глупость полная ваще - судя по имени чел - русский, а ему дойч понадобился..
Обновление редактора - ZX-Paintbrush 2.5
http://www.zx-modules.de/zxpaintbrus...rushframe.html
Топик на WoS
Цитата:
1. Bugfix: The new tool clone last drawn figure had no link to the context help.
2. Here some suggestions from kgmcneil:
2.1. With a new toggle function toggle overlay display you can hide an existing overly (it's still present but it's not displayed). This toggle function can be executed by pressing the 'O' key.
2.2 Implemented another raster edit to let the user adjust the X- and Y-raster independently.
2.3 Implemented a user-defined grid that can be used in addition to the pixels- and character grid.
2.4 Implemented a way for drawing with images. To perform this, a double-click on an existing overlay now draws it on the screen.
3. Implemented a 'remove capture' icon that removes an active capture object which was not easy
4. Bugfix: The utility "convert colour overlay to pixels only overlay" changed the position of the resulting overlay to top-left corner of the screen. Now it calculates the last position without attribute sizes and stays on its position.
5. Merging a colour overlay now does it the same way: The selection rectangle is not longer expanded to the full attribute area.
6. The holding of x or y cursor position is now performed with the <x> and <y> key rather than <shift> and <ctrl>. Because the older keys interfered with the capture drag function.
7. Einar Saukas suggested another algorithm for the "import picture" tool. Now, on a 2-color attribute field (8x8 or one of the others), the darker colour becomes INK and the brighter becomes PAPER.
Обновилась версия 2.5 до ZX-Paintbrush 2.5.1.2
Цитата:
- kgmcneil suggested a toggle function for the background picture. The background picture display now can be toggled with the <P> key.
- The X/Y rulers for grid lines and raster have been extracted from the raster toolbar and from the colors tool bar. Now, there are 3 different and separate toolbars for the rulers only.
- User-defined selector tool added. And also two rulers for X/Y values of the selection range.
- Changed the caption of these different toolbars with X/Y rulers for better identification: Selector toolbar uses Sx/Sy, raster toolbar uses Rx/Ry, grid toolbar uses Gx/Gy.
- The pixel grid and user-defined grid are now visible even with zoom levels from 200% and up.
- Bugfix: Removed the function that ignores the raster when a selector tool 8x8, 16x16, 256x192 and user-defined is active. This was necessary because the raster is needed while selectors are active, as well as when overlays are moved.
- Bugfix: Once again errors with the usage of raster. Einar Saukas kindful reported these. The problems seem to be fixed now. :-(
Выложите плиз ZX-Paintbrush 2.5.1.2 куда-нибудь на обменник! По ссылке выше не могу скачать. Щёлкаю по Download и ничего не происходит ((
Обновление редактора - ZX-Paintbrush 2.6
Топик на WoS
Цитата:
Основные изменения:
- Map editing features along with a new file format "*.zxm"
- Color attributes are now changed while drawing. This is more direct than in previous versions.
Остальные изменения:
Октябрь:
- Bugfix: Einar Saukas found the bug of all three inverter tools: They always moved in steps of 8 pixels no matter what attribute height we had.
- Bugfix: Einar Saukas reported that the "send to" feature does not work in Windows Explorer.
Ноябрь:
- Bugfix: When executed inside a dialog (e.g. inside of ZX-Blockeditor), the editing of Timex screens did not work properly.
- Added map editing feature. Maps are normal screens with overlayed map elements that may appear one or more times on that screen, which saves memory for storing and increases the flexibility to re-organize a screen to be a screen map for games etc. Map element display can be toggled with the 'M' key.
- Iznogoud suggested: The zoom factors of the preview window have been changed to fix values for better and undistorted display.
- JoeFish suggested: Attribute changes should be visible while drawing figures. This feature has now been implemented.
- Bugfix: Selective points were displayed when the inverter tools and shader tool have been used. This was annoying.
Декабрь:
- Added a list of hot keys and shortcuts in the context help.
- moroz1999 suggested to add the <Ctrl+ +> and <Ctrl+ -> keys for zoom in and out.
- Bugfix: moroz1999 reported that the mouse wheel should control the zoom combobox, when dropped down.
- Added GIF animation support. The picture converter now contains a frame selector for opened GIFs that contain more than one frame.
- Added a "set screen size" checkbox to the picture converter dialog.
блин, гифки распарсил, а нужного не сделал(
напиши сам:)
я стесняюсь и не шарю в инглезе.
