Mad Killer/PG, поздравляю!С64 рулез! Теперь самое время погонять демки на нём, или послушать музычки
С уважением, Александр.
SID-Blaster/ZX
Ну что... Принимайте в клуб свидетелей черного экрана. Состояние идеальное, в коробке с мануалами. Поломался, похоже, давно - хозяин спрятал подальше... и надолго. Без СИДа не включается так же. Через модулятор - такой же черный экран, как и через A/V Ничего, кроме ПЛМ и VIC не греется особо - но для них это норма. Вобсчем, занятие себе таки нашел... Пока пойду по этому гайду, дальше - видно будет... Возможно, придется воспользоваться этим http://www.cbmitapages.it/tecnico/plaeng.htm
Код:C64 BLANK SCREEN Latest updates and corrections 11-20-07 Blank screen is the most common symptom, and a failing PLA chip is the most common reason in the early version C64. However, quite a few other failures can cause it as well, such as a bad power supply (check with a known good substitute), bad RAM chip(s), and in general, just about any other chip in there because many chips share multiple data lines. If any one of those lines is loaded down or missing a signal for whatever reason, it can produce that symptom. Fortunately, most of the time, the same few ICs are the cause of the blank screen symptom, so that narrows the search down a bit. You start with the statisticlly most common failures are work your way down. There are a few tests you can run to determine what the problem is. At a minimum, you will need a supply of known good replacement chips, some skill with a volt-ohm meter and a soldering iron. Repair is mostly educated guesswork and trial and error to see what works and what doesn't as you go along. Turn the computer off and back on rapidly about five times. If the screen ever comes up with flashing colors or all one color, the PLA is suspect. Replace it to check. Try a game cartridge. Some carts will essentially "replace" some of the chips in the computer when the game runs. If a cart works, check the ROMs. The screen can have a normal border even if the CHARacter or BASIC ROMs are bad. A bad Kernal ROM will show no border but a few game carts bypass the Kernal. Commodore Kickman and Jupiter Lander are the only two I have that work with a missing or bad Kernal ROM. I once repaired a C64 with one bad RAM chip, U10 on a 250425 board. The symptom was a blank screen. Remembering that some game cartridges would work with a bad Kernal, I tried a cartridge and the computer produced a garbled game screen. After swapping out the PLA and the Kernal without success, I tried the RAM "piggyback" trick (explained in detail later) with the cart plugged in and got the game screen with U10 piggybacked. I then got a normal boot screen after that RAM chip was replaced. The internal RF unit outputs a signal that goes to the antenna input of your TV. If the picture is snowy, suspect the RF modulator, or bad cabling (switchbox, adaptor, etc.) to the TV. If the computer is "dead" but is getting its +5VDC source from the power supply (red LED on), the PS 9VAC source may be missing. If so, the modulator will produce a black screen... darker than the blank screen of a failing chip in the computer. Loss of 9VAC can be a bad PS or blown fuse in the computer. See if any of the RAM chips (there are eight of them) get warm or hot... feel each one with the back of your finger after the computer has run for about 5 minutes. Shorted chips will get hotter than the others. Note: bad RAM doesn't always get hot. See if the computer resets the other components in the system like the drive and/or printer. If so, try a "blind" disk command and see if the drive responds. Try formatting a disk. If that works, you may have a bad VIC chip (no screen display). Sometimes a bad SID chip will produce a blank screen... pull it out and try the computer. It will boot without it, although you will have no sound, and a proportional mouse will not work. The few large chips that normally run hot have a high failure rate: in rough order... the PLA, SID, MPU and the VIC. Static zaps usually take out chips like the CIAs because those ICs are directly connected to the external ports. A shorted CIA can produce a blank screen. You will get a startup screen with the CIA's removed but you will have no cursor without U1 (keyboard interface) plugged in. You can use that as a diagnostic. The smaller so-called "glue logic" chips (TTL) run cool and are pretty rugged. Although they rarely fail, I've had a few repair jobs that drove me crazy by making me unsolder a dozen IC's until I found the bad one. Sometimes there is just no easy way. With the above noted exceptions, removing a chip will usually produce a blank screen. The only practical way to check chips is by substitution. The easiest way to do that is by inserting each suspected chip into a working computer that already has all chips socketed. You can chase your tail doing it the other way around, and you're really stuck if you end up having more than one bad IC. I made a test board for just that reason. Suspected chip(s) can be tested one at a time and only the bad ones need be replaced. At the very least, you need a source of known good chips for test purposes. Be careful... they are static sensitive. If you don't want to go to that much trouble to diagnose the problem, you will probably be better off hunting up another C64. Chips are hard to find and expensive. Keep a spare "breadbox" or two, even if only for parts. Salvage from used boards is all there is to keep our "obsolete" computers going. Ray Carlsen CARLSEN ELECTRONICS... a leader in trailing-edge technology.
creator
Ага, как по мурзилкеПровел экспресс-диагностику. PLA - под замену. Одновременно активны два CAS на двух ПЗУ (CHAR - постоянно в активном состоянии и Kernel - параллельно с ней на частоте 1MHz). Естественно, на ШД полный бардак. VIC, скорее всего живой. Еще есть подозрения по поводу дешифратора VIC<>SID<>COLOR - на одной из выходных линий просматривается 50Hz т.е. он, скорее всего, в обрыве. Ну что-ж - попробую 27C512 - там отзывы есть положительные.
Остановился пока на таком решении.
http://www.vic20.de/html/eprom_pla_8296_und_c64.html
Есть в загашниках "правильная" EPROM с подходящими таймингами, при использовании которой, судя по отзывам, нет риска спалить SID. FLASHки, как я понял, из-за более быстрых таймингов, дают конфликты на шине, что приводжит к перегреву SID, а решение с XILINX стоит столько же, сколько рабочая PLA из старых запасов. Кто-то уже пробовал варианты такой замены?
Я поступил по-крестьянски: купил еще одну машину в ЗИП.
C64C, TI-89
Снял PLA, прошил EPROM, сделал переходную панель. Комп заработал. При просмотре через модулятор есть небольшая помеха поверх изображения, а так, нормально. Так неохота плату опять в фольгу заворачивать (вся плата в корпусе была завернута в металлическую фольгу. Сверху - на картонной основе. С одной стороны - выше помехозащищенность. С другой - проблемы с охлаждением... А кто как с ней поступает?
Последний раз редактировалось Mx_Serg; 04.03.2017 в 20:10.
У меня B-3 версия платы - там сверху металлический лист, который "касается" горячих ИС. Для вашей версии, я видел, что люди просто радиаторы ставят, без всяких экранов.
Я видел несколько разобранных тушек - никакой фольги не было, все нужные компоненты уже ведь закрыты кожухами.
Нашел, что это, похоже, в каком-то регионе только было:
As said before, all that rf shielding like the cages and cardboard you're talking about was simply to make the machine part 15 compliant of FCC rules that were supposed to keep home electronics from leaking signals that can cause interference to radio or tv reception.
since the computer is not sold new in stores anymore, i second the notion for taking off the cardboard rf shield. I've seen the one you are talking about, its got a shiny side to it and paper on the other side. it looks like it would be more effective in evenly cooking popcorn in the microwave oven.
just throw it away.
Последний раз редактировалось vsnb; 05.03.2017 в 04:24.
C64C, TI-89
vsnb
Да, сомнительная польза от такого экрана...
Попробовал с C64 его родной VIC-1541 привод FDD. Работает без проблем. А вот SID все-таки глючит. Заказал у китайцев, благо стоит он недорого. Наклеил на EPROM распечатанную на принтере защитную полоску. Получилось оригинально.
С китайцами не вышло - начали темнить. Есть подозрение, что фуфломицин продают. Нормальные есть только в партиях от 10шт, что для меня дороговато. Если у кого есть проверенный лишний SID - велком в ЛС. Готов за него отдать 8у.е.+ доставка. Или возьму попозже за 15у.е. SwinSID - он, по крайней мере, не деградирует...
