Sinclairean is a new ZX Spectrum emulator written in machine code for x86-compatible, OpenGL-capable computers.
Features:
* Fast machine code performance
* Accurate and pleasant CRT display emulation
* Full screen mode without either artifacts or chunky pixels
* Smooth, stable screen updates and 50 Hz conversion
* Advanced development tools/display monitoring
* OpenGL display trickery and eye candy
Notice
The emulator is still in beta development stage, so your mileage may vary. Please take into account the following issues:
* It still depends on SDL (included)
* Z80 core is not 100% translated to machine code yet
* Windows is the only OS supported at this point
Usage
Sinclairean can be run either from Windows Explorer or from the command shell. A .sna or .tap file can be supplied as a command parameter, can be dragged-and-dropped onto the application's icon, or can be "Open With"-ed. Snapshots are executed instantaneously but tapes are just prepared; you'll still have to type LOAD "" to load'n'run the game
Keyboard controls:
* F1 Zoom screen in
* F2 Zoom screen out
* F3 Rotate screen anticlockwise
* F4 Rotate screen clockwise
* F5 Toggle CRT aperture grille emulation on/off
* F6 Cycle display modes (color, Melbourne Draw, inverse ink)
* F7 Pause/enter single frame step mode
* F8 Step 1 single frame
* F9 Toggle video character layer (forthcoming debugger/monitor) off/transparent/opaque
* F10 File requester (load): up/down arrow keys select file, page up/down advance one page, home/end go to start/end of directory, left arrow go to parent directory, F9 toggle transparency, enter load file or enter directory (VERY ALPHA: no filetype filtering, no error checking, incorrect default directory when started from Windows Explorer, etc, etc...)
* F11 Monitor/debugger (only a mockup, not yet implemented)
* F12 Reset
* Home Resets zoom/rotation and toggles between several display modes (FIT, GAME, FULL, FILL)
* Esc Quit
* Win+arrows Pan screen
* Win+keypad number Save an instant snapshot to a channel (0 to 9)
* Keypad number Switch channel (retrieve its snapshot, 0 to 9)
ссылка на автора - http://sinclairean.blogspot.com/
скачать - http://bit.ly/bJlHW1
Ответить с цитированием
