Показано с 1 по 10 из 44
Тема: Yumiko in the haunted Mansion
    Khimki
    15 сообщений
    По умолчанию Yumiko in the haunted Mansion
    И ещё одна новая игра от LCD - Yumiko in the haunted Mansion. Вот тут сам автор пускай напишет, что делать. Он есть на этом форуме. Музыка AY, её автор там написан. Плохого просто не умеет делать.
    На официальном сайте (верхняя ссылка) находится более полная версия игры.
    http://members.inode.at/838331/zx/Yu...d Edition).zip
    http://www.worldofspectrum.org/infos...cgi?id=0027988
    http://vtrdos.ru/gamez/y/YUMICO.zip - TRD
    Последний раз редактировалось Rindex; 30.04.2014 в 00:44.
    Сбросив пару лишних мегатонн,
    1,497
    974 сообщений
    как я понял блуждая в потёмках надо зажечь все свечи.
    кнопка FIRE показывает карту.
    Vienna, Austria
    Correct!
    Pass near the candles to light them up. If all are lightning, you will go to next level.
    When the screen flashes, the ghosts appear and they can blow all near candles off. If your candle is blown out, you can reignite it by passing a lightning candle.
    Your candle get weaker with time, resulting in less and less light.
    Staying ca. 10 second without light means that a monster will catch your feet and draw you into the ethernal darkness.
    This is just a preview version because I have not done all levels ant intro yet.
    Khimki
    15 сообщений
    Похоже, что да.
    Khimki
    15 сообщений
    LCD, good game. And what will be in the full version?
    Vienna, Austria
    The full version is supposed to have 24-32 levels (depends on how good I can compress them), and a nice intro where the story is told about Yumiko, her family, what she is supposed to do. This will add even more atmosphere.
    If I can optimise the code further, I probably can add one or two features.
    I want to keep the game running on 48K and not switch to 128K.
    I want to release the full game for free as TZX, TAP and MGT, probably also as TRD.
    There will be also a collectors edition on Tape for sale too...
    NovaStorm: That is on purpose as the map is the most important thing in the game. This makes you really feel like a lone little kid in a unknown enviroment in the darkness, with only a weak light of a candle .
    Этот пользователь поблагодарил LCD за это полезное сообщение:
    Uzix(30.08.2020)
    Ливны, Орловская обл
    Сложно понять, можно ли двигаться в определённую сторону без карты. Хоть бы как-то стены видны были бы.
    А так - весьма атмосферненько =)
    Khimki
    15 сообщений
    Переключайся на карту почаще. И смотри, когда молния будет, где приведения находятся, заодно и все ходы помещения увидишь. А идея игры действительно отличная.
    Последний раз редактировалось Rindex; 30.10.2012 в 14:37.
    Khimki
    15 сообщений
    LCD, do 128к and with a limit of turning on of the maps, for example - three-four times on one level. That would be excellent.
    Vienna, Austria
    I wanted to do this, but then it was unplayable on larger and more complex maps because you do not know where the ghosts blowed off the candles, especialy on "Madness" level where 8 ghosts appear at once. I ended up searching blown off candles in dead corners where they were perfectly lightning, running out of time. So if, then only as option for totaly hardcore masochistic players.
    128K version of this game is not planed, but the follow up to this game may be 128K only: "Yumiko in the realm of Slenderman". The reason is simple: My BorIDE does not have 128K memory management yet.
