Я думаю form всё разъяснит, сам я не могу точно сказать что к чему.
SPDCPU видимо считает время выполнения инструкций, сейчас соберу, посмотрю. Остальные должны в RT собираться.
---------- Post added at 02:44 ---------- Previous post was at 02:41 ----------
Не сильно информативно
>FLX /RS/FA=DU3:SPDCPU.MAC/RT:5
>DCL MAC SPDCPU
>DCL L SPDCPU
>RUN SPDCPU
31250   Instructions per loop.
320     Passes through loop.
TST      Instruction
17-MAR-14 02:41:50.1 started
17-MAR-14 02:41:56.3 ended
ROR      Instruction
17-MAR-14 02:41:56.5 started
17-MAR-14 02:42:02.7 ended
SWAB     Instruction
17-MAR-14 02:42:02.9 started
17-MAR-14 02:42:09.1 ended
MOV      Instruction
17-MAR-14 02:42:09.3 started
17-MAR-14 02:42:15.5 ended
MOVB     Instruction
17-MAR-14 02:42:15.7 started
17-MAR-14 02:42:21.9 ended
CMP      Instruction
17-MAR-14 02:42:22.1 started
17-MAR-14 02:42:28.3 ended
ADD      Instruction
17-MAR-14 02:42:28.5 started
17-MAR-14 02:42:34.8 ended
BIT      Instruction
17-MAR-14 02:42:34.9 started
17-MAR-14 02:42:41.2 ended
TST 1    Instruction
17-MAR-14 02:42:41.4 started
17-MAR-14 02:42:52.1 ended
CMP 1    Instruction
17-MAR-14 02:42:52.3 started
17-MAR-14 02:43:09.8 ended
MOV 42   Instruction
MCR>ABO
 17-MAR-14 02:43:10.0 started
17-MAR-14 02:43:30.3 ended
Program ends.
---------- Post added at 02:51 ---------- Previous post was at 02:44 ----------
ASHTST видимо проверяет ошибки ASH/ASHC (сдвиг влево на 31 итд)...
.RU ASHTST
Testing ASH operation...  ASH  (R1),R2
                       (R1)   PSW    R2
Initial  values are:   177737 000017 177777
Correct returns are:   177737 000006 000000
Expected values are:   177737 000006 000000
Returned values were:  177737 000006 000000
The PSW and results are correct!!
This CPU's returns and PSW matches a new style J11!!
Testing ASHC operation..  ASHC (R1),R2
                       (R1)   PSW    R2     R3
Initial  values are:   177737 000017 177777 177774
Correct returns are:   177737 000006 000000 000000
Expected values are:   177737 000006 000000 000000
Returned values were:  177737 000006 000000 000000
