Страница 378 из 458 ПерваяПервая ... 374375376377378379380381382 ... ПоследняяПоследняя
Показано с 3,771 по 3,780 из 4576
  1. #3771
    Carrollton, Texas, USA
    Hello again :-) I am looking for capacitor values for the monitor board and for the power supply board. I have tried looking for Passports, but have either not found them or the values listed do not match what I see on my own board. I can only see certain capacitors, but others are blocked from my view, and I would rather know what to order before I have to disassemble everything.
    Here is what I have so far:
    Monitor board:
    C56: 100V 22uF
    Below C56: 100V 50uF
    C34: 25V 100uF
    Next to C34: 25V 100uF
    C30, C39, others: 63V 470uF
    C1, C3, two below C3: 16V 1000uF
    Power supply board: (Elektronika MS 9002)
    C39, C15, (C45 or 49): 25V 5uF
    Possibly C49 & C50: 6.3V 50uF
    C4, and the group of 6: 16V 1000uF axial
    Group of 3: can't see the values, no exposed labels
    Sorry for no Russian, I don't have a lot of time to get this posted. Any documentation you could link me to would be appreciated!
  2. #3772
    Казахстан, Алматы
    http://tis.kz/large/IMG_0507_BP_KM1.jpg
    http://tis.kz/large/IMG_0507_BP_KM2.jpg
  3. #3773
    г. Павловский Посад
    557
    436 сообщений
    42 Post(s)
    Elektronika MS 9002
    http://emuverse.ru/wiki/%D0%94%D0%92%D0%9A
  4. #3774
    Thanks. It appears I missed those pages showing the full capacitor list. Last time I looked at this, I thought the last page had the only list. It seems to match what I have written down so far.
    ( Благодарю. Похоже, я пропустил эти страницы с полным списком конденсаторов. В прошлый раз, когда я посмотрел на это, я подумал, что на последней странице был единственный список. Кажется, это соответствует тому, что я записал до сих пор. )
    My monitor board looks like this:
    ( Моя монтажная плата монитора выглядит так: )
    https://photos.app.goo.gl/jA8sPauKCqi1pyCZ9
  5. #3775
    Bryansk
    140
    107 сообщений
    MS-6105
  6. #3776
    I have replaced the twelve biggest capacitors on the power supply board, as I thought they are most likely to cause major problems. Some showed signs of leakage when I removed them.
    ( Я заменил двенадцать крупнейших конденсаторов на плате питания, так как я думал, что они, скорее всего, вызовут серьезные проблемы. Некоторые обнаружили признаки утечки, когда я их удалил. )
    I have a question to those who have also done this: Have you ever considered replacing the smaller electrolytic capacitors with film capacitors or ceramic capacitors? And do you replace 50μF capacitors with 47μF capacitors? My wife (a capacitor expert) said 2μF capacitors are common film capacitor values, but yet this MS9002 board has it as an electrolytic capacitor. Values like 2μF and 5μF are hard to find as electrolytic capacitors. Also, she observed that ceramic capacitors are much more commonly used than electrolytic capacitors these days for stabilization as long as the capacitance is lower than around 50μF. She suggested replacing the 50μF capacitors with 63μF rather than 47μF because "values like that have to be for smoothing". She didn't even look at the schematic.
    ( У меня есть вопрос к тем, кто также это сделал: считали ли вы когда-нибудь заменой меньших электролитических конденсаторов пленочными конденсаторами или керамическими конденсаторами? И вы заменяете конденсаторы емкостью 50 мкФ на конденсаторы емкостью 47 мкФ? Моя жена (эксперт по конденсаторам) сказала, что конденсаторы емкостью 2 мкФ являются общими значениями пленочных конденсаторов, но эта плата MS9002 имеет в качестве электролитического конденсатора. Значения типа 2 мкФ и 5 мкФ трудно найти в качестве электролитических конденсаторов. Кроме того, она отметила, что керамические конденсаторы гораздо чаще используются, чем электролитические конденсаторы в эти дни для стабилизации, пока емкость меньше, чем около 50 мкФ. Она предложила заменить 50 мкФ конденсаторы на 63 мкФ, а не на 47 мкФ, потому что «такие значения должны быть для сглаживания». Она даже не взглянула на схему. )
    Also worth noting is that the original DEC schematics show very few electrolytic capacitors. She asked about this too, but I didn't think that was interesting until we had our conversation.
    ( Также стоит отметить, что оригинальные схемы DEC показывают небольшое количество электролитических конденсаторов. Она тоже об этом спрашивала, но я не думал, что это интересно, пока мы не поговорим. )
  7. #3777
    Питер
    63
    44 сообщений
    По опыту замены чаще высыхают конденсаторы маленького размера, нежели большого. Можно заменить 50 uF на 47 uF или на 63 uF.
    Рекомендую приобрести этот измеритель емкости без выпаивания: https://www.radiodevices.ru/esr/esr5.htm
    According to the experience of replacement, capacitors of small capacity (1..20 uF) rather than large ones (>20 uF) dry out more often. You can replace 50 uF by 47 uF or at 63 uF.
    I recommend that you purchase this capacity/ESR meter without removing from PCB: https://www.radiodevices.ru/esr/esr5.htm
  8. #3778
    Thanks for the response, Sergei! I have enjoyed browsing your site.
    ( Спасибо за ответ, Сергей! Мне понравилось просматривать ваш сайт. )
    Anyway, 63 uF capacitors were hard to find in-person here, so I went with 68uF. I replaced all the capacitors, then left the machine running Tetris all weekend at a convention. It worked fine. I got it put back together just in time for the newsman to come take some B-roll footage of it for a news story about the convention. You can see it at about 1:10 here: https://cw33.com/2018/07/29/lets-pla...s-to-all-ages/
    ( Во всяком случае, 63 мкФ конденсаторам было трудно найти здесь, поэтому я пошел с 68uF. Я заменил все конденсаторы, а затем оставил компьютер, работающий на Tetris на весь уик-энд на выставке. Он работал нормально. Я закончил перестраивать его как раз вовремя, чтобы журналист снял видеоролик, чтобы использовать его в новостях об экспозиции. Вы можете увидеть это примерно в 1:10 в видео в приведенной выше ссылке. )
    By the way, I was given approximately 200 square meters of space to exhibit personal computers of all ages, from among various local collectors, at the above event.
    ( Кстати, мне было предоставлено около 200 квадратных метров пространства для демонстрации персональных компьютеров всех возрастов, из разных местных коллекционеров, в вышеупомянутом мероприятии. )
  9. #3779
    255
    223 сообщений
    А как он измеряет, если несколько электролитов включены в параллель, среднюю по больнице?
  10. #3780
    Питер
    63
    44 сообщений
    По закону Бойля-Мариотта суммирует емкости
    Ответов: 23
    Последнее: 26.07.2005, 12:55
    Последнее: 21.07.2005, 11:49
  3. Ответов: 0
    Последнее: 25.06.2005, 23:14
