подписи проводов конвертер не перенес, в kicad вроде нет такой возможности провода подписывать.
хм, а как выход U54 отключает выходы U178?
из `свежих` новостей
"Some Z80 chips react differently to a out-of-spec INT signal that does not respect the setup time.
A description of this appears in the ULA book, pg.227-228.
If the previous instruction is just an opcode fetch (OCF) cycle,
these Z80 chips will accept an INT signal that was asserted later than the usual sampling time (rising CLK of OCF-T4).
