Цитата:
Hello,
a new hard drive with system 7 installed. I hope that'll fix matters.
According to the technical specifications, the LC 475 needs at least System 7.1 and a System Enabler 065 (the specifications for the Performa 475 list System 7.1P3 and System Enabler 364). No need for system enablers with the newer operating systems mentioned.
I don't have a Mac with a floppy drive
If you have (or could borrow) a Windows PC (with a floppy drive), it can be used for the Network Access Disk 7.5 download, but would require (Aladdin) StuffIt Expander for Windows and a suitable PC disk image utility.
Normally, never decode or decompress Mac program files on a PC. Always keep MacBinary (.bin) or BinHex (.hqx) unaltered until on a Macintosh computer.
BTW, a full System 7.5.3 is available for download from Apple (e.g., British and North American versions). The downloadable System 7.5.3 files are small enough to be transferred on 1.44 MB diskettes (in this case, a plain copying process; no separate disk image program needed). A startup floppy file is not included (use the Network Access Disk 7.5 whenever necessary).
Jan
то есть берете досовский RAWRITE (ну или этот
