там был нюанс с TOS - какие то версии уже были конкретно заточены под более продвинутые машинки. я запамятовал ссылку но народ вроде сделал новый ТОС или некоммерческий аналог оригинального TOS. как бы это был не чел с сайта FPGAarcade.
по поводу попробовать - я пока еще не собрал второй стол для работы и Атарик некуда поставить пока. посему пробы нового ТОС я не проводил. нет даже возможности глянуть а какой же версии у меня прошит.
Тогда изучайте:
TOS-Fixes/Patches
ROM TOS (TOS 1.0)
The original ROM TOS, this version shipped in 520ST and 1040ST
machines. It is no longer shipping in any machines.
Formats: 2 chip ROMs (a 1MB Prom DIL-Chip), 6 chip ROMs (a 256KB Prom
DIL-Chip)
Machines: 520ST, 1040ST
Utilities: FOLDRXXX.PRG
FOLDRXXX.PRG will add more entries into your OS Pool.
In TOS 1.0 and TOS 1.02, the limit for the number of
directories that you can enter is around 40. With this
program you can extend that limit much higher. If you
are using a hard drive, this program is recommended
highly. It will work with all TOS versions and will
ive the performance of your system.
Notes: GET TOS 1.04 TODAY! TOS 1.04 is the latest version of TOS
for 520/1040/MEGA owners. It is MUCH faster, has faster,
better disk I/O, many other improvements.
MEGA TOS (TOS 1.02)
This is commonly referred to as MEGA TOS. This version of TOS fixes
some minor problems in TOS 1.0 and has support for the BLiTTER chip
and Real-Time Clock chip.
DIL-Chip)
Machines: 520ST, 1040ST, Mega 2, Mega 4
FOLDRXXX.PRG is explained above.
Notes: See notes for TOS 1.0.. GET TOS 1.04 TODAY!
Rainbow TOS (TOS 1.04)
TOS 1.04 or Rainbow TOS, as it is commonly known is the latest
version of TOS available for 520/1040/MEGA owners. It has been
available as a dealer upgrade for awhile now. It has much more
robust Disk I/O, Autorunning of GEM programs at boot up,
a fix for the 40 folder limit, and much more. Most of all is
it much faster than previous versions of the Operating System.
DIL-Chip-available as Upgrade!)
Machines: Stacy
Utilities: TOS14FIX.PRG, POOLFIX3.PRG, CACHEXXX.PRG, FOLDRXXX.PRG
TOS14FIX.PRG solves some small problems in the AES (for
additional information, please see the documentation that
accompanies the TOS14FIX.PRG program).
POOLFIX3.PRG fixes a bug in GEMDOS. Documentation that
accompanies the POOLFIX3.PRG program explains (in detail)
the problem that it fixes.
CACHEXXX.PRG is a new program that adds GEMDOS buffers
to your system. The caching of data and disk directories
by GEMDOS (when this program is used) will result in
your system running much faster! This program is highly
recommended and requires TOS 1.04 or higher for full
benefits!
Notes: Please use the utilities available and if you haven't
upgraded to this version of TOS yet.. please consider
doing so. It's a very worthwhile upgrade.
There are some disk-based versions of _early_ developer
only releases of TOS 1.04 floating around on BBS systems
here in the United States and abroad. Please don't use
them! They are bad news! They have some very nasty bugs
and have been known to corrupt data!
STE TOS, Rev 1 (TOS 1.06)
TOS 1.06 is the TOS version that is shipped with the 1040STE and
520STE machines. It is essentially TOS 1.04 with support for the new
hardware that the STE has.
Formats: 2 chip ROMs (or 1MB Eprom DIL-Chip)
Machines: 520STE, 1040STE
Utilities: STE_FIX.PRG, POOLFIX3.PRG, CACHEXXX.PRG, FOLDRXXX.PRG
STE_FIX fixes the infamous Desktop Medium/Low resolution
bug. The problem is that there is a bug in the desktop
code in this version of TOS that prevents the user from
booting into Medium Resolution. The patch program STE_FIX
will solve the problem. Once it is executed in the AUTO
folder, the problem no longer exists.
FOLDRXXX.PRG, CACHEXXX.PRG, and POOLFIX3.PRG are
explained above.
Notes: This version is only available in 1040STE and 520STE
machines. It isn't available for upgrading. It won't
work in older machines.
STE TOS, Rev 2 (TOS 1.62)
This is a slightly revised revision of TOS 1.6. It fixes the POOLFIX
problem in GEMDOS and the problem in the Desktop that was present in
TOS 1.06.
Utilities: CACHEXXX.PRG, FOLDRXXX.PRG
CACHEXXX.PRG and FOLDRXXX.PRG are explained above.
Notes: This version is only available in 1040ST and 520STE
Mega STE TOS (TOS 2.05)
TOS 2.05 is the version of TOS currently shipping in the Mega STE.
Formats: 2 chip ROMs (a 1MB Eprom DIL-Chip)
Machines: Mega STE
Notes: This version is only available in the Mega STE. It isn't
Mega STE TOS (TOS 2.06)
TOS 2.06 is the latest version of TOS currently shipping in the Mega
STE and fixed from Atari for TOS-Upgrade with a TOS-Card for all ST's
and the STBook
Machines: Mega STE
Notes: This version is available on ST/MegaST/MegaSTE. It is an
for upgrade for all older TOS versions on ST-Computers.
TT TOS (TOS 3.01)
TOS 3.01 is the version of TOS that originally shipped in the TT030.
Formats: 4 chip ROMs (a 1MB Eprom DIL-Chip)
Machines: TT030
Notes: This version is only avaible in the TT030. It isn't
TT TOS (TOS 3.05)
TOS 3.05 is the second version of TOS currently shipping in the
TT030.
Machines: TT030
Utilities: CACHEXXX.PRG, FOLDRXXX.PRG, SERPTCH1.PRG, SERPTCH2.PRG
TT TOS (TOS 3.06)
TOS 3.06 is the latest version of TOS currently shipping in the
TT030.
Machines: TT030
ну я как бы про это и говорил :
я уже натыкался на этот текст ранее. у меня как раз STF а не STE. на новых тачках они уже блиттер ставили и память стояла в виде SIMM модулей. и что-то было вроде намучено по поводу DMA звука .
balu_dark, там есть еще 2.06
and the STBook
It is an for upgrade for all older TOS versions on ST-Computers.
Цитата:
Сообщение от
Atari
а поделись готовыми файлами под 2*128 флешки, плз.
Вот TOS 1.04 English с разбивкой на 2 ПЗУ по мегабиту и на 6 по 256 килобит.
ПЗУ проверены, 100% рабочие, другими пользоваться НЕ рекомендую!
по поводу разбиения ТОС на LO и HI не понял как это делать,
установил софт программатора но не нашел в нем как разбить
кто в курсе помогите
давно это было, не помню :(
ищите что-то типа odd even
хм нет нигде ничего похожего - odd even..
речь идет про софт программатора - тритон?
японский бог.. нашел!
