Страница 20 из 22 ПерваяПервая ... 16171819202122 ПоследняяПоследняя
Показано с 191 по 200 из 216
Тема: TSX-Plus OS
  1. #191
    СССР, Новосибирск
    290
    234 сообщений
    30 Post(s)
    Выложил на некоторое время загрузочный образ.
    В эмуляторе загрузился в 22-bit QBUS конфигурации.
    RT-11FB  V05.07
    .SET TT SCOPE
    .TSX
    * TSX-Plus Version 6.50 *
    Copyright (c) 1980,1981,1982,1983,1984,1985,1986,1987,1988,1989,1990,1991
    an unpublished work by S&H Computer Systems, Inc., Nashville, TN, USA
    (S&H) covered by U.S. Patent No. 4,642,756.  All rights reserved.
    This material contains the valuable properties and trade secrets of S&H
    and may not be used except by the express written permission of S&H.
    Distributed by S&H Computer Systems, Inc.
    Licensed for use Here, There and Everywhere in The World.
    License # = 999-TPS-00000
    Line # 1
    .SH ALL
    TSX-Plus Version = 6.50
    Date unknown
            Active          Handler  Handler  Handler
    Device    I/O   Status  V. base  P. base   size     CSR    Vector
      TT        0   000004
      LD        0   102446
      CL        0   016057   035470   000000    512
      DU        0   102450   067706   000000    340    172150  154
      DL        0   102405   120000   075255   1418    174400  160
      RK        0   100000   120000   075250    280    177400  220
      MU        0   017060   070432   000000   3240    174500  260 254
    Assignments:
    SY  --> RK0:
    DK  --> RK0:
    There are no allocated devices
    Uptime: 00:00:03
    System use:   Run=20%, I/O-wait=0%, Swap-wait=0%, Idle=80%
    I/O Activity: User I/O=8%, Swapping I/O=0%
    Job   Line   Pri   State    Size   Connect   CPU time  Program    Job name
     1*   1(0)    50  IN        39Kb   00:01:00  00:00:00  KMON
    Line  Type     Vector     CSR    Terminal  Speed     Active  Line Name
     1*   Oper.  DL     060  177560  VT200      9600 8N    Yes   Console
    CL version number 18.
    Unit  Line   Job           Options
     CL0  none  none
     CL1  none  none
     CL2  none  none
     CL3  none  none
    Total installed memory            = 4088Kb
    Size of unmapped TSX and handlers = 32Kb  (077142)
    Size of mapped TSX system regions = 77Kb
    Total size of TSX and mapped data = 129Kb
    Size of mapped device handlers    = 2Kb
    Size of sharable run-time systems = 0Kb
    Size of data cache buffer area    = 33Kb
    Space available for user jobs     = 1873Kb
    Swappable job context area        = 7Kb
    Current job memory limit = 56Kb
    Maximum job memory limit = 64Kb
    QUAN0  = 2
    QUAN1  = 20
    QUAN1A = 2
    QUAN1B = 2
    QUAN1C = 1
    QUAN2  = 10
    QUAN3  = 20
    INTIOC = 30
    HIPRCT = 40
    There are no spooled devices
    Logical subset disks:
    No logical disks are mounted
    Mounted devices:
      Device          Associated jobs
    RK0:        1
    Shared run-time systems:
    There are no named regions
       Program               Attributes and Privileges
    RK0:DUP.SAV      DUP/PRIV=(SYSPRV,NODEBUG)
    RK0:IND.SAV      NOWAIT/IND/PRIV=(NODEBUG)
    RK0:KED.SAV      SINGLECHAR/NOWAIT/HIGH/PRIV=(NODEBUG)
    RK0:KEX.SAV      SINGLECHAR/NOWAIT/HIGH/PRIV=(NODEBUG)
    RK0:K52.SAV      SINGLECHAR/NOWAIT/HIGH/PRIV=(NODEBUG)
    RK0:LOGON.SAV    LOCK/BYPASN/PRIV=(BYPASS,SETNAME,SETPRV,SYSPRV,
                     NODEBUG)
    RK0:PATCH.SAV    SINGLECHAR/PRIV=(NODEBUG)
    RK0:SETUP.SAV    IOPAGE/SETUP/PRIV=(NODEBUG)
    RK0:SYSMON.SAV   /PRIV=(MEMMAP,NODEBUG)
    RK0:TECO.SAV     SINGLECHAR/NOWAIT/PRIV=(NODEBUG)
    RK0:TRANSF.SAV   SINGLECHAR/NOWAIT/NONINTERACTIVE/NOWINDOW/PRIV=(
                     NODEBUG)
    RK0:TSAUTH.SAV   BYPASN/PRIV=(NODEBUG)
    RK0:TSXUCL.SAV   TSXUCL/PRIV=(NODEBUG)
    RK0:VTCOM.SAV    SINGLECHAR/NOWAIT/MEMLOCK/PRIV=(PSWAPM,NODEBUG)
    Authorized privileges: ALLOCATE,BYPASS,DEBUG,DETACH,GETCXT,MEMMAP,
                           MESSAGE,NFSREAD,NFSWRITE,OPER,PSWAPM,REALTIME,
                           RLOCK,SEND,SETNAME,SETPRV,SPFUN,SYSGBL,
                           SYSPRV,TERMINAL,WORLD,GROUP,SAME,SUBPROCESS,
                           UP1,UP2,UP3,UP4
    Current privileges:    ALLOCATE,BYPASS,DEBUG,DETACH,GETCXT,MEMMAP,
                           UP1,UP2,UP3,UP4
    SL status: OFF,NOKED,NOTTYIN,SUBSTITUTE
    VM not installed
    .BO
    [System shutdown]
    Connect=00:01:00  CPU=00:00:01
    RT-11FB  V05.07
    .SET TT SCOPE
    Цитата Сообщение от vva Посмотреть сообщение
    работа идет на DM
    Для начала стоит проверить DMA,MAPH,MAPIO, если заведется - попробовать драйвер DM22 (без MAPIO).
    Последний раз редактировалось form; 26.03.2023 в 12:16.
    PMI: KDJ11-BF, MSV11-JE
    VT220, CM7209
    Этот пользователь поблагодарил form за это полезное сообщение:
    vva(26.03.2023)
  2. #192
    г. Черкесск
    20
    12 сообщений
    R TSX -- тотальный вис без сообщений.
    С драйвером RK из 6.5 ругань, как и раньше;
    ?TSX-F-Fatal system error at 123410
    KRE-KMON read error
    Arg. value = 000000
    Seg. value = 000027
    Overlay: EX2
    SP at time of crash = 141464
  3. #193
    г. Самара
    720
    602 сообщений
    Ради интереса попробую (но немного позже - сейчас другое терзаю) на PDP-11X/23
  4. #194
    СССР, Новосибирск
    290
    234 сообщений
    30 Post(s)
    Там образ RK05 - можно весь образ попробовать.
    Если он заработает - проблемы нужно искать в TSGEN, если не заработает - нужно ковырять железяку.
    У TSX есть системный отладчик, но я ни разу не пробовал его.
    Ну и таки интересно что SH CONF говорит на этой железяке.
    VT220, CM7209
  5. #195
    г. Черкесск
    20
    12 сообщений
    RT-11FB V05.07
    Booted from RK0:RT11FB
    USR is set SWAP
    EXIT is set SWAP
    KMON is set NOIND
    MODE is set NOSJ
    TT is set NOQUIET
    ERROR is set ERROR
    SL is set OFF
    EDIT is set KED
    FORTRAN is set FORTRA
    KMON nesting depth is 3
    CLI is set DCL, CCL, UCL, NO UCF
    PDP 11/23 PLUS Processor
    4088KB of memory
    FP11 Hardware Floating Point Unit
    Extended Instruction Set (EIS)
    Memory Management Unit
    50 Hertz System Clock
    FPU support
    Переделывать контроллер RK от комрада forth32 желания нет (необходимости тоже - прекрасно работает с кучей систем и TSX 6.1)
    Что-то где-то в нвстройках... Например, почему 6.1 не работает с MEMSIZ > 248?
  6. #196
    СССР, Новосибирск
    290
    234 сообщений
    30 Post(s)
    У меня все прекрасно работало.
    Type a command then press the RETURN key: B DU3
    Trying DU3
    Starting system from DU3
    RT-11ZM (S) V05.07
    .SET TT QUIET
    .R DATE
    Date? 11-MAR-2014
       @Tim
    .LO NQ
    .RU ETHTIM
    .UNL NQ
    .R DATE
    .BO RT11SB
    RT-11SB (S) V05.07
    .SET TT QUIET
    .R DATE
    .@SY:RUNTSX
    .D 1000=13700,54,12760,2005,276,104350
    .ST 1000
    .SET ERROR NONE
    .R TSX
    * TSX-Plus Version 6.01 *
    Copyright (c) 1980, 1981, 1982, 1983, 1984, 1985 an unpublished work by
    S&H Computer Systems, Inc., Nashville, TN, USA (S&H) All rights reserved.
    Distributed by JPY Associates Limited
    Licensed for use on a single computer system at HI TECH SYSTEMS S A
    License # = 56-T1S-10783
    11-Mar-2014  22:08:30
    Line # 1
    Logon please:ROOT
    Password:
    Welcome to the system
    .SH ALL
      TT        0   000004
      LD        0   102446
      CL        0   006057   055646   000000    708
      DU        0   102450   105612   000000    944    172150  154
      VM        0   102447   107472   000000    384
      LP        0   032003   120000   075622    404    177514  200
      NL        0   000025   120000   075621     58
      EQ        3   007061   120000   075531   3566    174440  120
    Assignments:
    SY  --> DU3:
    DK  --> DU3:
    TCP --> LD7:
    CF  --> VM0:
    WF  --> VM0:
    Device  Job    Job name
     CL0    10   TELNET servr
     CL1    13   TELNET servr
     CL2    14   TELNET servr
    Uptime: 00:00:28
    System use:   Run=37%, I/O-wait=61%, Swap-wait=0%, Idle=0%
    I/O Activity: User I/O=94%, Swapping I/O=0%
     1*   1(0)    50  HI        37Kb   00:01:00  00:00:01  KMON     ROOT
     2    2(0)    50  TI        37Kb   00:01:00  00:00:01  KMON     GUEST
     3    3(0)    50  TI        37Kb   00:01:00  00:00:01  KMON     GUEST
     4    4(0)    50  TI        37Kb   00:01:00  00:00:01  KMON     GUEST
    10    Det.    50  SL        62Kb   00:01:00  00:00:01  RTELNT   TELNET servr
    11    Det.    50  SL-Swap   30Kb   00:01:00  00:00:00  WINPRT   Window print
    12    Det.    50  SL-Lock   62Kb   00:01:00  00:00:04  TCPIP    TCP/IP stack
    13    Det.    50  SL        62Kb   00:01:00  00:00:01  RTELNT   TELNET servr
    14    Det.    50  SL        62Kb   00:01:00  00:00:01  RTELNT   TELNET servr
     2    Local  DHV- 0 350  160500  VT200     19200 8N    Yes   DHV unit 0
     3    Local  DHV- 1 350  160500  VT200     19200 8N    Yes   DHV unit 1
     4    Local  DHV- 4 350  160500  VT200     19200 8N    Yes   DHV unit 4
     5    Local  DHV- 5 350  160500  VT200     19200 8N    No    DHV unit 5
     6    Local  DZ - 0 340  160100  VT200      9600 8N    No    DZ unit 0
     7    Local  DZ - 1 340  160100  VT200      9600 8N    No    DZ unit 1
     8    Local  DZ - 2 340  160100  VT200      9600 8N    No    DZ unit 2
     9    Local  DZ - 3 340  160100  VT200      9600 8N    No    DZ unit 3
    36    CL     DHV- 2 350  160500  unknown   19200 8N    CL0   DHV unit 2
    37    CL     DHV- 3 350  160500  unknown   19200 8N    CL1   DHV unit 3
    38    CL     DHV- 6 350  160500  unknown   19200 8N    CL2   DHV unit 6
    39    CL     DHV- 7 350  160500  unknown   19200 8N    CL3   DHV unit 7
     CL0   36    10   [FORM,TAB,LC,LFOUT,LFIN,CR,CTRL,DTR]
     CL1   37    13   [FORM,TAB,LC,LFOUT,LFIN,CR,CTRL,DTR]
     CL2   38    14   [FORM,TAB,LC,LFOUT,LFIN,CR,CTRL,DTR]
     CL3   39   none  [TAB,LC,EIGHTBIT,LFOUT,LFIN,CR,CTRL]
     CL4  none  none
    Size of unmapped TSX and handlers = 37Kb
    Size of mapped TSX system regions = 70Kb
    Total size of TSX and mapped data = 124Kb
    Size of mapped device handlers    = 4Kb
    Size of data cache buffer area    = 0Kb
    Space available for user jobs     = 1915Kb
    Swappable job context area        = 6Kb
    Maximum job memory limit = 56Kb
    Spooled devices:  LP
    LD7 --> DU3:TSXTCP.DSK[4800]
    Mounted devices:
    DU3:        1  2  3  4 10 11 12 13 14
    DU3:TSXTCP  1  2  3  4 10 12 13 14
    DU3:TSXWRK  2  3  4
    VM0:        1  2  3  4
    Region   Size    Type   Job  Use  Shared  AGE
    EI $      31.6  Global   12    0    Yes   No
    WIN01A     3.8  Global    1    1    No    No
    SCKT00     8.0  Global   12    2    Yes   No
    WIN02A     3.8  Global    2    1    No    No
    SCKT01     8.0  Global   12    2    Yes   No
    WIN03A     3.8  Global    3    1    No    No
    SCKT02     8.0  Global   12    2    Yes   No
    WIN04A     3.8  Global    4    1    No    No
                           UP1,UP2,UP3,UP4
                           UP1,UP2,UP3,UP4
    SL status: ON,NOKED,NOTTY,SUBSTITUTE
    В сущности V6.01 работал не хуже 6.50.
    Из недостатков: не поддерживаются регионы для драйверов и вызов .CLOSZ (из-за чего запуск из под RT-11 V5.5 и новее требует хитростей [в коде выше их видно] - иначе будут проблемы с KED).
    Последний раз редактировалось form; 26.03.2023 в 13:52.
    VT220, CM7209
  7. #196
  8. #197
    г. Черкесск
    20
    12 сообщений
    Вот "моя" 6.1
    .sh all
    TT 0 000004
    LD 0 102446
    CL 0 006057 034006 000000 236
    DM 0 102423 063512 000000 1434 177440 210
    RK 0 100000 120000 006046 280 177400 220
    Assignments:
    SY --> DM2:
    DK --> DM2:
    Uptime: 00:00:10
    System use: Run=1%, I/O-wait=2%, Swap-wait=0%, Idle=95%
    I/O Activity: User I/O=2%, Swapping I/O=0%
    1* 1(0) 50 IN 37Kb 00:01:00 00:00:00 KMON ROOT
    1* Oper. DL 060 177560 VT100 N/A 8N Yes Console
    2 Local DL 310 176510 unknown N/A 8N No * Not installed *
    3 Local DL 320 176520 unknown N/A 8N No * Not installed *
    CL0 none none
    Size of unmapped TSX and handlers = 28Kb
    Size of mapped TSX system regions = 53Kb
    Total size of TSX and mapped data = 91Kb
    Size of mapped device handlers = 0Kb
    Space available for user jobs = 155Kb
    Mounted devices:
    DM2: 1
    UP1,UP2,UP3,UP4
    UP1,UP2,UP3,UP4
    Сгенерина с MEMSIZ = 248, с большими значениями "рубится".
  9. #198
    СССР, Новосибирск
    290
    234 сообщений
    30 Post(s)
    Нужен TSGEN.MAC - так ничего не понять.
    Хм.
    Если проблема только в падениях - то скорее всего из-за DM который не умеет работать с 22bit.
    Нужно попробовать с MAPIO.
    VT220, CM7209
  10. #199
    г. Черкесск
    20
    12 сообщений
    Хорошо, попробую.
    "Взял" PDP2011 от forth32, заменил в TSGEN QBUS на UNIBUS и поставил MEMSIZ = 2048.
    Сработало (sh mem):
    Total installed memory = 3840Kb
    Space available for user jobs = 1952Kb
    RT11XM:
    PDP 11/70 Processor
    3840KB of memory
    Cache Memory
  11. #200
    СССР, Новосибирск
    290
    234 сообщений
    30 Post(s)
    UNIBUS
    Если железка конфигурится как UNIBUS то все вопросы с памятью отпадают - там нет проблем с 22bit для RK/DM.
    VT220, CM7209
