Страница 10 из 23 ПерваяПервая ... 67891011121314 ... ПоследняяПоследняя
Показано с 91 по 100 из 223
Тема: Эмулятор Atari
  1. #91
    Омск
    46
    32 сообщений
    Altirra 2.1 - стабильный релиз.
    http://virtualdub.org/downloads/Altirra-2.10.zip
    http://virtualdub.org/downloads/Altirra-2.10-src.zip
    список изменений:
    [features added]
    SlightSID emulation support.
    Covox emulation support.
    1200XL emulation support.
    BASIC programs can now be booted.
    Fast boot option now accelerates timeouts for powered down disk drives.
    Disk: Added support for format skewed ($66) command.
    Disk: Format commands ($21, $22) now support high-speed operation.
    Disk: Added emulation profile modes for various disk drives.
    Disk: Reduced ACK-to-complete delay when accurate sector timing is off.
    Disk: Added rotation and seek sound emulation.
    Disk: Accurate disk timing prediction is now preserved when burst I/O transfers are enabled.
    Debugger: Added .sum (sum memory area) command.
    Debugger: Added .warmstart command.
    Debugger: Added ap (alias pattern) command for adding aliases with patterns.
    Debugger: Added additional aliases to a8 command (set Atari800-compatible command aliases).
    Debugger: Added alternate L>addr syntax for setting an address range length based on an end address.
    Debugger: Added heat map support.
    Debugger: Added .basic_dumpline command.
    Debugger: Enter now repeats the last command.
    Debugger: .dumpdlist command now collapses runs of identical commands.
    Debugger: Unassemble and dump commands now support continuation from the last address.
    Debugger: Added deref signed byte (dsb) expression operator.
    Debugger: Added %c and %y formatting specifiers to .printf command.
    Debugger: Added .dmamap command to show ANTIC DMA pattern over the course of a frame.
    Serial: 1030 Modem support.
    Display: Added scanline display mode.
    Display: Added integer-multiple version of preserve aspect ratio sizing mode.
    Display: Added sharp bilinear filter mode.
    Display: Text can now be copied out of ANTIC modes 2, 3, 6, and 7 (GR.0, 1, and 2).
    Display: Added CIO intercept based enhanced text mode.
    HDevice: Added minimal support for SDX Get Current Directory command ($30).
    HDevice: Added support for H6-H9: text translation modes.
    HDevice: Implemented rename, get/set/create/remove directory, and get file length commands.
    HDevice/PCLink: Fixed lock command not setting read-only flag.
    Cartridge: Added MicroCalc 32K cartridge type support.
    Cartridge: Added cartridge type autodetection.
    UI: Screenshot command now adjusts for interlacing and 14MHz dot clock rendering.
    UI: The program is now marked as high DPI aware in the application manifest.
    Simulator: Added support for MapRAM MMU modification.
    [bugs fixed]
    Increased paste keyboard timer to reduce dropped keys on line processing delays.
    Fixed startup crash on Sandy Bridge CPUs on Windows XP.
    Simulator: Inhibit FP math acceleration hooks when PBI ROM overlay is active.
    Simulator: BASIC disable Option key hold is now released more quickly to reduce cartridge conflicts.
    Debugger: "read" and "write" terms can now appear more than twice in a conditional breakpoint expression.
    Debugger: Fixed .tracecio off not working.
    Debugger: Fixed execution stopping on TRACE statements.
    Debugger: Breakpoint clear (bc) command no longer interprets breakpoint numbers as hex.
    Debugger: Fixed console entry window not always disabling properly.
    Debugger: .pokey command now reports correct status for secondary POKEY.
    Display: Fixed crash on some XP systems on display mode change.
    Display: Added workaround for ps1.1 precision issue on Intel graphics cards.
    Display: Fixed bicubic scaling in OpenGL mode.
    ANTIC: Fixed line buffer addressing to correctly handle aliasing of buffered data to different modes.
    POKEY: Fixed glitching in high-pass filtering.
    POKEY: Fixed wrong bit in SKSTAT being set for serial input overruns.
    POKEY: Fixed asynchronous receive mode not resetting timers 3+4 that are already running.
    Disk: Fixed handling of XF551 high-speed sector skew format commands ($A1/$A2).
    Disk: Format command now sends back ACK+ERROR+buffer instead of NAK on a read-only disk.
    Disk: Adjusted step rate of 810 drive to 5.3ms.
    Disk: Fixed forced sector ordering command (.diskorder) for .pro images.
    Disk: Step delays were not always reflected correctly in command delay time (only rotational position).
    Disk: Fixed inverted write protect bit status.
    Disk: Attempted writes to a write protected disk now return errors instead of a NAK.
    Disk: Fixed command response when accessing a drive with no disk.
    Disk: Fixed error return for unsupported Write PERCOM Block requests.
    Disk Explorer: Fixed case sensitivity issue allowing duplicate file creation on DOS 2 file systems.
    Input: Fixed bug in keyboard repeat detection code.
    Input: Improved Caps Lock key support.
    Cartridge: An error is now thrown when attempting to save a cartridge image in .CAR format with an unsupported mapper.
    Cartridge: Fixed switchable XEGS cartridge modes.
    Display: Fixed display mode matching when /f is specified on the command line.
    Display: Improved behavior of interlaced mode when frames are dropped.
    CPU: Fixed cycle behavior of ASL/LSR/ROL/ROR abs,X instructions in 65C02 mode.
    HLE Kernel: Fixed BUFADR being overwritten by CIO, which broke the DOS XE executable loader.
    IDE: Fixed banking in KMK/JZ V1 mode and added 3K ROM support.
    IDE: Fixed multiple sector read requests of exactly 32 sectors.
    VBXE: Fixed memory not being cleared on cold reset with randomize function disabled.
    Serial: Fixed incompatibility with Ice-T XE and the R: handler's STATUS handler.
    Misc: Fixed upper 4 bits for some R-Time 8 register reads.
    HDevice: Fixed NOTE and POINT commands.
    Cheats: Fixed 16-bit option not being tracked properly for manually entered cheats.
    GTIA: Sprites are now triggered properly from within horizontal blank.
    GTIA: Fixed sprite image overlap result.
    Cassette: Loading a new tape didn't press 'play' on the emulated player until the next cold reset.
    ну вот и дождались финального релиза эмулятора, Эвери работал над этой версией аж восемь месяцев (сколько будет разрабатываться следуящая версия боюсь предположить даже), причём вышла она как-раз акурат к моим именинам
    ниже прилагаю свой файл настроек и полный комплект биосов, достаточно просто распаковать архив в папку с эмулятором.
    Последний раз редактировалось ZEman; 16.05.2013 в 11:22.
  2. #91
  3. #92
    8 сообщений
    не качается алтирра
    You don't have permission to access /downloads/Altirra-2.10.zip on the virtualdub.org website. Nuts.
    Последний раз редактировалось razer; 14.08.2012 в 19:39.
    "С тобою мы объехали пол света,но каждый раз тянуло нас домой,поставь мою любимую кассету,давай передохнём перед игрой"
  4. #93
    Омск
    46
    32 сообщений
    странно, обычно оттуда всегда качается без проблем.
    возьмите эмулятор с другого сайта, например здесь
    http://tv-games.ru/forum/showthread.php?t=3662&page=46
    я тут рубрику по атари давно веду.
    ---------- Post added at 22:58 ---------- Previous post was at 22:51 ----------
    видимо сайт глючит, ща выложу на файлообменник, погодите.
    ---------- Post added at 23:01 ---------- Previous post was at 22:58 ----------
    http://depositfiles.com/files/m5o2f3dd5
    держи.
  5. #94
    Samara
    322
    246 сообщений
    что за дебуггер?
    есть ли где нибудь нормальный эмулятор с нормальным дебуггером?
    по типу no$gmb
    С уважением,
    Jerri / Red Triangle.
  6. #95
    Омск
    46
    32 сообщений
    в altirra дебугер проработан по самое нехочу, автор им постоянно занимается.
    за эти 7 тестов от 2.2 версии много чего было добавленно, самые же интересные нововведения это - сейвы и ultimate1mb.
  7. #96
    Samara
    322
    246 сообщений
    ZEman, это не дебуггер это монитор
    С уважением,
  8. #97
    Омск
    46
    32 сообщений
    в смысле ?
    что тебе в нём нужно ?
    пиши, я уже несколько лет являюсь бета-тестером эмулятора altirra, любые предложения могу сразу передать Эвери.
  9. #98
    goblinish
    для Atari дебаггер годен в Atari800win Plus.
  10. #99
    Омск
    46
    32 сообщений
    goblinish, чтото ты путаешь, это в altirra дебагер а в Atari800win Plus всего-лишь монитор, он кстати именно так и называется "monitor".
  11. #100
    goblinish
    набор команд более похож на отладчик имхо.
  1. Винтажный дисковод-atari+мафон-atari
    от doc11 в разделе Барахолка (архив)
    Последнее: 15.07.2010, 10:00
  2. Продажа ATARI 65XE ATARI 2600 Sega MegaDrive
    от Zloy в разделе Барахолка (архив)
    Ответов: 69
    Последнее: 05.06.2010, 15:08
  3. [Питер] Продам Atari 65 XE, магнитофон Atari XC12
    Последнее: 05.02.2010, 11:48
  4. Продам в Питере Atari 65XL + Atari STe
    от scald-spb в разделе Барахолка (архив)
    Последнее: 26.08.2008, 10:28
  5. эмулятор ZX Spectrum на Atari XL?
    от [bETA]mEN в разделе Atari
    Последнее: 09.12.2007, 22:51
