K-MOUSE 2008 can work in master or slave mode. If user connect two K-MOUSE 2008 interfaces and first device switch as master and second as slave then both mouses will use different ports:
master mouse:
#FADF - buttons
#FBDF - x-axis
#FFDF - y-axis
slave mouse:
#3ADF - buttons
#3BDF - x-axis
#3FDF - y-axis
You can use same mouse driver, only if slave(player two) is active then on mouse ports reset adress A15 and A14 (#Fxxx > #3xxx). If you access to free 128kB pages then use two different mouse drivers.
