No - FF port is useless in this mode. In exUSSR nobody dont use FF port.
Запустил. Спасибо Syd за дельные советы и за разработку 2010, Zorel за оказанную помощь в приобретении платы и комплектующих.
Speccy2010, ver 1.0, rev 51 !
RTC init OK..
SD card init OK..
FPGA cofiguration file speccy2010.rbf is opened...
FPGA configuration started...
FPGA configuration status OK...
....................................FPGA configuration conf done...
FPGA configuration finished...
Speccy2010 FPGA configuration found...
FPGA clock - 19.99717 MHz
FPGA PLL clock - 83.98810 MHz
ROM configuration started...
ROM configuration finished...
PS/2 keyboard init OK..
AndyS, Кварц заменил?
AndyS, поздравляю с запуском !
Такой http://kazershop.kiev.ua/Dzhojstik-sega/p-108.html подойдет для 2010-го?
да, подойдёт, у меня такой же
The problem with SID is that it occupying a FPGA space and I'm running out of that space. Syd make a provision for use different fpga files and this might be the answer. All it is needed is a switch in ARM firmware.
Regarding the SAA1099 - I think it's worth to be considered but I'm almost certain It won't fit the current FPGA with turbo sound. But maybe there will be another way - for example external card with real chip-something to consider...
