А мне вот такую гадость сказал.
DriectX 9 и NET framework 2 установлены. Windows 2003 SP1.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: Не найден указанный модуль. (Exception from HRESULT: 0x8007007E)
   at ZXMAK.GUI.MainForm._videoDevice_DeviceReset(Object sender, EventArgs e)
   at Microsoft.DirectX.Direct3D.Device.raise_DeviceReset(Object i1, EventArgs i2)
   at Microsoft.DirectX.Direct3D.Device.Reset(PresentParameters[] presentationParameters)
   at ZXMAK.GUI.MainForm._videoDevice_DeviceResizing(Object sender, CancelEventArgs e)
   at ZXMAK.GUI.MainForm.InitDirectX(IntPtr hWnd)
   at ZXMAK.GUI.MainForm.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at ZXMAK.GUI.MainForm.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.42 (RTM.050727-4200)
    CodeBase: file:///E:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ZXMAK.NET
    Assembly Version: 1.0.6.8
    Win32 Version: 1.0.6.8
    CodeBase: file:///E:/ZX/ZXMN/ZXMAK.NET.exe
    CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Assembly Version: 1.0.2902.0
    Win32 Version: 9.05.132.0000
    CodeBase: file:///E:/WINDOWS/assembly/GAC/Microsoft.DirectX.Direct3D/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.Direct3D.dll
Microsoft.DirectX
    Win32 Version: 5.04.00.2904
    CodeBase: file:///E:/WINDOWS/assembly/GAC/Microsoft.DirectX/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
