If it has special loader you can try to load it without interception of read byte procedure:
1. type LOAD "" but do not press Enter key
2. on the toolbar press "play" button and select the .tap file
3. after that press Enter key immediately
4. during the loading you can press and hold F9 to speed up the loading
Ответить с цитированием
