Показано с 1 по 10 из 42
Тема: ZX Spectrum Evolution Graphic Compo 2014
    Рязань
    По умолчанию ZX Spectrum Evolution Graphic Compo 2014
    Это объявление от Yerzmyey утонуло во время Forever, поэтому стоит напомнить:
    While this year edition of International Vodka Party we would like to organize a graphic compo especially for ZX Spectrum Evolution (320x200 in 16 colours out of 64-colours palette, each pixel can have its own colour).
    You don't have to be an owner of the machine (nor the compatible - ATM Spectrum model), the format is simple: ***BMP*** file, 320x200 resolution, 16 colours on the screen (out of the 64-colours palette of ZX Spectrum Evolution).
    You can recognize easily that the final file format is OK: the BMP file will be exactly 32118 bytes long.
    This gfx-mode is available for Spectrum world since 1991, but it wasn't used very often. Which now changes 'cause Eva is the only reasonable choice if one wanna get a new ZX model.
    2 pictures per author allowed.
    Unlike the converts – converted pictures are NOT allowed at all.
    We provide You a "zx_eva_palette.pal" file that You can load into Your favourite PC (and Mac possibly) gfx-editor and draw the compo picture(s).
    Example of loading the palette file into PaintShop:
    COLORS / LOAD PALETTE and... yes, "OPEN" file. Still, You can use only 16 colours out of those 64 ones.
    Check out the example BMP files, too.
    DOWNLOAD the palette FILE and example-pictures!
    Send Your works to yerzmyey AT poczta.onet.pl
    Sending 2 versions - signed and unsigned - might be a reasonable choice.
    ********Deadline - 16 August 2014********
    Note: if You didn't get any confirmation from me, that means I DIDN'T GET YOUR FILE!!!
    Note 2: We consider also making an on-line voting for everybody, after the party.
    Note 3: You can send as well the TRD/SCL 256x192 RGB format pictures (called also "8color" or 3"color" sometimes) but remember You can use there only 8 colours of standard ZX Spectrum palette, and such pictures will compete with Eva's pictures, so it might not be a "fair fight" (although the RGB gfx-mode is stable on ZX Evolution - it doesn't blink).
    Рязань
    Помимо того, что bmp определённого формата можно смотреть прямо в Evo Reset Service, наш португальский товарищ Paulo Silva написал для ATM Turbo 2 специальный вьювер на бейсике (исходники прилагаются).
    Последний раз редактировалось alone; 04.04.2014 в 20:03.
    г. Арзамас
    и что ждать от компо? ворох дизеринга?
    Khimki
    15 сообщений
    Эта новость ещё с февраля висит - http://speccy-live.untergrund.net/20...ic-compo-2014/
    Ерз, кстати предлагает сам участвовать лично людям. Только что толку от конкурса? Конверченные картинки что-ли выставлять?
    Сбросив пару лишних мегатонн,
    Рязань
    Читай внимательно. Конверченные картинки запрещены.
    Khimki
    15 сообщений
    А это вот с Фиатом, само нарисовано? Лучше бы под картинки демку сделали, на радость AAA.
    Рязань
    Показанные картинки - НЕ С КОМПО. Это просто примеры.
    Khimki
    15 сообщений
    А где они задействованы будут потом, которые с компо? Специальная дема для них написана будет, или опять что-то вроде эффектов 1к, которые никому не нужны, кроме конкурсантов, только для Пентевы?
    ---------- Post added at 20:25 ---------- Previous post was at 20:14 ----------
    Просто вон, человек попросил, что-то никто не откликнулся. А это не для компо, а для игры, которая уже сделана. Палитра почти таже.
    http://zx.pk.ru/showthread.php?p=691035#post691035
    Последний раз редактировалось Rindex; 03.04.2014 в 20:19.
    2,217
    871 сообщений
    Не запутывай художников. Палитра не та же, а все гораздо проще.
    Палитра - ЛЮБАЯ, число цветов тоже любое. Должна лишь быть визуальная имитация ограниченного числа цветов, как на Амиге. И все.
    Рязань
    Это компо как раз для того, чтобы появились такие художники.
  1. DiHalt 2014 Lite : Realtime Compo
    от TmK в разделе События
    Последнее: 05.01.2014, 20:23
  2. BEEPER music compo (ZX Spectrum 48K chiptune)
    от breeze в разделе События
    Ответов: 14
    Последнее: 16.08.2011, 20:00
  3. Battle Of The Bits ZX Spectrum Beeper Speaker Compo 2010
    от GibbS в разделе События
    Последнее: 16.11.2010, 04:58
  4. Stupid compo for ZX Spectrum graphic (53 colours, low-res)
    Последнее: 23.08.2009, 23:24
  5. RetroEuskal | 8Bits Graphic Compo
    от riskej в разделе Графика
    Ответов: 38
    Последнее: 05.08.2008, 19:26
