Страница 1 из 70 12345 ... ПоследняяПоследняя
Показано с 1 по 10 из 699
Тема: SjASMPlus от z00m
    77
    59 сообщений
    По умолчанию SjASMPlus от z00m
    Альтернативная ветка от чехов нашего любимого кросс-асма.
    https://github.com/z00m128/sjasmplus/releases
    Достаточно часто обновляется со вкусными релиз нотами.
    sjasmplus v1.11.0
    Added ZX Spectrum Next instructions support
    Added --msg option, directives DG and DH
    Changed listing layout to fixed-width type
    Errors, Warnings and similar are now channeled to STDERR
    Fixed string literal parser, added two apostrophes and escaped zero
    Fixed docs templates (HTML is now more valid)
    Fixed nesting DUP issue
    Fixed CRLF handling in parser
    Fixed -D option for multiple asm files
    Fixed address display when the 64kB limit exceeded
    Fixed lost code when current memory leaves device slot in "disp" mode
    Fixed IF inside MACRO, DUP and REPT
    Fixed ALIGN behavior and docs wording
    Fixed INCHOB/INCBIN (offset / length)
    Fixed INCLUDE/INCLUDELUA system path priority ("" vs <>)
    Fixed END behavior
    Fixed DEFARRAY to work as documented
    Fixed and refactored WORD/DWORD/D24
    Fixed and extended STRUCT
    Multiple bugfixes in listing generation
    Multiple bugfixes of internal code
    Refactored options parser, instruction parser and Warning/Error system
    C++14 standard is now required minimum (to compile sjasmplus sources)
    Added automated-testing scripts, with 50+ tests
    GitHub connected with Cirrus Continuous Integration service
    sjasmplus v1.11.1
    Fixed global labels in MACRO and in IFUSED/IFNUSED
    Fixed nested IF-DUP-IF
    Fixed local labels fail when amount of lines did change between passes
    Fixed Makefile to build when path to project contains space
    Added macro-example: turn "DJNZ ." into "DJNZ $" (to fix Zeus syntax source)
    Added --msg=lst and --msg=lstlab options to produce listing file to STDERR
    Added options to read input file from STDIN and output "raw" binary to STDOUT
    Эти 2 пользователя(ей) поблагодарили krt17 за это полезное сообщение:
    ace210(05.01.2021), SAVC(07.04.2024)
    Ладошкино
    339
    244 сообщений
    14 Post(s)
    хы, .SCL без ошибок компилит. Уже нравиЦЦа.
    Profi v3.2 -=- Speccy2010,r2
    г. Дзержинск, Украина
    663
    513 сообщений
    печально что не отечественная ветка
    г. Таллин, Эстония
    223
    159 сообщений
    Какая разница, кто поднял упавший флаг, если несёт достойно?
    663
    513 сообщений
    некому писать пожилания и угрозы
    а ищо вроде есть жо наша отечественная ветка (которая должна была фсех победить)
    и вообще будем надеятсо что настанет тот день
    когда sjasm ВНЕЗАПНО закомпилирует сорцы аласма
    Последний раз редактировалось NEO SPECTRUMAN; 04.04.2019 в 00:59.
    г. Таллин, Эстония
    223
    159 сообщений
    		ld      a, '\\'
    В других верисиях ок, эта вываливает предупреждение (полученный бинарник, правда, правильный)
    г. Арзамас
    181
    126 сообщений
    все повторы по старинке через DUP/REPT
    в Storm'e было после .4 - удобнее.
    г. Арзамас
    181
    126 сообщений
    с системными переменными та же шляпа со 128
    Cyprus
    24
    20 сообщений
    Печально что эти парни взяли за основу древнейший код, незаметив "основную", более новую ветку, которую правил @Vitamin и позже я. Во многом заново наступают на/правят те же самые грабли, древнейший код.
    Да вот действительно, вспоминается анекдот про "ты хотя бы лотерейный билет купи". Уж сколько раз я предлагал писать запросы/багрепорты в issues. Один @asve79 что-то пишет иногда, а больше никому ничего не нужно судя по всему.
    А это зачем нужно? Аласмовские сорцы токенизированные же? Чем их редактировать на PC?
    Последний раз редактировалось mastermind; 05.04.2019 в 18:22.
    г. Арзамас
    181
    126 сообщений
    А ничем. От специфического синтаксиса можно чокнуться
    не понравилось, что при компиляции вылезает сообщение об include/incbin
  1. SjASMPlus Z80 кросс ассемблер
    от Aprisobal в разделе Программирование
    Ответов: 1663
    Последнее: 19.06.2021, 01:36
  2. Исходники TR-DOS для SjASMPlus
    от Keeper в разделе Программирование
    Ответов: 20
    Последнее: 11.02.2011, 11:57
  3. Запуск STS из .sna, сгенерированного sjasmplus.
    от siril в разделе Программирование
    Последнее: 11.10.2010, 21:33
  4. Breakpoints в связке Sjasmplus+UnrealSpeccy
    от Kurles в разделе Программирование
    Ответов: 19
    Последнее: 26.01.2009, 12:36
  5. Disturbed COverMAnia ( music disk with z00m music collection)
    от kyv в разделе Музыка
    Последнее: 27.03.2008, 10:01
