Страница 2 из 23 ПерваяПервая 123456 ... ПоследняяПоследняя
Показано с 11 по 20 из 223
Тема: Эмулятор Atari
    Днепропетровск
    Аtari800Win Мне больше нравится,
    А Hatari сильно глючный.
  2. #12
    Омск
    46
    32 сообщений
    обновился лучший эмулятор атари 8 бит и 5200, Altirra.
    список изменений по сравнению с предыдущими версиями просто огромный.
    Altirra 1.8.
    Version 1.8 [December 22, 2010]:
    [features added]
    * Initial 5200 support.
    * Simulator: Added 16K memory size support.
    * Simulator: 576K and 1088K modes now allow ANTIC access to extended memory.
    * Simulator: ROM image paths are now configurable.
    * Cartridge: Added support for Corina 1MB + 8K EEPROM and 512K + 512K SRAM + 8K EEPROM cartridges.
    * Cartridge: Added support for Telelink II NVSRAM.
    * Cartridge: Added support for DB 32K, Williams 32K / 64K, Diamond 64K, SpartaDOS X 64K/128K, Phoenix 8K, Blizzard 16K, and Atrax 128K cartridges.
    * Cartridge: Added support for 8K right slot cartridges.
    * Cartridge: Added support for non-switchable 256K-1M XEGS cartridges.
    * Cartridge: Mapper dialog attempts to detect Atari 2600 cartridge images (unsupported).
    * Debugger: The history window no longer needs to be closed and reopened after toggling history mode.
    * Debugger: Source windows now highlight lines that have symbol information associated and can be used for execution control.
    * Debugger: Added on-screen watch byte/word commands (wb/ww/wc/wl).
    * Debugger: History window now detects and collapses loops.
    * Debugger: Added optional length parameter for dump and disassemble commands.
    * Debugger: Added dump INTERNAL string command (di).
    * Debugger: Added .iocb command.
    * Debugger: Added ya/yc/yd/yr/yw commands for manually adding symbols.
    * Debugger: Verifier now detects recursive NMIs.
    * Debugger: Font and font size can now be changed.
    * Debugger: Added 6502 miniassembler.
    * Debugger: Added detailed command help.
    * Debugger: Added .pathrecord command and documented existing path commands.
    * Debugger: Added .basic and .basic_vars commands.
    * Debugger: Console window now supports multiple history entries and page up/down from the command line.
    * Debugger: Added symbol parsing support for ATasm and XASM assembler output.
    * Disk: Added support for D9: through D15:.
    * UI: Added DirectSound support.
    * UI: Audio latency can now be adjusted.
    * UI: Switched to larger font for on-screen UI.
    * UI: Shift key now controls whether dropped files are mounted/added (shift) or booted (no shift).
    * UI: Left-shift and right-shift keys can now be bound separately.
    * UI: Warnings are now displayed before modified images are implicitly discarded.
    * UI: Enabled themed controls.
    * UI: Removed borders on docked panes.
    * UI: Added first pass at pause button (F9).
    * UI: Ctrl+Arrow keys now give the un-Ctrl'd keys on the emulated keyboard for programs that use pseudo arrow keys.
    * UI: Mouse auto-capture is now an option.
    * UI: Added option to resize main window to remove letterboxing on display.
    * Input: Input map editor redesigned for easier controller configuration.
    * Input: Input maps now support shifted subsets via flags.
    * Input: Analog axes can now be bound as either relative or absolute, with tunable speed for relative mode.
    * Input: Paddles now support rotation-based control.
    * Input: Added light pen/gun support.
    * Input: Added tablet support.
    * VBXE: 5200 support added.
    * IDE: Added option to switch between short and long BSY-to-DRQ delays to simulate platter and solid-state media.
    * Serial: Added support for 850 R: and basic virtual-modem-over-TCP emulation.
    * Cheats: Added simple cheat finder and value locker.
    * Recording: Added options to tweak the frame rate and to record at half rate.
    [bugs fixed]
    * Disk: Added workaround for yet another goofy way to store boot sectors in a DD ATR image (3 x 128K followed by 384K of nulls).
    * Disk: Fixed crash when opening .zip file containing files with no filename extension.
    * Disk: Disk drives dialog now highlights disk images that have been modified and not saved.
    * IDE: Fixed excessively long delay for BSY to assert after a command is issued.
    * Input: Binding mouse up/down/left/right outputs to digital inputs now works.
    * UI: Fix for crash when using Direct3D display on video cards that don't support arbitrary non-pow2 textures.
    * UI: Rewrote audio output path to use block duplication/removal rather than resampling to maintain sync.
    * UI: Fixed emulated mouse button not working reliably.
    * UI: Reduced border artifacts when using bicubic display stretching.
    * UI: Fixed crosstalk between interlace and frame blending settings.
    * PIA: Control bits 6 and 7 are no longer writable.
    * POKEY: Fixed RANDOM offset in 17-bit noise generator mode.
    * POKEY: Fixed IRQ timing for CPU-triggered IRQs.
    * POKEY: Fixed serial output complete interrupt not always deactivating properly.
    * POKEY: Clearing SKCTL bit 1 now disables the keyboard.
    * POKEY: Adjusted timing of 15KHz and 64KHz timers after exiting initializing mode.
    * GTIA: Phantom P/M graphics DMA is now implemented.
    * GTIA: Fixed graphic output when changing the size in the middle of a player image.
    * GTIA: Improved accuracy of graphic output when changing GTIA modes mid-screen.
    * GTIA: Latched triggers are now implemented.
    * HLE: Delete line ($9C) now resets cursor column.
    * HLE: Implemented CRSINH function.
    * HLE: IRQ handler now clears decimal flag.
    * HLE: Fixed crash when jumping to cassette init routine.
    * Debugger: Fixed MADS listing parsing for code lines after ORG statements.
    * Debugger: .dumpdsm command works again.
    * Debugger: History window now shows effective addresses.
    * Debugger: Disassembly and history windows now allow disassembly columns to be toggled.
    * Debugger: Stepping in source view now steps by source line instead of instruction.
    * Debugger: Fixed uninitialized screen data sometimes appearing when stepping.
    * Debugger: Register "r" command can now set A register.
    * Debugger: Breakpoints now work on the run address of a loaded executable.
    * Debugger: Fixed .writemem crashing if filename was invalid.
    * CPU: Fixed IRQ timing around CLI and SEI instructions.
    * CPU: Fixed a couple of bugs with decimal mode.
    * CPU: Taken branches now delay IRQ/NMI acknowledgement by one cycle.
    * CPU: Fixed false read behavior for: STA (zp),Y; STA abs,Y; STA abs,X; STX abs,Y.
    * CPU: Implemented reserved NOPs in 65C02 mode.
    * CPU: Fixes to undocumented opcodes: RLA ($23, $27, $2F, $33, $37, $3B, $3F); ASR ($4B); SAX ($83, $87, $8F, $97); SHX ($9E).
    * ANTIC: Fixed occasional unexpected DLIs on cold reset, which was causing once-only emulation crashes.
    * ANTIC: Corrected NMIST change timing.
    * Cartridge: Fixed OSS 034M and M091 mappers.
    * Recording: Fixed crashes in some cases when recording start process failed.
    * VBXE: Attribute map RES bit is now implemented.
    * VBXE: Fixed attribute map addressing getting scrambled on mid-screen changes.
    * VBXE: Overlay scrolling and addressing is now reset at VBL and no longer affects bitmap modes.
    * VBXE: Frame blending is now supported in VBXE mode.
    из интересного:
    - добавлена полная эмуляция Atari 5200.
    - добавлены все типы контроллеров (light gun, light pen, mouse, koala pad, atari touch tabblet....) за исключением пожалуй только трэк-бала.
    - добавлена система поиска чит-кодов.
    - настройка клавиш и контролерров стала во много раз проще и удобней.
    - добевлены все известные мапперы картриджей.
    - эмуляция Right slot cartridge.
    - R-device модем.
    - сильно улучшен дебагер.
    - добавлен подробный Help по эмулятору.
    и много, много чего ещё.
    http://virtualdub.org/downloads/Altirra-1.8.zip
    http://virtualdub.org/downloads/Altirra-1.8-src.zip
    чтобы было проще я выкладываю здесь файл своих настроек и биосы для эмулятора, всё это нужно распаковать в папку эмулятора.
    Последний раз редактировалось ZEman; 04.01.2011 в 18:11.
  3. #13
    Омск
    46
    32 сообщений
    http://www.virtualdub.org/beta/Altirra-1.9-test3.zip
    самый новый на сегодня бета-билд эмулятора altirra.
    из нового добавлена поддержка Soundboard (ABXE).
    также добавлено меню помогающее устранять ошибки при крахе эмулятора.
    что такое Soundboard (ABXE) ?
    не так давно умельцы с сайта atariage смогли присоеденить к атари звуковую карту, что дало более мощный и качественный звук (можно сравнить с GS на спеки).
    подробней можно прочитать здесь:
    http://www.atariage.com/forums/topic...page__hl__ABXE
    что требуется для работы ABXE в эмуляторе altirra 1.9 test 3 ?
    для начала придётся скачать архив с софтом для abxe
    http://rapidshare.com/files/440703488/abxe.rar
    потом добавьте в корень эмулятора файлы биосов.
    и положите в папку эмулятора мой файл настроек (смотрите вложение).
    запустив эмулятор выставите опции
    System ----> Soundboard ----> Enabled
    и
    System ----> Soundboard ----> Use $D600-D6FF
    убедитесь что у вас включена настройка
    System ----> Disk Drive ----> Burst (polled / SDX compatible).
    откройте картридж "SDX442_SDX128.ROM" из папки abxe,
    File ----> Attach cartridge ---->
    при открытии картриджа укажите тип маппера как SpartaDOS X 128K.
    дождитесь окончания загрузки доса (процесс можно ускорить нажав F1).
    откройте диск "neoplay.atr" из папки abxe.
    File ----> Open Image ---->
    ни в коем случае не открывать через boot image !
    набрать команду dir
    вы увидите список файлов находящихся на диске.
    файлы имеющие расширение .neo это и есть музыка.
    открываем их следующим образом:
    набрать
    neoplay [пробел] [имя файла] [.neo]
    скобки ставить не надо, у вас должно получиться допустим:
    neoplay ending.neo
    нажмёте enter, дождётесь загрузки мелодии и можно слушать.
    нажав кнопку escape вернётесь назад в дос и можно выбирать любую другую мелодию.
    Последний раз редактировалось ZEman; 27.01.2011 в 11:44.
  4. #14
    г. Кирово - Чепецк
    12
    8 сообщений
    Нет такой вкладки Soundboard.
  5. #15
    Омск
    46
    32 сообщений
    atariki,
    у вас проблемы со зрением ?
    http://img529.imageshack_.us/img529/7808/soundyu.jpg
    в продолжение темы:
    новая бета эмулятора altirra.
    http://www.virtualdub.org/beta/Altirra-1.9-test11.zip
    из особо интересного:
    добавлены особености PAL видео режима, палитра теперь как на настоящем атари, чем не может похвастаться ни один из существующих ныне эмуляторов atari 8 bit.
    (смотреть в опциях System ---> Video ---> adjust colors включить опцию Use PAL quirks).
    добавлен фильтр PAL artifacting high.
    добавлены устройства Amiga mouse и СХ85 numeric keypad.
    добавлен audio monitor.
    много фиксов.
    к эмулятору прилагаю обновлённый мой файл настроек и биосы.
    Последний раз редактировалось ZEman; 05.02.2011 в 05:02.
  6. #16
    г. Кирово - Чепецк
    12
    8 сообщений
    не, проблема только с одним глазом. Просто версия старая, незнал. Спасибо. Всё играет.
    ATARI 65XE|130XE|XEGS|4-XC12|(2-TURBO2000)|SIO2SD
  7. #16
  8. #17
    Омск
    46
    32 сообщений
    обращайтесь если что заинтересует или будет непонятно, всегда буду рад помочь
  9. #18
    г. Кирово - Чепецк
    12
    8 сообщений
    Я так понимаю на реальном atari этот номер не пройдет ?
  10. #19
    Омск
    46
    32 сообщений
    что вы имеете ввиду, soundboard ?
    вообщето soundboard существует в реальности, её изобрели для атари совсем недавно месяца полтора два назад, и по крайней мере 2 - 3 пользователя имеют этот девайс.
    подробности можно прочитать здесь:
  11. #20
    г. Кирово - Чепецк
    12
    8 сообщений
    Да, я так понимаю надо паять схему ? Просто в англ не очень силён
  1. Винтажный дисковод-atari+мафон-atari
    от doc11 в разделе Барахолка (архив)
    Последнее: 15.07.2010, 10:00
  2. Продажа ATARI 65XE ATARI 2600 Sega MegaDrive
    от Zloy в разделе Барахолка (архив)
    Ответов: 69
    Последнее: 05.06.2010, 15:08
  3. [Питер] Продам Atari 65 XE, магнитофон Atari XC12
    Последнее: 05.02.2010, 11:48
  4. Продам в Питере Atari 65XL + Atari STe
    от scald-spb в разделе Барахолка (архив)
    Последнее: 26.08.2008, 10:28
  5. эмулятор ZX Spectrum на Atari XL?
    от [bETA]mEN в разделе Atari
    Последнее: 09.12.2007, 22:51
