Показано с 1 по 3 из 3
Тема: ATM TURBO - RAM PAGING
    Praha
    34
    15 сообщений
    По умолчанию ATM TURBO - RAM PAGING
    I need access on ATM TURBO 2+ from ZX basic to system port #xx77, but writing to this port is dibable. Why ?
    I need switch ram pages in area #4000-#7FFF and #8000-#BFFF. But access to port #7FF7 and #BFF7 is ignored...
    Please help. Ideal with example.
    Praha
    34
    15 сообщений
    I test it in UNREAL SPECCY emulator.
    I am in ZX mode:
    1) push to stack adress for return
    2) push to stack adress of instruction OUT (C),A in TR-DOS rom
    3) set BC register to #0277 and register A to 0
    4) set 48 rom via paging port #7FFD
    5) CALL #3D2F
    After return are enabled all shadow ports for controll memory ports
    Is this correct ?
    http://atmturbo.nedopc.com/inf/books...c/atm_hard.zip
    CALL	SHADOW
    SHADOW	LD	BC,#2A53	; OUT (C),A in TR-DOS address space
    		PUSH	BC		; Putting on stack
    		LD	BC,#nnnn	; Address of the shadow port
    		LD	A,#nn	; Data to out
    		JP	#3D2F	; Jump to RET in TR-DOS space
    out #FFF7 = %xx11111111110111 (#3FF7,#7FF7,#BFF7,#FFF7)
    (A0=A2=A4=A7=1; A3=0)
    Bits description:
    D0–D5 – inverted page number, RAM or ROM (#00-#3F). If you want to setup page #05 (%00000101) then you should out its inverted value %11111010
    D6 – defines ROM or RAM page
    D6=0 – ROM page defined by bits D0-D5
    D6=1 – RAM page defined by bits D0-D5
    D7 – Defines what memory manager`s ports and bits are used to form page number
    D7=0 – Page number defined by port #xFF7 only
    D7=1 – Use not inverted bits D0-D2 of port #7FFd instead of inverted bits in port #xFF7 If RAM selected by D6: inverted bits D0-D2 replaced with not inverted bits of port #7FFD
    LD	A, #2B		;PAge number is 43 dec
    	PUSH	AF
    	SCF			;invert if for port #xFF7
    	AND	%11111000	;D7=1 – use port #7FFD
    	LD	BC, #FFF7	;window 3 (#C000)
    	OUT	(C), A	;set bits 3-5 of the page number
    	POP	AF		;restore page number
    	AND	%00000111	;cut off higher bits
    	LD	BC, #7FFD
    	OUT	(C), A	;set bits 0-2 of the page number
    <<cut>>
    Bits on address bus : A14-A15 - selects window in address space:
    A14 A15 window port
    0 0 #0000-#3FFF (port #3FF7)
    1 0 #4000-#7FFF (port #7FF7)
    0 1 #8000-#BFFF (port #BFF7)
    1 1 #C000-#FFFF (port #FFF7)
    P.S.: Fast and lazy translation after hard day...
  1. MEMORY PAGING IN LOW 16kB
    от VELESOFT в разделе Память
    Последнее: 04.04.2015, 13:36
  2. PAGING PORTS of ZX / CLONES
    Ответов: 42
    Последнее: 28.01.2013, 21:02
  3. ZX PROFI - memory paging
    от VELESOFT в разделе Profi
    Последнее: 06.11.2009, 20:08
  4. GRM и Turbo ВГ
    от roxx в разделе Несортированное железо
    Последнее: 13.08.2006, 22:26
