Показано с 1 по 10 из 10
Тема: TSE questions
    Czech Republic
    32
    8 сообщений
    По умолчанию TSE questions
    Дорогие друзья,
    о Sound Editor Turbo. В руководстве я могу читать: компилятора: нет, плеер: нет.
    Как я могу использовать мою музыку, что я создал в TSE, в моих программ?
    Кроме того, здесь автор TSE? Я бы некоторые вопросы по ним.
    спасибо
    Dear friends,
    about the Turbo Sound Editor. In the manual I can read: Compiler: none, Player: none.
    How can I use my music, that I created in TSE, in my programs?
    Also, is here the author of TSE? I would have some questions on him.
    Thanks
    Hood
    Russia, Ulianovsk
    33
    22 сообщений
    you can use vortex tracker 2 (on pc) which can compile turbotracks with player.
    speccy merchandise
    Czech Republic
    32
    8 сообщений
    So you mean after I finish my track in TSE, I save it on trd disk,then export it on pc and there I use Vortex Tracker only to add a player.then I can use it on speccy as part of any program,right?
    Russia, Ulianovsk
    33
    22 сообщений
    i'm not sure about vortex ability to load tracks written in tse, i ment, you may write track in vortex tracker and then export your track as compiled module in hobeta or scl-format.
    i just never use tse to write tracks only protracker 3.7 (on zx) or vortex tracker (on pc)
    speccy merchandise
    Czech Republic
    32
    8 сообщений
    I know Vortex Tracker is perfectly comfortable. But I prefer work on real ZX, than PC. And on the first sight, TSE looks better for me, as I have overview on all 6 channels in one time, while in PT I have to switch between chip 1 and 2.
    But yes, maybe PT offers slightly better functions and commands as it is a bit more modern then TSE.
    Anyway, lots of useful info to be found in Vortex Tracker manual.
    Thanks for your advice
    Hood
    Russia, Ulianovsk
    33
    22 сообщений
    not at all. don't mention it
    speccy merchandise
    Izhevsk
    65
    12 сообщений
    А ведь я почти сделал к нему компилятор
    Himik's ZxZ/PoS-WT
    Izhevsk. Russia. Planet 'Earth'. Sun system.
    The Pusher. Crack music system.
    Turbo-Sound at 1995 year.
    Саранск
    247
    106 сообщений
    Никогда не поздно довершить начатое
    Не уверен - не напрягай!
    Не сдавайся. Дыши?
    Virtual TR-DOS
    Izhevsk
    65
    12 сообщений
    ни чо се, смог запустить эмуль под вин8-64. исходники загрузил, музяка играет, тсе работает
    Himik's ZxZ/PoS-WT
    Russia, Ulianovsk
    33
    22 сообщений
    бОльшая часть работы уже сделана
    speccy merchandise
