Страница 9 из 28 ПерваяПервая ... 5678910111213 ... ПоследняяПоследняя
Показано с 81 по 90 из 280
Тема: Микроконтроллеры STM32, "с нуля".
  1. #81
    Ярославль
    О трудностях смд монтажа ...
    Воздушный монтаж на скорую руку .
    http://youtu.be/YekS6kWs4PQ
    Планшет снимает дерьмово, в жизни все интересней...
    #include <stm32f05x.h>
    		static volatile uint32_t TimingDelay;
    	  static volatile uint32_t TimerCntDN;
    		static volatile uint32_t TimeOut;
    /* Delay & timers */
    		void SysTick_Handler(void) {
    			if (TimingDelay) {
    				TimingDelay--;
    			if (TimerCntDN) {
    				TimerCntDN--;
    			if (TimeOut) {
    				TimeOut--;
    		void Delay_mS(uint32_t nTime) {
    			TimingDelay = nTime;
    			while (TimingDelay);
    /* main loop */
    int main (void)
      uint16_t i;
      SysTick_Config(SystemCoreClock /1000);
      RCC->AHBENR |= RCC_AHBENR_GPIOAEN | RCC_AHBENR_GPIOBEN;
      RCC->APB1ENR |= RCC_APB1ENR_TIM2EN;
      GPIOA->MODER &= ~GPIO_MODER_MODER15|GPIO_MODER_MODER0;
      GPIOA->MODER |= GPIO_MODER_MODER15_1 | GPIO_MODER_MODER0_0;
      GPIOB->MODER &= ~(GPIO_MODER_MODER3 | GPIO_MODER_MODER10 | GPIO_MODER_MODER11);
      GPIOB->MODER |= ( GPIO_MODER_MODER3_1 | GPIO_MODER_MODER10_1 | GPIO_MODER_MODER11_1);
      GPIOA->AFR[1] |= (2<<(4*7));
      GPIOB->AFR[0] |= (2<<(4*3));
      GPIOB->AFR[1] |= (2<<(4*2))|(2<<(4*3));
      GPIOA->OSPEEDR |= GPIO_OSPEEDER_OSPEEDR15 | GPIO_OSPEEDER_OSPEEDR0;
      GPIOB->OSPEEDR |= (GPIO_OSPEEDER_OSPEEDR3 | GPIO_OSPEEDER_OSPEEDR10 | GPIO_OSPEEDER_OSPEEDR11);
      TIM2->PSC = 160-1;
      TIM2->ARR = 1000-1;
      TIM2->CCR1 = 70; // Pulse_Output = ARR - CCR1
      TIM2->CCR2 = 30;
      TIM2->CCR3 = 10;
      TIM2->CCR4 = 5;
      TIM2->CCMR1 |=
                 TIM_CCMR1_OC1M_2 |
                 TIM_CCMR1_OC1M_1 |
                 TIM_CCMR1_OC1FE  |
                 TIM_CCMR1_OC2M_2 |
                 TIM_CCMR1_OC2M_1 |
                 TIM_CCMR1_OC2FE
                                ;   // canell 1-2 PWM Mode1
       TIM2->CCMR2 |=
                 TIM_CCMR2_OC3M_2 |
                 TIM_CCMR2_OC3M_1 |
                 TIM_CCMR2_OC3FE  |
                 TIM_CCMR2_OC4M_2 |
                 TIM_CCMR2_OC4M_1 |
                 TIM_CCMR2_OC4FE
                                ;   // canell 3-4 PWM Mode1
      TIM2->CCER |=
                 TIM_CCER_CC1E |
                 TIM_CCER_CC2E |
                 TIM_CCER_CC3E |
                 TIM_CCER_CC4E
      //TIM2->BDTR |= TIM_BDTR_MOE;
      TIM2->CR1   |= TIM_CR1_CEN;
    	while(1)
       for(i=0;i<800;i++)
        TIM2->CCR1 = i;
         Delay_mS(1);
       for(i=0;i<800;i++)
        TIM2->CCR2 = i;
         Delay_mS(1);
       for(i=0;i<800;i++)
        TIM2->CCR3 = i;
         Delay_mS(1);
       for(i=0;i<800;i++)
        TIM2->CCR4 = i;
         Delay_mS(1);
       for(i=800;i>0;i--)
        TIM2->CCR1 = i;
         Delay_mS(1);
       for(i=800;i>0;i--)
        TIM2->CCR2 = i;
         Delay_mS(1);
       for(i=800;i>0;i--)
        TIM2->CCR3 = i;
         Delay_mS(1);
       for(i=800;i>0;i--)
        TIM2->CCR4 = i;
         Delay_mS(1);
    	return 0;
    Последний раз редактировалось dosikus; 30.04.2014 в 11:48.
    Profi 1024+CF+CPM+VGA
    ATARI 800XL+SIO2PC+SIO2SD
    RK86@Maximite
  2. #82
    Ярославль
    Обошлась в 650 руб. сама плата
    Так все таки F3 дискаверина или L ?
    RK86@Maximite
  3. #83
    55 сообщений
    а мне все никак к uartу не вернуться. На работе всё бегом, а сейчас в ёперный театр меня тащат. Интиллихенты, млин...
  4. #84
    Ярославль
    Viktor2312, Для твоей борды ссылка на эту тулзу здесь http://www.zx.pk.ru/showpost.php?p=706770&postcount=75
    Это скрипт exel для конфигурации тактовой , создает файл system_stm32xx.c . Где xx
    лиейка чипов. При смене значения HSE - обязательно править значение HSE и в хэдере stm32xx.h !
    Рекомендуется для изучения структуры системы тактирования на первоначальном уровне изучения .4
    Я сегодня на работе , дык что до 16.30 спрашивай ...
    RK86@Maximite
  5. #85
    Ярославль
    Если речь идёт об этом:
    Угу . Читай о системе тактирования в референс мануале + это http://ziblog.ru/2011/12/07/stm32l-n...iya-obzor.html
    RK86@Maximite
  6. #86
    Симферополь
    Досикус приветствую.
    Столкнулся тут с необходимостью запуска USB на STM32F20х чипе.
    В общем встал вопрос с адекватным запуском прерываний для CDC которые будут класть в FIFO из USB и отправлять из другого буфера в USB.
    Интересует именно блоковая передача а на побайтовый прием как в большинстве реализаций. Блоки до 4120 байт. Компилятор обычно юзаю EWARM но думаю что это не существенно особо.
    ZX Evo 4Mb- в строю.
    Speccy2010 v1
    Это все мое!
    Родное!
  7. #87
    Ярославль
    Приветствую!!!!
    Я USB рыл только на 103их , да и то только кейловские примеры перелопачивал.
    Спроси у Паши http://kazus.ru/forums/showpost.php?...&postcount=134
    Он что то подобное творит...
    Последний раз редактировалось dosikus; 01.05.2014 в 14:19.
    RK86@Maximite
  8. #88
    Ярославль
    В общим процесс потихоньку идёт... Но, очень медленно.
    Быстрей пойдет с железом на руках .
    Что из периферии имеется ?
    Дисплеи с SPI, USB<->USART, и т.д. ?
    RK86@Maximite
  9. #89
    Ярославль
    Хотя с английскими мануалами пока ничего не получается процент понимания 0,1%, а вот с тем, что на русском описано, пока всё понятно.
    Ну будем опираться именно на оригинал . Я буду описывать -как и что искать. Начнем с маленького а там привыкнешь...
    RK86@Maximite
  10. #90
    55 сообщений
    Ничего, но там же на плате дисплей есть, он же наверное к микроконтроллеру подключён, если да, то можно будет на нём эксперименты проводить?
    Лучше другой дисплей поищи, типа WH1602, или Нокиа-3310.
    На демоплате дисплей без контроллера аппаратного, рулится самой СТМ, в реальных проектах ты вряд ли будешь такой применять, он ножек чипа ест огромное количество.
    Далее, найди дата-шнурок от какого-нибудь древнего Сименса, типа С55, как адаптер USB<->UART. UART - вообще очень часто используется с МК, один из самых удобных интерфейсов. И первые уроки неспроста делаются именно с UART.
  1. Ответов: 17
    Последнее: 26.12.2015, 23:22
  2. Ответов: 19
    Последнее: 30.09.2011, 03:08
  3. Ответов: 0
    Последнее: 15.08.2010, 14:38
  4. Ответов: 18
    Последнее: 27.08.2008, 20:27
  5. Ответов: 6
    Последнее: 20.11.2007, 11:29
