balu_dark,
и картинка будет в цвете?
Добавлено через 7 минут
balu_dark,
RF-out - это случаем не антенный PAL выход?
а то нашел на одно форуме такое
The C64 has a built-in RF modulator, so you should be able to plug it directly into your TV, given that:
1. Your TV has an coaxial antenna input (which I suppose all still have?)
2. Your TV is set to channel UHF 36 (PAL/Europe) or VHF 3 (NTSC/US ?)
3. You don't live in a place where airbourne digital TV or other nonsense is cluttering the frequency span and will prevent you from getting a picture in the UHF frequency range
4. You use the correct type of cable, but the one included with the computer should be OK
То есть 36 канал можно настроить и будет изображение?
Или всеже это не то?
