Показано с 1 по 9 из 9
Тема: New ideal firmware for ZX EVO board
    Praha
    34
    15 сообщений
    По умолчанию New ideal firmware for ZX EVO board
    All existing firmwares for ZX EVOLUTION board only copy architecture of Pentagon / Scorpion computers. But for FPGA can be writed better and more universal firmware.
    My idea:
    - unlimited memory paging (full 4MB) separate for each 16kB block in 64kB adress space. Block 0 (0-16383),block 1 (16384-32767),block 2 (32768-49151),block 3 (49152-65535).
    - Each block can contain any 16kB page of 4MB ram or 512kB rom. With this layout will easy realisable multitasking and allram modes.
    - Each block contain selectable write protect (for possibility enable writing to flash eprom or disable writing in ram page for possibility emulate rom in low 16kB)
    - Readable status of all used I/O ports (ula port #FE, paging ports, configuration ports, etc...)
    - possibility emulate ZX rom (48rom+128editor+gluk+tr-dos) in extended ram (very good feature for developing and testing new rom based software)
    - colour palette for all 16 ZX colours
    - better graphic modes (256x192/16 colours per pixel - with used palette). And for easy access to screen must be graphic area in ram as linear data block 24kB as on SAM COUPE. Each pixel = 4bits (1 byte = 2 pixels).
    - possibility emulate different ZX clones ( software selectable configuration - screen size, ula timing, etc.. = similar as in SPECCY CONFIGURATOR utility on SPRINTER 2000 ).
    - switchable memory size ( Pentagon 48, 128, 512, 1024, etc.. )
    - emulation of european devices as MB02+ or DIVIDE interface (for possibility use +D emulation, D80 emulation, MB02 emulation, access to FAT16/FAT32 via easy LOAD/SAVE routines in zx rom. Possibility load/save snapshots from/to hdd.
    - original ZX128 ULA timing (slow-down cpu for perfect 100% timing in games and demos).
    - faster mode than 7 MHz
    - Z80 CPU emulation in FPGA
    50 different firmwares are not so good as one universal firmware !
    Последний раз редактировалось VELESOFT; 18.08.2010 в 00:39.
    Днепропетровск
    18 сообщений
    Try to see on this project: http://zx.pk.ru/showthread.php?t=12425
    Praha
    34
    15 сообщений
    Yes, I know. Also Pentagon 2.666 emulate Z80 CPU in FPGA. But is it possible also in ZX EVO ?
    г. Луганск
    VELESOFT,вечный вопрос: " Что делать?" (с) Чернышевский , перефразирую - кто сделает? (с) я. идея то хорошая, по идее реализуемая в Speccy 2010. но... кто?
    55 сообщений
    No. low-level FPGA ("ACEX") do not have necessary amount cells for T80 softcore.
    ---------- Post added at 09:34 ---------- Previous post was at 07:57 ----------
    "globalization" in the Spectrum-world?
    Последний раз редактировалось Ewgeny7; 18.08.2010 в 07:59.
    50 different firmwares? Where can I see them?
    "Любое околокомпьютерное творчество одинаково сильно сопряжено с покупкой и воровством" dk_spb
    55 сообщений
    it's figuratively
    Praha
    34
    15 сообщений
    Screen timing switching between PENTAGON/SCORPION is easy. Emulaion of european devices is also very very easy. For example some of this features is realised in my PROFI INTERFACE in one small CPLD.
    http://velesoft.speccy.cz/profi/profi-firmware-1.htm
    DOCUMENTATION:
    http://velesoft.speccy.cz/profi/prof...ty_techman.zip
    S.Pb
    You're late, it's old ideas: http://zx.clan.su/forum/7-57-1
    Последний раз редактировалось Black_Cat; 18.08.2010 в 15:34.
  1. Ultimate upgrade board. Есть ли?
    от Surfin_Bird в разделе Несортированное железо
    Ответов: 28
    Последнее: 06.08.2009, 23:42
  2. Project two: The Most Sexual Board
    от sq/skrju в разделе События
    Последнее: 19.03.2008, 17:13
  3. Insert Board( SoC)
    от andrews в разделе Несортированное железо
    Ответов: 22
    Последнее: 24.07.2006, 21:41
  4. Firmware для Спектрума
    от CityAceE в разделе Оси
    Ответов: 30
    Последнее: 25.07.2005, 10:14
