Страница 5 из 5 ПерваяПервая 12345
Показано с 41 по 45 из 45
Тема: Bomb Munchies
  1. #41
    Perm, Russia
    306
    107 сообщений
    Bomb Munchies Version 1930, 17th Nov 2017
    топик на WoS
    список изменений:
    Added:
    One extra frame of ticking bomb, now takes a fraction of a second longer for the bomb to explode and gives everyone that fraction of a second to run away.
    New pick-up feature:
    The Detonator: When a player collects it, all active bombs within the arena are detonated.
    Bombs that are in the process of popping up from the arena floor are not affected.
    If you see it, get in quick as it will survive for a short while, before being destroyed by the arena.
    The Tryantulas can press the plunger too......
    ----Danger UXB----
    - Small diamond graphic appears in the left status panel when the main diamond has been picked up.
    - main diamond now has yellow background.
    Keyboard/joystick setup page.
    ---- Multi-direction on/off ----
    New option to have the diagonal input on/off with joystick and selected key inputs.
    Player 1 press A
    Player 2 press S
    Player 3 press D
    Player 4 press F
    The screen will show either a 4-way arrow graphic or 8-way arrow graphic under the player character.
    Due to keyboard conflicts (real and emulation) ASWDX and IJKLM are set to 4 way input only
    - they will automatically switch to 4-way when selected. No 8-way movement for ASWDX or IJKLM.
    Kempston, Sinclair, Fuller, QWERT and QAOPM/Space can have 4-way or 8-way input selected.
    Note: the player does not move diagonally, it just registers a diagonal input and might make the game easier for some people to play. The graphic will jump around when they are in a corner, this is perfectly normal.
    If you want all 4 players on joysticks with multi-direction (8-way) on then it is best to use Sinclair 1 and 2 with Kempston 31.
    For the forth player you will require:
    a) COM-CON interface set up as QWERT, or just use QWERT on the keyboard. (Com-Con works with interface 48k, 128k, +2 grey only)
    b) K-55 interface (see Joefish) - it is a modified Kempston interface.
    c) Kempston 95 (see velesoft) - requires DivIDE with RTC interface.
    d) Fuller interface - this may clash with the Kempston 31/K-55/Kempston 95 input though - be careful.
    Remember to switch on the 8 way input for each player, if you want it.
    -- Pause Game --
    Now works on the intro/story screen of Tryantulas. I had coded it so that the game did not pause
    on this screen, however, I've moved the pause message up the screen and it now works.
    Pressing 'G' pauses the game
    'Y' quits to title screen
    'N' returns to the game
    'R' changes 2D / 3D mode.
  2. #42
    262
    156 сообщений
    8 Post(s)
    И как обычно.
    Этот пользователь поблагодарил creator за это полезное сообщение:
    abelenki(05.03.2020)
  3. #43
    Perm, Russia
    306
    107 сообщений
    Bomb Munchies Version 2060, 18th Feb 2020
    пост на SC
    список изменений:
    Added stuff that covers all the games:
    - The screen redraw is a tad faster, it won't notice but yes it is faster.
    - 4 Extra frames of a frazzling bomb - it takes a fraction of a second longer for a bomb to explode.
    - 2 Extra frames of a bomb popping up from the floor.
    Pause Mode: (Press G during the game)
    - Border colour in the game can now be changed in pause mode - by pressing B.
    - Screen rendering 2D/3D can be changed in pause mode by pressing R.
    Tryantulas:
    - Game complete message now waits for a key to be pressed.
    - A few new graphics replace old ones.
    Эти 2 пользователя(ей) поблагодарили abelenki за это полезное сообщение:
    creator(05.03.2020), OMu4(05.03.2020)
  4. #44
    262
    156 сообщений
    8 Post(s)
    SCL
    Эти 4 пользователя(ей) поблагодарили creator за это полезное сообщение:
    abelenki(05.03.2020), lzb_j77(06.03.2020), OMu4(05.03.2020), Underground1(05.03.2020)
  5. #45
    Tomsk, Russia
    Сильно похожа на амижный Master Blaster, но у амижной версии музыка гораздо забойнее.
  1. [Video] Bomb Jack Plus
    от morcar1975 в разделе Игры
    Последнее: 31.07.2019, 13:46
  2. Нужны задние фоны из Bomb Jack.
    от kusakov в разделе Графика
    Последнее: 07.01.2014, 21:07
  3. Bouncing Bomb - Redux
    от Rindex в разделе Игры
    Последнее: 28.06.2012, 11:04
  4. Bomb Fusion под General Sound
    от Evgeny Muchkin в разделе Игры
    Последнее: 08.08.2007, 00:21
