yes, doesn't look well.
I would maybe try to use the CN ahead of instruction, and real labels on separate line ahead:
BTW, the "=" (alias "DEFL") is more like variable, and allows redefinition of the value. If things like `frq` are used for self-modify code, I would suggest to use EQU instead, which creates "constant" (attempt to redefine it second time in source will emit error about different value assigned).Код:frq = $+1
CN=CN+10 : ld de,$0123
With a bonus of the EQU maybe creating different visual feel in this case too:
Or maybe use macro? But that will explode the listing file, but if you are not planning to use listing very often for this area of code, it may help with the source (you can disable listing for particular part of source, if you are using listing to check other areas).Код:frq EQU $+1
Код:countT MACRO cycles?
CN=CN+(cycles?)
ENDM
CN=0
ld a,b : countT 4
and $70 : countT 7
frq=$+1 ld de,$1234 : countT 10
IF CN < 26
.((26-CN+3)/4) nop
countT (26-CN+3)&-4
ENDIF
