run: 4183 ; Res: 4185 ; CLC: 86.0
1: -12: AShC R2,R0 Evt: 2 ; Run: 3997 ; Res: 3999 ; CLC: 90.0
1: -13: AShC R2,R0 Evt: 2 ; Run: 3827 ; Res: 3829 ; CLC: 94.0
1: -14: AShC R2,R0 Evt: 2 ; Run: 3671 ; Res: 3673 ; CLC: 98.0
1: -15: AShC R2,R0 Evt: 2 ; Run: 3527 ; Res: 3529 ; CLC: 102.0
1: -16: AShC R2,R0 Evt: 2 ; Run: 3394 ; Res: 3396 ; CLC: 106.0
1: -17: AShC R2,R0 Evt: 1 ; Run: 3270 ; Res: 3271 ; CLC: 110.1
1: -20: AShC R2,R0 Evt: 2 ; Run: 2949 ; Res: 2951 ; CLC: 122.0
1: -30: AShC R2,R0 Evt: 2 ; Run: 2221 ; Res: 2223 ; CLC: 161.9
1: -31: AShC R2,R0 Evt: 1 ; Run: 2167 ; Res: 2168 ; CLC: 166.1
---------- Post added at 16:33 ---------- Previous post was at 16:27 ----------
Код:.RU ASHC3
ASHC3 - v1.0
Memory Top: 116334
BUF words: 18268
CPU KHz: 18000 >
1: 1: AShC R2,R0 Evt: 1 ; Run: 9225 ; Res: 9226 ; CLC: 39.0
1: 2: AShC R2,R0 Evt: 1 ; Run: 8367 ; Res: 8368 ; CLC: 43.0
1: 3: AShC R2,R0 Evt: 0 ; Run: 7655 ; Res: 7655 ; CLC: 47.0
1: 4: AShC R2,R0 Evt: 0 ; Run: 7055 ; Res: 7055 ; CLC: 51.0
1: 5: AShC R2,R0 Evt: 1 ; Run: 6541 ; Res: 6542 ; CLC: 55.0
1: 6: AShC R2,R0 Evt: 1 ; Run: 6098 ; Res: 6099 ; CLC: 59.0
1: 7: AShC R2,R0 Evt: 0 ; Run: 5711 ; Res: 5711 ; CLC: 63.0
1: 8: AShC R2,R0 Evt: 0 ; Run: 5370 ; Res: 5370 ; CLC: 67.0
1: 9: AShC R2,R0 Evt: 0 ; Run: 5068 ; Res: 5068 ; CLC: 71.0
1: 10: AShC R2,R0 Evt: 0 ; Run: 4797 ; Res: 4797 ; CLC: 75.0
1: 11: AShC R2,R0 Evt: 1 ; Run: 4555 ; Res: 4556 ; CLC: 79.0
1: 12: AShC R2,R0 Evt: 1 ; Run: 4335 ; Res: 4336 ; CLC: 83.0
1: 13: AShC R2,R0 Evt: 1 ; Run: 4136 ; Res: 4137 ; CLC: 87.0
1: 14: AShC R2,R0 Evt: 0 ; Run: 3954 ; Res: 3954 ; CLC: 91.0
1: 15: AShC R2,R0 Evt: 0 ; Run: 3788 ; Res: 3788 ; CLC: 95.0
1: 16: AShC R2,R0 Evt: 0 ; Run: 3634 ; Res: 3634 ; CLC: 99.1
1: 17: AShC R2,R0 Evt: 0 ; Run: 3493 ; Res: 3493 ; CLC: 103.1
1: 20: AShC R2,R0 Evt: 1 ; Run: 3129 ; Res: 3130 ; CLC: 115.0
1: 30: AShC R2,R0 Evt: 0 ; Run: 2309 ; Res: 2309 ; CLC: 155.9
1: 31: AShC R2,R0 Evt: 0 ; Run: 2225 ; Res: 2225 ; CLC: 161.8
.VDT
VDT V05.07
*177746/000000 14
*^C
.RU ASHC3
ASHC3 - v1.0
Memory Top: 116334
BUF words: 18268
CPU KHz: 18000 >
1: 1: AShC R2,R0 Evt: 0 ; Run: 7820 ; Res: 7820 ; CLC: 46.0
1: 2: AShC R2,R0 Evt: 1 ; Run: 7194 ; Res: 7195 ; CLC: 50.0
1: 3: AShC R2,R0 Evt: 1 ; Run: 6661 ; Res: 6662 ; CLC: 54.0
1: 4: AShC R2,R0 Evt: 1 ; Run: 6202 ; Res: 6203 ; CLC: 58.0
1: 5: AShC R2,R0 Evt: 1 ; Run: 5802 ; Res: 5803 ; CLC: 62.0
1: 6: AShC R2,R0 Evt: 1 ; Run: 5450 ; Res: 5451 ; CLC: 66.0
1: 7: AShC R2,R0 Evt: 1 ; Run: 5139 ; Res: 5140 ; CLC: 70.0
1: 8: AShC R2,R0 Evt: 1 ; Run: 4861 ; Res: 4862 ; CLC: 74.0
1: 9: AShC R2,R0 Evt: 1 ; Run: 4612 ; Res: 4613 ; CLC: 78.0
1: 10: AShC R2,R0 Evt: 1 ; Run: 4387 ; Res: 4388 ; CLC: 82.0
1: 11: AShC R2,R0 Evt: 1 ; Run: 4183 ; Res: 4184 ; CLC: 86.0
1: 12: AShC R2,R0 Evt: 0 ; Run: 3997 ; Res: 3997 ; CLC: 90.1
1: 13: AShC R2,R0 Evt: 1 ; Run: 3827 ; Res: 3828 ; CLC: 94.0
1: 14: AShC R2,R0 Evt: 1 ; Run: 3671 ; Res: 3672 ; CLC: 98.0
1: 15: AShC R2,R0 Evt: 1 ; Run: 3527 ; Res: 3528 ; CLC: 102.0
1: 16: AShC R2,R0 Evt: 1 ; Run: 3394 ; Res: 3395 ; CLC: 106.0
1: 17: AShC R2,R0 Evt: 1 ; Run: 3270 ; Res: 3271 ; CLC: 110.1
1: 20: AShC R2,R0 Evt: 1 ; Run: 2949 ; Res: 2950 ; CLC: 122.0
1: 30: AShC R2,R0 Evt: 1 ; Run: 2221 ; Res: 2222 ; CLC: 162.0
1: 31: AShC R2,R0 Evt: 1 ; Run: 2167 ; Res: 2168 ; CLC: 166.1
