Показано с 1 по 9 из 9
Тема: TFM Music Maker
    Khimki
    15 сообщений
    По умолчанию TFM Music Maker
    Обновился этот редактор для TSFM до версии 1.5, а также вышел новый плагин для WinAmp. Внимательно читаем одноимённые абзацы на сайте автора - Shiru. Там-же и скачиваем.
    13.06.11 - TFM Music Maker v1.5, TFM Music Player plug-in for WinAmp v1.21
    http://shiru.untergrund.net/software.shtml
    Изменения:
    + SMPS instruments format support
    + Exchange channels in the pattern menu has not worked
    + Quoted parameters in the command line have not worked
    + Selection of the row number to highlight
    + Current directories now remembers correctly
    + When export a file, a filename is entered automatically
    + BPM display
    + Option to switch off the volume fade out for WAV export
    + Option to move the cursor horizontally when enter a parameter into the
    pattern
    + Numberic keys sticking in the instrument editor is fixed
    + 'Editor' window is renamed to 'Preferences'
    + YM2203 code is now in an external DLL
    + Speed interleaving has been messed sometimes after click on the order
    list while the music plays
    + TFD export code is completely rewritten, to fix the unstable export problem,
    and also to make files smaller
    + Algorithm preview when hovering the mouse cursor on a button
    + Replacement of reserved characters in the filename when saving an instrument
    + Group save for instruments
    + TL modification for an instrument or group (changes the volume)
    + Automatic backup of previous version when saving a module
    + Undo/Redo
    + Other changes and fixes
    Последний раз редактировалось Rindex; 15.06.2011 в 11:56.
    Сбросив пару лишних мегатонн,
    Khimki
    15 сообщений
    В догонку почти сразу пошла версия 1.51. Ссылка та же, что в первом посту.
    * Background in the preview window has not erased with reducing of the font size
    * Selection highlight has not taken row highlight settings into account
    * Fadeout option for WAV export worked from the editor only
    * WAV export from command line has been broken
    * Scale slots TL feature has not worked properly
    * Undo for operations that altered whole module has not worked
    * Current pattern has been not updated with changing order position
    * Changing instrument parameters with numberic key has not worked
    Russia, Ulianovsk
    33
    22 сообщений
    классные понятные изменения на красивом буржуинском языке
    speccy merchandise
    Khimki
    15 сообщений
    Как написал автор, так и скопипастил.
    Земля, Москва, Марьино
    17 сообщений
    Как пояснения написаны так и работы музыканты пишут. FM у нас ещё не родилось. Две с половиной конверсии.
    GibbS
    Talking =)
    Из встроенного хелпа удалось взять вот это:
    1.51 20.06.11
    * При уменьшении размера шрифта не стирался фон в окне предпросмотра
    * Подсветка выделения не учитывала настройки подсветки строк
    * Настройка fadeout при экспорте WAV работала только из редактора
    * Не работал экспорт WAV из командной строки
    * Функция Scale slots TL не работала корректно
    * Не работала отмена операций, изменяющих весь модуль
    * Не обновлялся отображаемый паттерн при выборе позиции ордер-листа
    * Не работал ввод параметров инструмента цифровыми клавишами
    1.5 13.06.11
    + Поддержка инструментов в формате SMPS
    + Не работал пункт Exchange channels в меню паттерна
    + Не работали параметры в командной строке, заключённые в кавычки
    + Выбор строки для подсветки
    + Исправления для запоминания текущих директорий
    + Автоматически подставляются имена с нужным расширением при экспорте
    + Отображение BPM
    + Отключение плавного убирания громкости для экспорта WAV файлов
    + Опциональное горизонтальное перемещение курсора при вводе параметров в
    паттерне
    + Исправлено залипание некоторых нот (на цифрах) в редакторе инструментов
    + Переименовано окно настроек
    + Код эмуляции YM2203 вынесен во внешнюю DLL
    + Исправлена проблема с неправильным чередованием скоростей при клике по
    ордер-листу во время проигрывания
    + Переписан код экспорта TFD, для решения проблемы нестабильного экспорта
    и для уменьшения размера получаемых файлов
    + Предпросмотр алгоритма при наведении стрелки на кнопку
    + Исправление недопустимых символов в имени инструмента при сохранении
    + Сохранение группы инструментов
    + Модификация TL слотов инструмента или группы инструментов (изменение
    громкости)
    + Опциональный автоматический бэкап предыдущей версии файла модуля при
    перезаписи
    + Undo/Redo
    + Другие изменения
    Последний раз редактировалось GibbS; 21.06.2011 в 18:00.
    Khimki
    15 сообщений
    По умолчанию TFM Music Maker v1.52
    TFM Music Maker v1.52 - http://shiru.untergrund.net/software.shtml
    1.52 15.11.11
    * Не работало отпускание клавиш на USB MIDI клавиатурах
    * Переключение инструмента через MIDI выделяло группу инструментов
    * Убрана зависимость в dll от MSVC Redistributable
    * При открытии модуля или инструмента пропадал пункт Help главного меню
    * Эффекты выше F отображались неправильно в соседних паттернах
    * Неправильно импортировались некоторые SMPS инструменты
    Последний раз редактировалось Rindex; 17.11.2011 в 23:00.
    Khimki
    15 сообщений
    Unhappy
    83 сообщений
    LVD+
  1. Disturbed COverMAnia ( music disk with z00m music collection)
    от kyv в разделе Музыка
    Последнее: 27.03.2008, 10:01
  2. TFM Maker ver1.1
    от CHRV в разделе Музыка
    Последнее: 20.02.2008, 09:56
  3. slave maker
    от kyv в разделе Игры
    Последнее: 01.10.2007, 09:55
  4. Потерялся Shadow Maker
    от rasmer в разделе Люди
    Последнее: 26.04.2006, 21:28
  5. Pro SOUND MAKER
    от Dexus в разделе Музыка
    Ответов: 18
    Последнее: 10.08.2005, 07:01
