Показано с 1 по 4 из 4
Тема: ZX PROFI - memory paging
    Praha
    34
    15 сообщений
    По умолчанию ZX PROFI - memory paging
    What paging ports is used in ZX PROFI ?
    Port 7FFD select only 8 pages (128kB block)
    and DFFD select one of 8 memory blocks in 1MB ram.
    ZX PROFI also support memory paging in adress space 32768-49151 ?
    Exist any info about it ?
    What about allram mode and paging in low 16kB ?
    S.Pb
    yes
    91
    54 сообщений
    port dffd:
    bit0 - bit2 = number of project page
    bit3 = for change window of memory
    0 = win_1 (c000-ffff)
    1 = win_2 (4000-7fff)
    bit4 = if 0, then 7ffd is block off and ROM off. in memory 0000 - 3fff is RAM page. win_0.
    bit5 = if set in 1 and "ROM14 (bit4 of 7ffd port) = 0, then access WG93 from all memory (0000 - ffff). If ROM14 set to 1, then access to ext memory is change (change hardware acces...new some ports)
    bit6 = if set to 1, then ext screen is set in memory area 8000 - bfff. page 6 only (screen). but attributes is stand in 3a page and access from c000 or 4000 (see for bit3).
    bit7 = is set to 1, then work ext screen. page 04 = screen0 and page 38 is attr. page 06 screen1 and page 3a is attr.
    you can download profi 3+ schematic and see for all. use translators for translate to eng...
    ---------- Post added at 23:07 ---------- Previous post was at 23:05 ----------
    yes
    only page 6 (screen), if bit6 = 1. else - 8000 - bfff is not set as window for pages...
    0A заповедей:
    I. Не удаляй каталог свой.
    III. Не кради файлы.
    Sprinter resurrect:
    Telegram
    Discord
    Repo
    Forum
    S.Pb
    Sayman, VELESOFT судя по всему спрашивал про программную совместимость с ZX режимом.. Profi CP/M им, западникам, скорее всего и даром не надо..
    Вот, наиболее грамотно составленное руководство по программированию #DFFD (намного лучше чем оригинальная инструкция к Profi ):
                  READ                               WRITE
    #DFFD/57341 Profi EXPANDED MEMORY PORT
    D0 -                                    D0 CPU3/1 A17'RAM
                                            D1 CPU3/1 A18'RAM
                                            D2 CPU3/1 A19'RAM
    D1 -                                    D3 WindowPageSelect:0-CPU3,1-CPU1
                                            D4 1-blkD5#7FFD & RAM0>CPU0
                                            D5 Device modify mode:0-ZX,1-CP/M
    D2 -                                    D5|D4#7FFD
                                             0| x IOTRDOS&TRDOSROM or IOZX-on
                                             1| 0 IOTRDOS-on,IOZX&TRDOSROM-off
    D3 -                                     1| 1 IOZX-on,IOTRDOS&TRDOSROM-off
                                            D6 Screen mode:0-ZX,1-CP/M
    D4 -                                    D6|D3#7FFD
                                             0| 0 RAM5>CPU1
                                             0| 1 RAM7>CPU1
    D5 -                                     1| 0 RAM4>CPU2
                                             1| 1 RAM6>CPU2
    D6 -                                    D7 Video mode:0-ZX,1-CP/M
                                            D7|D5#7FFD
                                             0| x 256x192 ZX
                                             1| 0 512x240 CP/M
    D7 -                                     1| 1 512x240 CP/M & wrShadowPalette
    Последний раз редактировалось Black_Cat; 06.11.2009 в 21:41.
  1. MEMORY PAGING IN LOW 16kB
    от VELESOFT в разделе Память
    Последнее: 04.04.2015, 13:36
  2. Extended memory and SNApshots in emulators
    от VELESOFT в разделе Эмуляторы
    Последнее: 01.09.2009, 22:41
  3. External memory upgrade for ZX16/48
    от VELESOFT в разделе Несортированное железо
    Последнее: 26.01.2009, 19:30
  4. BASIC + Paged memory
    от valker в разделе Программирование
    Последнее: 15.05.2007, 14:17
  5. Contended memory /Медленная память/ на Original Speccy
    от MadCat! в разделе Программирование
    Ответов: 15
    Последнее: 05.03.2005, 11:18
