Показано с 1 по 3 из 3
Тема: Video Connector - /C1_Clock_Out Pin15 какой частоты клок ???
    По умолчанию Video Connector - /C1_Clock_Out Pin15 какой частоты клок ???
    САБЖ однако .
    Вроде где то видел описание но чёто отрыть не могу .
    Колпино
    Вот что нашел:
    Цитата Сообщение от http://www.thule.no/haynie/research/a3000p/docs/a3000p.pdf
    5.3.2 Clock Signals
    These are various clock signals useful for synchronous timing of video peripherals.
    /C1 Clock
    This is a 3.58 MHz clock (3.55 MHz on PAL systems) that’s synched to the falling edge
    of the 7M system clock. Also known as /CCK in some places.
    /C3 Clock
    This is a 3.58 MHz clock (3.55 MHz on PAL systems) that’s synched to the rising edge
    of the 7M system clock. Also known as /CCKQ in some places.
    /C4 Clock
    of the 7M CDAC clock.
    CDAC Clock
    This is a 7.16 MHz clock (7.09 MHz on PAL systems) that trails the 7M system clock by
    90°.
    C28O Clock
    This is a 28.64MHz clock (28.36MHz on PAL systems) that’s synchonized to the digital
    RBG bus.
    Timer Time Base (TBASE)
    This is the real time clock time-base input, either 50Hz or 60Hz depending on the country
    involved and the setting of the Time Base Jumper. The jumper can select either line frequency
    or vertical synchronization as the clock’s time base.
    External Clock (XCLK, /XCLKEN)
    The video slot provides for an external system clock, generally used to cause the entire
    A2000 system to become synchronized to something external. This should be something very close to the 28.64 MHz clock normally used to drive the system; the value used for XCLK can be
    a somewhat higher frequency, though anything too high will cause memory and other system
    timings to break down. XCLK will only be engaged as the system clock when /XCLKEN is
    asserted. There is no fixed phase relationship between XCLK and the internal clocks and video
    output; C28O can always be used for pixel clocking.
    Это из "The Amiga 3000+ System Specification".
    Еще по A2000 нашел документ, но там тоже самое.
    ZX Spectrum forever!
    10X!!! То что надо .
  1. ZX+S-Video
    от Bear в разделе Изображение
    Последнее: 20.09.2009, 03:04
  2. Замена диода турбы на индикатор тактовой частоты ПЦ.
    от harushima в разделе Несортированное железо
    Последнее: 28.12.2007, 16:00
  3. Ответов: 16
    Последнее: 14.03.2007, 05:35
  4. RGB-video.
    от Dendy в разделе Изображение
    Ответов: 30
    Последнее: 21.03.2006, 13:10
  5. more new (?) video
    от kas1e в разделе Пресса
    Последнее: 11.09.2005, 23:53
