Страница 80 из 107 ПерваяПервая ... 767778798081828384 ... ПоследняяПоследняя
Показано с 791 по 800 из 1061
Тема: Электроника-85 vs. DEC Pro-350 + их эмуляция
  1. #791
    СССР, Новосибирск
    290
    234 сообщений
    30 Post(s)
    Интересно. A DU/MU - они же с DMA?
    Да, с DMA.
    Файлы лежат здесь.
    Скачал прямо c TSX'а
    pdp-11:~/public_html/files/tsx-plus% ftp bigsys
    Connected to bigsys.home.lan.
    220 Remote FTP Server bigsys.home.lan [172.31.10.13] Ready
    Name (bigsys:form):
    331 Password required for user form
    Password:
    230-Logged into Default Directory - /du7:
    230-RFTP-11   V02.40  [15-Jun-2008]
    230-Initiated from host: 172.31.10.1
    230-No RFTP Message File
    230 User form logged in [password verified]
    Remote system type is TSX-Plus.
    ftp> bi
    200 Type set to I, binary transfer mode
    ftp> prom
    Interactive mode off.
    ftp> mg ohandl.obj tskmn1.obj tskmn3.obj tskmsg.obj tsname.obj
    local: ohandl.obj remote: ohandl.obj
    227 Entering Passive Mode (172,31,10,13,63,154)
    150 Opening a BINARY data connection for ohandl.obj  (512 bytes)
    226 Transfer complete
    512 bytes received in 2.01 seconds (0.25 KB/s)
    local: tskmn1.obj remote: tskmn1.obj
    227 Entering Passive Mode (172,31,10,13,64,30)
    150 Opening a BINARY data connection for tskmn1.obj  (22528 bytes)
    22528 bytes received in 2.65 seconds (8.29 KB/s)
    local: tskmn3.obj remote: tskmn3.obj
    227 Entering Passive Mode (172,31,10,13,64,191)
    150 Opening a BINARY data connection for tskmn3.obj  (24064 bytes)
    24064 bytes received in 2.71 seconds (8.66 KB/s)
    local: tskmsg.obj remote: tskmsg.obj
    227 Entering Passive Mode (172,31,10,13,65,99)
    150 Opening a BINARY data connection for tskmsg.obj  (12288 bytes)
    12288 bytes received in 2.17 seconds (5.54 KB/s)
    local: tsname.obj remote: tsname.obj
    227 Entering Passive Mode (172,31,10,13,65,237)
    150 Opening a BINARY data connection for tsname.obj  (1024 bytes)
    1024 bytes received in 2.02 seconds (0.50 KB/s)
    ftp> quit
    221 Goodbye
    DOB если что можно на CTAKAHе запользовать, но и в RT-11 вроде были какие-то объектные дизассемблеры.
    PMI: KDJ11-BF, MSV11-JE
    VT220, CM7209
  2. #792
    г. Караганда, Казахстан
    225
    177 сообщений
    17 Post(s)
    Файлы лежат здесь.
    Это TSKMN1.OBJ, я без всяких дизассемблеров, посмотрел эту радость в HEX-виде FAR'ом, поискал в нем DIR*ECTORY и тут же нашел кусок таблицы из него:
    CMDHD::
    .WORD 2
    $$$CMD <R> CMDRSY
    $$$CMD <RU*N> CMDRUN
    $$$CMD <REN*AME> CMDCCL
    $$$CMD <REM*OVE> CMDREM
    $$$CMD <RES*UME> CMDRSM
    $$$CMD <RESE*T> CMDRST
    $$$CMD <COP*Y> CMDCCL
    $$$CMD <DIR*ECTORY> CMDCCL
    Теперь вопрос: а как его собрать назад, с моим TSKMO1 (во девичестве TSKMN1, в прошлый раз я ошибся с его девичьей фамилией )? Под виндой, или под RT-11. И где Потёмкин его выкопал?
    А пользовать надо именно его - именно в нём вписан SL от Сторожевых.
    Последний раз редактировалось AFZ; 12.03.2015 в 20:14.
  3. #793
    СССР, Новосибирск
    290
    234 сообщений
    30 Post(s)
    Собрать просто - COP все эти файлы (перечисленные через +) в TSX2.OBJ
    Только следует помнить, что OBJ нельзя просто так подредактировать редактором - там контрольные суммы ведутся. Нужно PAT использовать. Его впрочем можно напрямую на TSX2.OBJ натравить - он поймет
    VT220, CM7209
  4. #794
    225
    177 сообщений
    17 Post(s)
    Это я помню. Но мне и не надо его править, у меня ведь есть исходник. А я-то все удивлялся, что это за (OHANDL,TSKMN3,TSKMSG,TSNAME).O лежат у меня в TSX02.RT (см. PRO TSX plus 6.1.zip\PROTSXplus601\ из той самой свалки разных TSX, котокую я выложил в мессаге 769, стр. 77)
    Последний раз редактировалось AFZ; 12.03.2015 в 21:19.
  5. #795
    СССР, Новосибирск
    290
    234 сообщений
    30 Post(s)
    У меня тоже где-то эти самые TSX*.RT валяются, на досуге надо будет глянуть да сравнить. А так - теперь считай TSX+ V6.01 полноценный есть: и для прошника и Y2K-совместим (кстати даже V6.50 не совместим до конца хотя и претендует на то )
    VT220, CM7209
  6. #796
    Зеленоград
    374
    311 сообщений
    вне темы
    по правой кнопке в контекстном меню - выбрать если "копировать ссылку" наведя
    мышь на номер сообщения, получаем ссылку на конкретное сообщение на форуме, которое можно вставить в текущее сообщение )
    Последний раз редактировалось hobot; 12.03.2015 в 21:57. Причина: исправил-уточнил ;-)
  7. #796
  8. #797
    225
    177 сообщений
    17 Post(s)
    То, что собирал я, пока не совместимо. Еще раз все проверю, выложу в упорядоченном виде всё, что надо, а потом и пропатчим. Хотя в той свалке лежит и какая-то патченная, посмотрю, если пойдет, то сразу сделаю с ней. А какие модули там патчатся?
    Блин, заглянул в исходник, а у него в четвертой заполненной строчке стоит .TITLE TSKMN1. И что было думать, кто там этот TSKMO1.OBJ?
    Последний раз редактировалось AFZ; 12.03.2015 в 22:06.
  9. #798
    СССР, Новосибирск
    290
    234 сообщений
    30 Post(s)
    Ну заодно можно проверить подойдут ли патчи
    VT220, CM7209
  10. #799
    225
    177 сообщений
    17 Post(s)
    Ура! Мы ее таки победили! TSX полностью собирается и сразу работает, без патчей для TSKMON.SAV ! Завтра-послезавтра выложу с полной инструкцией, сейчас сильно хочется спать...
  11. #800
    Vancouver, Canada
    Вот такая ошибка вылазит при установке ПРОС на ST-251 через 45 мин.
    Форматируются дорожки 0 - 579 для всех 6 головок, дорожки 580 - 819 остаются неотформатированными.
  1. Вектор-06Ц: Эмуляция
    от ZEman в разделе Вектор
    Ответов: 1516
    Последнее: 16.10.2025, 11:13
  2. [Поиск 1] Эмуляция
    от KingArthur в разделе Поиск
    Ответов: 192
    Последнее: 05.12.2021, 15:48
  3. Эмуляция Profi
    от Zloy в разделе Эмуляторы
    Ответов: 13
    Последнее: 16.03.2009, 05:58
  4. Аппаратная эмуляция GS/TFM/AY
    от Black_Cat в разделе Эмуляторы
    Ответов: 34
    Последнее: 03.05.2008, 23:34
