Цитата:
This directory contains all of the files needed to build an "RT11
emulator" for the V6, V7, 32V, 3BSD and 4.0BSD dialects of UNIX.
Цитата:
RUST/SJ is a classic unmapped RT-11 single-job system, the kind of thing you want in your toolkit when you're setting up a new system or debugging a system problem. The goals are classic RT-11: small, fast and easy-to-use.
RUST/XM is a mapped RT-11 multi-process system with PLAS, MTT, and many VMS-like extensions. While RT-11 is Prime Target there is also support for RSX, TSX and Unix applications. There's no SYSGEN: features are installed and removed at runtime. RUST/XM is configurable for single-user or multi-user use (with DZ11 and DHV11 support built-in). There are a number of packages supplied, including a real-time kit.
