Показано с 1 по 7 из 7
Тема: Bad KEMPSTON JOYSTICK controll
    Praha
    34
    15 сообщений
    По умолчанию Bad KEMPSTON JOYSTICK controll
    Some ZX software(games/utilities) contain bugs in Kempston joystick controll and joystick work incorrect or not work or work only original kempston interface. Big part of this software is fixed for correct joystick controll and compatibility with all existing kempston joystick interfaces/emulators/zx clones.
    Here is thread on WOS:
    http://www.worldofspectrum.org/forum...ad.php?t=30070
    But all this fixed software is in TAP format. Same software exist often also in TRD/SCL and may be also fixed...
    As first I fix Artist 1 by Xcellent Software'85 ( downloaded from http://vtrdos.ru/system/ARTIST1.ZIP ). Here is fixed version in TAP and TRD format:
    http://www.worldofspectrum.org/forum...7&postcount=27
    Praha
    34
    15 сообщений
    See this archives:
    http://velesoft.speccy.cz/other/zx_g...n_port_(1).zip
    http://velesoft.speccy.cz/other/zx_g...n_port_(2).zip
    If exist TRD/SCL images with this games, please send me direct link for download and I can fix it.
    1,456
    946 сообщений
    in the game RickDangerous (bleepload/dsk) in the joy subroutine AND #1F instead IN A,(#1F)
    Praha
    34
    15 сообщений
    In DSK version absent some instructions.... bad code...
    Other versions in TAP/TZX format work correct. You can convert RICK DANGEROUS 1 from TAP to DSK. Correct version exist, only in different fileformat.
    Одесса
    75
    31 сообщений
    Вспоминаются
    Star Bowls
    N.E.X.O.R
    у сеня в Unreal 0.37.6 by SMT там все время прыжки.
    http://www.sky.od.ua/~ptsk
    Praha
    34
    15 сообщений
    Цитата Сообщение от TomCaT Посмотреть сообщение
    Вспоминаются
    Star Bowls
    N.E.X.O.R
    STAR BOWLS with fixed kempston controll:
    http://velesoft.speccy.cz/other/star..._kempston).zip
    All TRDOS versions of NEXOR contain any bug, because after select KEMPSTON controll not read joystick port..
    But versions of NEXOR on WOS work correct.
    Последний раз редактировалось VELESOFT; 21.07.2013 в 21:56.
    Praha
    34
    15 сообщений
  1. Joystick 125
    от creator в разделе Устройства ввода
    Ответов: 25
    Последнее: 28.08.2025, 17:46
  2. Super Joystick Port
    от zx-kit в разделе Устройства ввода
    Ответов: 110
    Последнее: 19.05.2020, 22:44
  3. Kempston Joystick в АТМ-Turbo 2
    от stakh в разделе ATM
    Последнее: 25.06.2011, 13:19
  4. SPRINTER 2000 and kempston joystick
    от VELESOFT в разделе Sprinter
    Последнее: 03.11.2010, 20:52
  5. Проверка на наличие Kempston Joystick
    от Slider в разделе Для начинающих
    Ответов: 15
    Последнее: 19.11.2009, 22:56
