Страница 69 из 73 ПерваяПервая ... 656667686970717273 ПоследняяПоследняя
Показано с 681 по 690 из 727
Тема: EmuStudio-ZX
  1. #681
    1,652
    574 сообщений
    50 Post(s)
    Задача теста:
    1. Заскриншотить окно анализатора звука, когда оно заполнится почти целиком и прислать сюда.
    2. Заскриншотить окно консоли (копипастой) и тоже прислать сюда.
    EmuStudio v0.9 test 1 (50Hz, AudioBuf 0.5 frame).exe
    EmuStudio 0.9 test 1 (ZX-Mode)
    Written by dr.Titus 2006,2025
    CPU: AMD FX-8370 Eight-Core Processor
    Support: MMX SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 AVX
    Logical CPU cores: 8
    Current CPU #0 frequency: 4000MHz
    DWM Composition: Enabled
    Powered from AC
    Power scheme already exist
    Low CPU AC threshold = 90%
    Low CPU DC threshold = 20%
    Power scheme activated
    WM_CREATE
    Windows version: 11 (10.0.22621.4830)
    Multimedia timer resolution: 2431 mks
    Multimedia timer resolution: 2008 mks
    Desktop DPI: 96 dpi (scale: 100%)
    DXGI version 1.6
    Direct2D version 1.3
    Monitor[0] - NVIDIA GeForce GTX 970: 27G2G5
    Mode: 1920 x 1080, 74.973000Hz
    Frequences set: 50.00Hz, 59.94Hz, 60.00Hz, 74.97Hz
    Hardware composition: fullscreen / cursor stretched
    Monitor[1] - NVIDIA GeForce GTX 970: 2769M
    Mode: 1920 x 1080, 60.000000Hz
    Adapter[0]: Direct3D feature level 11.1
    Allow tearing (variable framerate): supported
    WASAPI system mix format: 96000 Hz, 32 bits, 2 channels, float
    Endpoint name: Динамики (5- USB HIFI AUDIO)
    WASAPI endpoint format: 96000 Hz, 24 bits, 2 channels, PCM
    Audio system: WASAPI Shared
    Audio format: 96000 Hz, 32 bits, 2 channels
    Device minimum period: 3 ms
    Audio Buffer Size: 2112 samples (22.0 ms)
    0,  0,  0,  0,  960,  0,  0,  0,
    Process priority: 128
    Main thread priority: 0
    High resolution timer: 10000000Hz
    CPU Mode: Pure
    WMI thread priority = -15
    Emulation thread priority = 2
    Video thread priority = 1
    Audio thread priority = 15
    Audio buffer is empty
    Audiobuffer padding: 3.3 ms
    Total audio delay: 21.0 ms
    Class name WIND_0000
    Init: Pentagon
    Snapshot snapshot.z80 loaded
    Frames lost: 1
    Viewport size changed: 812 x 572
    *Resync
    SoundProfiler: Init
    С уважением, Станислав.
    Этот пользователь поблагодарил CityAceE за это полезное сообщение:
    Titus(10.03.2025)
  2. #682
    г. Котельники
    22
    15 сообщений
    Цитата Сообщение от ZXMAK Посмотреть сообщение
    может у вас осциллятор с термостабилизацией? У меня в тестах на обычном кварце 32 МГц частота за 1 минуту уплывала больше чем на 2 кГц (за счет нагрева платы). Это порядка 60 ppm. Отклонение у обычных кварцев допускается порядка 200-400 ppm.
    Да не, без термостабилизации. Если говорить именно про кварцевые генераторы, последним брал копеечный SMD07050C4 , у него точность 10 ppm. Реально уход частоты с прогревом - единицы герц.
  3. #683
    2,223
    875 сообщений
    А почему-бы ей не плавать? Рубидиевые стандарты частоты в звуковухи вроде не ставят
    Все у современных звуковух хорошо и стабильно)
    это в настройках драйвера можно менять, в Windows была какая-то утилита в ней можно было все эти параметры менять, не помню точно уже название, помоему rivatuner. Можно также установкой переменной среды управлять, имя перменной зависит от драйвера.
    Это не регулируется твикерами.
    Моники поддерживают 50Гц. Лучше было бы на этой частоте попробовать)
  4. #684
    119
    80 сообщений
    ну я настраивал в твикере.
    Также vblank управляется через переменную среды.
    Для Broadcom и прочих видеокарт переменная vblank_mode:
     0 - Never synchronize with vertical refresh, ignore application's choice
    1 - Initial swap interval 0, obey application's choice
    2 - Initial swap interval 1, obey application's choice
    3 - Always synchronize with vertical refresh, application chooses the minimum swap interval
    Для NVIDIA драйверов переменная __GL_SYNC_TO_VBLANK
  5. #685
    2,223
    875 сообщений
    Это линукс, линукс!
    У меня винда) И линукс мне нафиг не нужен)
  6. #686
    119
    80 сообщений
    Это линукс, линукс!
    я в Win 7 настраивал. Там тоже несколько вариантов было - принудительно вкл, принудительно выкл, по запросу приложения и еще вроде какие-то варианты. Не знаю, может в современных Windows уже нельзя, но в Win 7 можно было настраивать много параметров у драйвера, принудительно перегружая настройки приложения. Помню там даже готовые наборы настроек для большинства игр были - можно было просто комбо-боксом выбрать игру и под нее оптимальные настройки подтягивались.
    жаль, я хотел попросить под Linux скомпилировать, но подозреваю там в коде наверное много завязок на DirectX?
    DirectX это устаревшая и ограниченная библиотека, сейчас модно под Vulkan писать.
    Если на Linux будешь смотреть, обязательно попробуй Wayland - минимум оверхеда для GPU, fps сразу +20%. Под него Labwc легковесный композитор, если хочется со спецэффектами, то Wayfire.
    Последний раз редактировалось ZXMAK; 10.03.2025 в 16:30.
  7. #687
    2,223
    875 сообщений
    Не просто завязана, а он под нее и написан.
    DX ничего не устарел. Просто для игр модно Vulkan. Как альтернатива.
    Я не думаю, что пользователю стоит лезть в настройки драйверов. И так система позволяет гибко работать на уровне DirectX.
  8. #688
    1,652
    574 сообщений
    50 Post(s)
    Powered from AC
    WM_CREATE
    Multimedia timer resolution: 1989 mks
    Multimedia timer resolution: 2014 mks
    DXGI version 1.6
    Mode: 1920 x 1080, 50.000000Hz
    0,  960,  0,  0,  0,  0,  960,  0,
    CPU Mode: Pure
    Audiobuffer padding: 5.0 ms
    Total audio delay: 26.0 ms
    Init: Pentagon
    Resync
    SoundProfiler: Init
    Titus(10.03.2025)
  9. #689
    Воронеж
    316
    239 сообщений
    Да. Но беда в том, что скорости самых топовых процессоров не хватит делать её для сигнала с частотой дискретизации 3.5 МГц.
    блин, уже не знаю, плакать или смеяться каких топовых процессоров тебе нужно посчитать менее 4000 значений в кадре?
    причём всё это спокойно считается на лету, сразу же в финальную сетку для звуковухи, безо всяких переводов одной в другую
    а нафига тебе сигнал с такой частотой? которую и не выведешь никуда
    если плавает частота дискретизации, то будет странным, если частота волны сигнала будет оставаться неизменной.
    наоборот - будет странным, если частота волны сигнала будет меняться
    Если системный таймер лишний, то относительно чего измеряются частоты дискретизации звуковой карты и видеоадаптера? Без него точно измерить не получится...
    нам найти нужно отношение промежутков звуковухи и видеоадаптера - первого ко второму
    таймер сюда может внести только дополнительную погрешность за счёт лишнего этапа на конвертацию
    проще говоря, если длина удава нужна именно в попугаях, так сразу в попугаях и измеряй
    и да, вы так обсуждаете характеристики и нагрев, будто бы на реальном спеке ничего не уплывало и не "корёжилось"
    так небось, еще и посильней уплывало - но что-то я не вижу праведных возмущений и призывов "нафиг такой реал"
    а еще это не эмулируется нигде а также вещи типа случайных отклонений в работе мембраны динамика
    (каковые тоже могут быть, подозреваю, куда больше всех погрешностей расчётов для эмуляции))
  10. #690
    Nizhnevartovsk
    152
    100 сообщений
    Lethargeek, не поверишь, но на реальном спеке частота AY не плавала, и не менялась в угоду плавности вывода на экран. На плавность вывода часто было плевать, кроме разве что демок. И уж точно было плевать на рассинхронизацию звука и картинки на экрана на кадр-другой. Вообще вот абсолютно фиолетово если звук на 2 фрейма отстает. А вот если он начинает щёлкать или плавать по частоте - то такое вот вообще не нужно, какая бы плавная картинка не была.
    Последний раз редактировалось Dexus; 10.03.2025 в 20:04.
  1. Эмулятор УКНЦ - EmuStudio
    Ответов: 1198
    Последнее: 07.05.2025, 13:34
  2. Эмулятор МС-0515 - EmuStudio
    Ответов: 143
    Последнее: 09.02.2023, 10:44
