Показано с 11 по 20 из 22
Тема: Majikazo
    Sevilla, Spain
    Sorry, friends. I included some code for Pentagon timings, but didn't test it properly. I've fixed a bug, and I think it should work now:
    http://www.speccy.org/metalbrain/majikazo_B_bugfix.tap
    (automatic translation: )
    Извините, друзья. Я включил код для таймингов Пентагона, но не проверяли должным образом. Я исправил ошибку, и я думаю, он должен работать сейчас:
  2. #12
    г. Черкассы, Украина
    1,700
    463 сообщений
    8 Post(s)
    Thanks, friend!
    О, думаю, теперь пойдет дело!!!
    Ave ZX!
  3. #13
    1,700
    463 сообщений
    8 Post(s)
    Dear friend! Can you tell about this code? What changes in it? And give us address of changes, please... (Because I want create universal "classic zx/pentagon" TR-DOS version).
    Or may be this bugfixed version will be correctly worked on all models of Spectrums? Am i right? Or this version for pentagon-clones only?
    ---------- Post added at 22:25 ---------- Previous post was at 22:20 ----------
    В общем, если я слишком уж коряво написал на английском, интересуюсь у Metalbrain о том, работает ли данная версия на всех моделях, включая Пентагон, или же эта версия ТОЛЬКО для Пентагон-клонов. Тогда хочется узнать, что и где было поменяно в коде...
    Последний раз редактировалось Slider; 16.05.2012 в 23:23.
    Ave ZX!
  4. #14
    Sevilla, Spain
    It should work correctly for all models now. There's a machine check at the beginning, and once selected, there's a pair of changes to the master delay (it depends on the total of T-states per frame: Pentagon has a higher value than 128k models, and 48k has the lowest value), and to the number of metatiles restored before waiting for the interruption. This number is lower on Pentagon (and might vary in standard spectrums if there's too much calculations, screen action and sound in the same frame, but it's a very very very rare case), but there was a part of the code that expected that number to be fixed. Not anymore.
  5. #15
    1,700
    463 сообщений
    8 Post(s)
    Terrible bug in game when time is out
    Последний раз редактировалось Slider; 11.05.2014 в 11:56.
    Ave ZX!
  6. #16
    Sevilla, Spain
    Thanks a lot for finding that!
    Rebugfixed version here:
    http://www.speccy.org/metalbrain/majikazo_B_bugfix2.tap
  7. #16
  8. #17
    1,700
    463 сообщений
    8 Post(s)
    Thanks for bugfixed version!!!
    Ave ZX!
  9. #18
    1,700
    463 сообщений
    8 Post(s)
    TR-DOS version is HERE!
    Ave ZX!
  10. #19
    Ижевск
    Slider, порт #FF убрал/оставил?
  11. #20
    1,700
    463 сообщений
    8 Post(s)
    Опроса порта #FF в этой версии нет.
    Ave ZX!
