Страница 14 из 16 ПерваяПервая ... 10111213141516 ПоследняяПоследняя
Показано с 131 по 140 из 158
Тема: Sundown 2009
  1. #131
    Норвегия
    Unbeliever, I will try to talk to some real C64 coders today and see what they say about it
    ---------- Post added at 10:13 ---------- Previous post was at 10:08 ----------
    BTW, I sent a mail about buying a Pentagon (thanks Riskej for the info) and got a reply now! Hopefully I will be able to buy one when the next production run starts.
  2. #132
    Воронеж
    Цитата Сообщение от Mermaid Посмотреть сообщение
    Ah, but there is no shifting of pixels in my image, and the artefacts have nothing to do with that - it's just the way the C64 graphics are displayed on the real machine connected to a TV or Commodore/Philips monitor - you will never get a sharp image, colours that are close to eachother will always blend/bleed, and so you can mix colours even without the use of interlace, just by placing colours of a similar luminance close to eachother. My image uses the standard C64 multicolour bitmap mode with no programming tricks at all.
    (Again, sorry for typing this in English)
    Hello, Mermaid!
    I’m like your images, especially series of pictures about little girl and doggie.
    I want learn to drawing on C64, but my real C64 not so good for drawing.
    What emulator of C64 and what graphic editor you use?
    Can you give me a link to download them?
    Kasik
  3. #133
    Норвегия
    Kasik
    Sure!
    Emulator: VICE - make sure to turn on PAL emulation under options to make it look more like the real C64 display.
    The graphics editor I use under Windows is Timanthes, it requires .net and it crashes sometimes but it's still nice, you can use it for many different C64 graphics modes. Just make sure to save your work often!
    Another popular editor is Project One, also a Windows program. I've never tested that one myself but some people really like it.
    Now about the graphics restrictions...
    Singlecolour bitmap mode (sometimes called hires bitmap) is similar to normal Spectrum bitmap, 2 colours for each 8x8 pixel block, 320x200 pixels.
    AFLI or HIFLI is almost like above but with 2 colours per 8x1 pixel block
    Multicolour bitmap mode is 160x200 pixels, 3 colours + screen colour per 4x8 pixel block.
    FLI is like multicolour bitmap but with more colours per block.
    There are a lot of other formats too, with and without interlace, some using sprites to get even more colours, but those are the 4 oldest and the ones I normally use.
  4. #134
    Норвегия
    Цитата Сообщение от unbeliever Посмотреть сообщение
    please feed us a links to articles about 1541 usage as additional CPU or exact cases (demo examples) where this power was used?
    Krill/Plush gave me some examples:
    The first 2 parts of Panta Rhei
    Many parts of Digital World
    The last part of The Masque
    The last part of +H2K
    He also says: "I can supply much technical info if needed, i have coded some of the stuff above, and analyzed the rest.. "
    So I'll send him a link to this thread, maybe he can elaborate and answer more of your questions
  5. #135
    чайковский
    в продолжении темы про фоновую загрузку с диска в unreal by ksa.
    сегодня поглядел ее на реале. да, все честно! все тесты, что провел об этом говорят. как только встанет вопрос делать что-нибудь на эту тему будет повод забраться в код. пока, поставил себе галочку с направлением в котором стоит поработать особенно учитывая то, что как оказалось не часто раньше заглядывали за этот "забор"...
    сам метод не плох, а сама дема затянута не столько даже нестандартной загрузкой, сколько приветами и излюбленным атрибутом того времени - бегушкой. что улучшать тоже очевидно - сектор длиной в 128 байт, например, никто не отменял...
    так что спасибо psb за наводку, думаю, поднятая тема еще пригодится.
    http://speccy-live.untergrund.net fresh speccy news
    profi512+ym+5,25"+3,5"
  6. #136
    Miass, Chelyabinsk region
    ну вообще это не очень гуд... в плане переноса между дискетами и эмулем. да и вообще. имхо чисто мелкий сектор не очень повлияет на ситуацию, я когда был маленький, я это пробовал нужен продуманный лоадер.
    еще стоит, наверное, обратить внимание на оригинальный Spectrum Expert #2. опять же, я его не ковырял, но все похоже на то, что там хитрый лоадер там свой формат диска, когда у каждого сектора по два заголовка. и сам сектор в 512 байт. грузится много данных и быстро, под музыку. так вот у меня предположение, что прерывания при загрузке запрещены (ну или как-то хитро быстро обрабатываются), и для синхронизации проигрывания музыки используется факт, что 1 сектор грузится примерно одно прерывание. а 2й заголовок используется чтобы узнать, какой сейчас реально пойдет сектор.
  7. #136
  8. #137
    Рязань
    Я в древние времена писал прогу CacheVox, которая играла музыку на ковоксе, грузя её параллельно с дискеты. Для работы требуется кэш. Тайминги были рассчитаны с точностью до такта. Но если цифровую музыку не играть, то нет проблем.
    По поводу ширины мультиколоров - можно рисовать под 8x1, потом подкорректировать, чтобы не более 8 пар байтов менялось каждую строку. В редакторе нужны для этого индикаторы.
    Для мультиколоров под фирменные машины:
    поскольку запись выравнивается на 8-й такт, то ld hl,..:ld (..),hl будет 32 такта (10+(16+5)+1) вместо 26
    можно делать так:
    ld bc,... ;10
    ld de,... ;10
    ld hl,... ;10
    ld ix,... ;14
    ld sp,... ;10
    push ix ;15+1
    push hl ;11+5
    push de ;11+5
    push bc ;11+5
    Это 118 тактов, т.е. (считая с ld hl,...) весь экран по ширине.
    Остальные записи не тормозятся: 4*26=104 или 10+4*21=94
    итого 222 такта или 212.
    Хотя это сферический случай в вукууме, не вижу проблем для вообще. Учитывая, что 2 верхних строки каждого знакоместа можно подготовить заранее, а остальные рисовать, чуть превышая заветные 224 такта (или сколько там).
  9. #138
    чайковский
    жуть, что уже народ в причину в наши дни ставит! ужас... для мулей если этим вообще заниматься есть ряд способов, на худой конец, всегда из релиза можно сделать тоже самое, что сделали phg со 2м спекструм экспертом лежащим на зхдарю ...эмуляторщикам все равно.
    блин и ты туда же, это всего лишь еще одно перепрочтение мультилоадера, в анриле же мы имеем совсем другое - фоновую загрузку (если ее можно так назвать).
    Цитата Сообщение от alone Посмотреть сообщение
    сферический случай в вакууме
    если, пока считать простым делением времени загрузки более короткого сектора на 2, получаем меньшие затраты времени во фрейм на чтение данных. разве нет? ну конечно на практике получится скажем делением на 1.8 скажем, но все равно такты то сэкономим...
    спасибо. сектора стандартные? ну и коротко об основных особенностях тогда бы написал, чисто для истории...
    только ты еще забыл кое-что рассказать. что скажем на первой строке знакоместа мы можем получить 8х1 любые 8 пар, а вот для второй строки и последующей уже не все так радужно - либо продолжать в такой же конфигурации пар, либо сколько то продолжать, а для скольки-то пар (но тоже достаточно жестко) изменить положение - хотел сказать только одно - если, рассматривать строку знакомест вертикально, то способ не дает даже в ней свободы пускай для 8 пар 8х1 при том, что вся остальная картинка будет простой гигой 8х8, так что не знаю кому нужен такой самокат... в дему?! да, пожалуйста!! а вот специальный режим под это дело городить! я бы не стал.
    видимо останусь при своих иллюзиях (насчет фоновой загрузки), которые со временем скорее всего попробую воплотить в жизнь. остальных (в погоне за 8х1 фулскрин) мне видимо не переубедить... ищите. и кто знает... только так на секундочку не забывайте про то что у нас уже есть. и попробуйте это использовать!! а то я что то не наблюдаю особого ажиотажа вокруг 8х2, а между прочим зря.
    Последний раз редактировалось pulsar; 18.09.2009 в 09:52.
  10. #139
    если ты подумал, что это только из-за мулей - зря. я когда делал R.A.P., тоже хотел сделать все со стандартным тр-дос форматом, ибо так проблем меньше, и пусть даже меньше влазит. и я бы так и оставил, если бы не низкий поток данных, т.е. просто пришлось менять формат, а то даже на 11025 Гц не хватало.
    просто подумай о людях, на сколько им легко будет с твоей работой. а выгоды тем временем не много.
    крякнуть? это не есть гуд.
    я не очень понял, что ты хотел сказать. так-то я намекал, что хитрые лоадеры появились еще в том веке не мы первые...
    да и в чем глобальное различие между всеми этими лоадерами? нет различия... те же самые процедуры просто в разном порядке. что ты видишь волшебного в "фоновой загрузке" я вообще не понимаю. этой идее уже более 15 лет. скролл с музыкой во время загрузки - это та же демо с загрузкой, просто эффект простой.
    не совсем. подумай про эффект стробоскопа, здесь он мешает. конечно, если ты сделаешь по 2 заголовка у секторов, то это сильнее поможет.
  11. #140
    Novomoskovsk
    Smile Image Viewer v.0.0.1
    Откопал у себя на диске наброски своего графического просмотрщика, ничего особенного не умеет, показывает обычные картинки, монохромные и цветные gigascreen. Тип режима определяется по размеру файла, и, вроде бы, по расширению. Цветной гигаскрин показывает всегда черезстрочно, в монохромном есть несколько режимов. Тайминги для цветного гигаскрина рассчитаны под Pentagon.
    -[Disk Options]------------------------------------------------
    [] - Cursor Up/Cursor Down
    [Enter] - Load file
    -[View Mode]---------------------------------------------------
    В режиме просмотра монохромных изображений
    [1] - маска конвертирования, изменяется циклически:
    1бит - 2бита - 4 бита
    [2] - построчное конвертирование.
    [3] - восстановление оригинального изображения.
    [s] - сохранение экранов в текущем режиме, в одном файле
    [d] - сохранение экранов в текущем режиме, в двух файлах
    [i] - выбор ink для 2 экранов, изменяется циклически
    [p] - выбор paper для 2 экранов, изменяется циклически
    [Enter] - переход в каталог
    контроля на совпадение имен нет, сохранение всегда происходит
    под одним и тем же именем scr_0/scr_1, при сохранении в виде
    отдельных файлов, и img, при сохранении в виде одного файла.
    Была идея на базе этого просмотрщика написать party viewer, чтобы все по-взрослому , с ini-файлом. Пока все заглохно на стадии написания парсера
    P.S. Только сейчас обратил внимание, что исходник последний раз редактировался в 2004 году, мда, как быстро время летит
    • Тип файла: zip Img001.zip (74.9 Кб, Просмотров: 190)
    Последний раз редактировалось rajdee; 18.09.2009 в 14:06.
  1. Hackers Top 2009 SE
    от breeze в разделе События
    Ответов: 46
    Последнее: 06.08.2012, 01:09
  2. СИСОПНИК-1/2009 (МАЙ)
    от STS в разделе События
    Ответов: 129
    Последнее: 27.08.2009, 15:28
  3. Sundown 2007 zx demos
    от diver в разделе События
    Ответов: 26
    Последнее: 27.10.2007, 11:54
  4. Sundown 2007 1kb invitro by ate bit
    от kyv в разделе Демо
    Ответов: 21
    Последнее: 22.05.2007, 22:11
  5. Sundown 2006 zx-demo
    от psndcj в разделе Демо
    Последнее: 04.03.2007, 11:21
Метки этой темы
