Страница 33 из 112 ПерваяПервая ... 293031323334353637 ... ПоследняяПоследняя
Показано с 321 по 330 из 1113
Тема: Софт для ДВК/PDP11
  1. #321
    СССР, Новосибирск
    289
    233 сообщений
    30 Post(s)
    Пример использования КОИ-8 шрифтов на VT2xx терминалах.
    Для простоты прога использует многотерминальный функционал который заведомо позволяет печатать 8бит символы без правки монитора.
    	.TITLE	VT2XXR
    	.IDENT	/V01.00/
    UNIT	=	8.
    M.TST2	=	2
    WPALL$	=	100000
    ESC	=	33
    	.MCALL	.EXIT,.MTATCH,.MTGET,.MTSET,.MTPRNT
    START::	.MTATCH	#AREA,#0,#UNIT
    	.MTGET	#AREA,#STAT,#UNIT
    	MOV	STAT+M.TST2,-(SP)
    	BIS	#WPALL$,STAT+M.TST2
    	.MTSET	#AREA,#STAT,#UNIT
    	.MTPRNT	#AREA,#VTLD,#UNIT
    	MOV	#CHRS,R1
    	MOV	#200,R2
    	CALL	PRINT
    	BIS	#40,R2
    	CALL	PRINT
    	CLR	R0
    	SOB	R0,.
    	MOV	(SP)+,STAT+M.TST2
    	.EXIT
    PRINT:	MOV	R1,-(SP)
    10$:	TSTB	@R1
    	BEQ	20$
    	BISB	R2,(R1)+
    	BR	10$
    20$:	MOV	(SP)+,R1
    	.MTPRNT	#AREA,R1,#UNIT
    	RETURN
    AREA:	.BLKW	3
    STAT:	.BLKW	4
    CHRS:	.ASCIZ	/@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_/
    VTLD:	.ASCII	<ESC>/[62;0"P/
    	.ASCII	<ESC>/ F/
    	.ASCII	<ESC>/P0;0;1;4;1;1{U/
    	.ASCII	"???????/???????;???}???/???A???;"
    	.ASCII	"?M??M??/???????;g}gg}g?/?B??B??;"
    	.ASCII	"GSS}SS_/?@@B@@?;CIcOGcA/A@??@A@;"
    	.ASCII	"kQQQk?_/@AAAA@A;??GEA??/???????;"
    	.ASCII	"?wCA???/??@A???;???ACw?/???A@??;"
    	.ASCII	"OSwOwSO/?@???@?;OOO{OOO/???@???;"
    	.ASCII	"???????/?CB@???;OOOOOOO/???????;"
    	.ASCII	"???????/??BB???;??_OGCA/A@?????;"
    	.ASCII	"wCAAACw/?@AAA@?;?GC}???/?AABAA?;"
    	.ASCII	"CaaQQQK/BAAAAAA;AAAQYUa/@AAAAA@;"
    	.ASCII	"_ogca}_/?????B?;]IIIIIq/@AAAAA@;"
    	.ASCII	"wcQQQQc/@AAAAA@;AAAaQIE/??B????;"
    	.ASCII	"kQQQQQk/@AAAAA@;KQQQQQ{/?AAAAA@;"
    	.ASCII	"??KK???/??BB???;??KK???/?CB@???;"
    	.ASCII	"O?g?C?A/????@?A;ggggggg/???????;"
    	.ASCII	"A?C?g?O/A?@????;CAAqIIC/???A???;"
    	.ASCII	"w_oGGGo/B?@AAA@;?ggggo?/@AAAA@A;"
    	.ASCII	"_QUYYQa/@AAAAA@;w????w?/@AAA@@E;"
    	.ASCII	"cQQQQQ{/@AAAAA@;ogggggo/@AAAAA?;"
    	.ASCII	"_OOwOO_/?@@B@@?;?gggggO/@AAAAAA;"
    	.ASCII	"G?O_O?G/A?@?@?A;w????w?/@AAA@BA;"
    	.ASCII	"w??C?w?/@AAA@BA;w___OOG/B???@@A;"
    	.ASCII	"??oGGGw/AA@???B;wO___Ow/B??@??B;"
    	.ASCII	"w_____w/B?????B;oGGGGGo/@AAAAA@;"
    	.ASCII	"wOGGGo?/B????BA;Ogggggw/AA@???B;"
    	.ASCII	"wGGGGGo/F@@@@@?;oGGGGGO/@AAAAA@;"
    	.ASCII	"GGGwGGG/???B???;w?????w/CDDDDDB;"
    	.ASCII	"GO_w_OG/A@?B?@A;{QQYSO_/@AAAAA@;"
    	.ASCII	"w_____?/BAAAAA@;w___??w/BAAA@?B;"
    	.ASCII	"OGGgggO/@AAAAA@;w??w??w/BAABAAB;"
    	.ASCII	"OGGgggo/@AAAAA@;w??w??w/BAABAAF;"
    	.ASCII	"w_____w/??????B;GGw___?/??BAAA@;"
    	.ASCII	"}O{AAA{/B?@AAA@;ogcaaa}/B?????B;"
    	.ASCII	"}QQQQQa/BAAAAA@;}????}?/BAAAABE;"
    	.ASCII	"?{AAA}?/EBAAABE;}QQQQQQ/BAAAAAA;"
    	.ASCII	"wCC}CCw/?@@B@@?;}AAAAAA/B??????;"
    	.ASCII	"E?gOg?E/B?????B;}?_OGC}/B@????B;"
    	.ASCII	"}?_RHC}/B@????B;}OOOggE/B?????B;"
    	.ASCII	"oGCAAA}/B?????B;}CGoGC}/B?????B;"
    	.ASCII	"}_____}/B?????B;{AAAAA{/@AAAAA@;"
    	.ASCII	"}AAAAA}/B?????B;KQqQQQ}/A@????B;"
    	.ASCII	"}aaaaa[/B??????;{AAAAAA/@AAAAAA;"
    	.ASCII	"EAA}AAE/???B???;MOOOOO}/@AAAAA@;"
    	.ASCII	"EgO}OgE/B??B??B;}QQQQ[_/BAAAAA@;"
    	.ASCII	"}OOOOO_/BAAAAA@;}OOO_?}/BAAA@?B;"
    	.ASCII	"CAAQQQk/@AAAAA@;}??}??}/BAABAAB;"
    	.ASCII	"AAQQQQ{/AAAAAA@;}??}??}/BAABAAF;"
    	.ASCII	"]OOOOO}/??????B;M}OOOO_/?BAAAA@;"
    	.ASCII	<ESC>"/"
    	.ASCII	<ESC>")U"
    	.ASCII	<ESC>"~"
    	.BYTE	200
    	.END	START
    Последний раз редактировалось form; 03.04.2013 в 00:47.
    PMI: KDJ11-BF, MSV11-JE
    VT220, CM7209
  2. #322
    СССР, Новосибирск
    289
    233 сообщений
    30 Post(s)
    По умолчанию Time over Ethernet
    Весьма уродливая недореализация subj. Подготовка к переходу на новую версию протокола. Пока многое не проверяется что должно бы, о big endian даже не думал еще. Работает и ладно, а окончательный вариант будем допиливать постепенно...
    В комплекте программа ETHTIM.SAV с исходниками для RT-11/TSX-Plus и исходники ethtimed для запуска под UNIX-системами (проверялся только в OpenBSD и Ubuntu).
    Не нашел где тут прошлая версия валалась. С тех пор изменилось:
    • параметр HZ передается серверу в рамках протокола
    • появилась поддержка TSX-Plus
    • в рамках протокола передается ID системы (необязательно)
    • полный поиск свободного unit драйвера
    pdp-11:~% zgrep ethtim /var/log/daemon.0.gz
    Apr  8 11:49:06 pdp-11 ethtimed[11759]: request from 08:00:2b:31:47:b4, 50 Hz, TSX-Plus V6.01
    Apr  8 11:49:46 pdp-11 ethtimed[11759]: request from 08:00:2b:31:47:b4, 50 Hz, RT-11ZM (S) V05.07
    pdp-11:~%
    Последний раз редактировалось form; 07.06.2014 в 18:33.
    VT220, CM7209
  3. #323
    149
    80 сообщений
    16 Post(s)
    В новой версии DAY.SAV исправлена (надеюсь) ошибка, приводившая к вылету по Trap_To_4 при запуске на процессорах, не допускающих словного обращения по нечётному адресу.
    Зеленоград
    374
    311 сообщений
    (надеюсь)
    Я ссылку на обе версии просто сделаю < ТУТ >. У меня пока старенькая пашет и в эмуляторе и в на живой машинке - вроде норм.
  5. #325
    149
    80 сообщений
    16 Post(s)
    Там по ошибке в одном месте вместо MOVB выполняется MOV.
    Новая версия ( DAY v2.0 ) отличается только исправлением этой ошибки.
  6. #326
    149
    80 сообщений
    16 Post(s)
    Новая версия DAY.SAV v2.1 при запуске переводит терминал во 2-ю систему команд.
    СССР, Новосибирск
    289
    233 сообщений
    30 Post(s)
    А она предварительно убеждается в том, что это в принципе возможно?
    VT220, CM7209
  8. #328
    149
    80 сообщений
    16 Post(s)
    Для этого посылается код 027, который никому не мешает.
  9. #329
    СССР, Новосибирск
    289
    233 сообщений
    30 Post(s)
    Это всего лишь предположение, что не мешает, хотя в большинстве случаев не лишенное основания.
    Впрочем точно также всего лишь предположение, что можно с помощью <BS> или <CR> вернуться и напечатать другую строчку вместо старой - для многих терминалов это не верно
    VT220, CM7209
  10. #330
    СССР, Новосибирск
    289
    233 сообщений
    30 Post(s)
    Обновление библиотеки RSXLIB. Убрана точка (и расширение если есть) при форматировании с помощью $EDMSG спецификации файла в которой отсутствует имя файла. Если в спецификации отсутствует как имя так и устройство, выводится точка.
    Последний раз редактировалось form; 07.06.2014 в 18:32.
    VT220, CM7209
  1. Криста-2: Софт
    от fan в разделе Вектор
    Ответов: 53
    Последнее: 24.04.2009, 01:31
  2. Софт для Covox'а
    от BYTEMAN в разделе Софт
    Последнее: 30.07.2008, 11:53
  3. Софт под GS ?
    от AAA в разделе Софт
    Последнее: 13.03.2008, 17:08
  4. Софт для ПК
    от Ewgeny7 в разделе Утилиты
    Последнее: 13.07.2006, 11:30
  5. Софт под iS-dos
    от demon_zx в разделе Софт
    Последнее: 07.03.2006, 23:35
