Показано с 1 по 10 из 75
Тема: RUSSIAN SOFTWARE and real ZX
    Praha
    34
    15 сообщений
    По умолчанию RUSSIAN SOFTWARE and real ZX
    Russian ZX games is writed on russian ZX clones and support hardware feature TURBO OFF ( for ZX clone ZS SCORPION ). Russian ZX clone ZS SCORPION use software switching of TURBO cpu mode 3.5MHz and 7.0 MHz:
    Read port #7FFD = CPU turbo 7MHz (turbo on)
    Read port #1FFD = CPU run at 3.5MHz (turbo off)
    Write only ports #7FFD and #1FFD is used on ZS SCORPION for memory paging and reading this ports is used for CPU TURBO mode switching.
    On ZX Spectrum +2A and +3 is port #7FFD and #1FFD(with different functions) used too for memory paging. Read of this ports is not supported and CPU read data from floating bus ( value #FF ). Software TURBO switching routines for ZS SCORPION is on ZX+2A/+3 models ignored (without effect) and software run always at original ZX speed (3.5 MHz)
    Problem with this russian software is on original ZX Spectrum 128 / +2 (grey) models. This computers contain hardware bug - after read port #7FFD will ZX crash (data from floating bus is writed to paging port).
    Read port #7FFD = on ZX128/+2 write to paging port data from floating bus (can't be use)
    Read port #1FFD = on ZX128/+2 write to paging port data from floating bus (can't be use)
    ZX128/+2 use paging port #7FFD only. Hardware use incomplette port adressation (accept only A15=0 + A1=0 and port adress #1FFD is same as port #7FFD). If any russian software use read of port #7FFD of #1FFD, then real ZX128/+2 will crash. For fixed this problem you must remove instruction IN ?,(C) if BC=#1FFD or #7FFD.
    This is critical routines ("?" = any register A,B,C,D,E,H,L):
    LD BC,#1FFD
    IN ?,(C)
    LD BC,#7FFD
    IN ?,(C)
    LD A,#1F
    IN A,(#FD)
    LD A,#7F
    IN A,(#FD)
    If you remove this IN instructions from russian games/demos/utilities then will possible use this software also on ZX128/+2 and all other ZX models (+2A/+3 and russian ZX clones)
    This is my fixed TAP version of Dizzy 'B' Treasure Island game with removed instruction IN A,(C). Version for all ZX128 models(ZX128/+2/+2A/+3/russian clones):
    http://velesoft.speccy.cz/other/dizzy-b_fixed.zip
    This is original release(crash on ZX128/+2):
    http://www.worldofspectrum.org/infos...cgi?id=0015211
    And this is my fixed TAP ( ! ! ! ) version of WALKER game:
    http://velesoft.speccy.cz/kmouse/kmg...emo-km.tap.zip
    http://www.worldofspectrum.org/infos...cgi?id=0013118
    Последний раз редактировалось VELESOFT; 12.08.2009 в 11:00.
    Приютово
    Народ, о чем примерно идет речь? А то я ни-бум-бум в заморском...
    Savage
    Cracked by Bill Gillbert 1989
    Одесса
    75
    31 сообщений
    Won't I be impudent if I would translate this shortly?
    Я наберусь наглости и кратко переведу.
    Отечественные ZX игры пишутся на клонах и поддерживают аппаратное(?) TURBO выкл. Русский клон ZS SCORPION использует программное переключение TURBO cpu режима - 3.5МГц / 7.0 МГц:
    Чтение порта #7FFD = CPU турбо 7MHz (turbo on)
    Чтение порта #1FFD = CPU работает на 3.5MHz (turbo off)
    Т.е. запись для управления страницами, а чтение для переключения скорости.
    На ZX Spectrum +2A / +3 порты #7FFD и #1FFD тоже используются для управления страницами. Чтение не поддерживается, а CPU читает данные с висящей шины ( значение #FF ). Программное переключение игнорируется (без последствий), программа всегда работает на обычной ZX скорости (3.5 MHz).
    Проблема с отечественными программами - на оригинальных ZX Spectrum 128 / +2 (серый) моделях. В этих компьютерах прячется аппаратный баг - после чтения порта #7FFD программа теряет работоспособность (данные с висящей шины ЗАПИСЫВАЮТСЯ в порт страниц).
    Чтение и #7FFD, и #1FFD дает этот результат из-за неполной адресации порта (достаточно того, что A15=0 + A1=0), адреса этих портов одинаковы. Если отечественная программа читает #7FFD или #1FFD, то настоящие ZX128/+2 упадут. Для исправления проблемы следует убирать IN ?,(C) если BC=#1FFD или #7FFD.
    Это критические куски ("?" = любой рег. общего назначения):
    LD BC,#1FFD
    IN ?,(C)
    LD BC,#7FFD
    IN ?,(C)
    LD A,#1F
    IN A,(#FD)
    LD A,#7F
    IN A,(#FD)
    Если убирать эти INы из русских игр/дем/утилит/ их можно будет использовать на ZX128/+2. И на всех других оригинальных моделях (+2A/+3 и русских клонах(?) )
    (дальше ссылки на фиксы)
    Последний раз редактировалось TomCaT; 19.10.2008 в 16:25.
    http://www.sky.od.ua/~ptsk
    Praha
    34
    15 сообщений
    По умолчанию problem with FAST and SLOW(contended) memory
    Russian games/demos designed for ZX clones run on original ZX128 models with different speed and can crash.
    More ZX clones use fast access to contended(with ULA/videoram) memory. Original ZX Spectrum models use slow access to contended memory(ULA slow-down CPU).
    adress space on original ZX128/+2(grey model):
    #0000-#3FFF = zx rom (fast memory)
    #4000-#7FFF = videoram 1 (slow memory contended with ula)
    #8000-#BFFF = fast memory
    #C000-#FFFF = memory paging area (pages 0,2,4,6 = fast / pages 1,3,5,7 = slow)
    128kB memory = 64kB fast mem. + 64kB slow mem.
    adress space on original ZX128+2A/+3:
    #C000-#FFFF = memory paging area (pages 0,1,2,3 = fast / pages 4,5,6,7 = slow)
    RESULT:
    Different ZX128 models/clones use different layout of slow and fast memory pages !!! For example - Animation effect run in VERA game(in menu) incorrect on real ZX128/+2 (incorrect animations and problem with cursor).
    Animation code work with slow memory pages. More russian demos use too slow(on real ZX) pages and crash. Any russian software work only on ZX128/+2 and other only on ZX128+2A/+3 because this models use different numbers of slow memory pages. Russian ZX clones use all memory pages fast and software work always correct at full speed. If coders will accept also memory layout for orig.ZX models, russian software can work too on this computers. Disk loader can detect type of used ZX model and load critical timing routines only to fast memory pages and other data to slow memory.
    RESULT:
    More russian games/demos can run on different ZX models only if you rewrite numbers of memory pages on instructions OUT (?),A (OUT #7FFD,xx). This is easy way for best compatibility.
    VELESOFT
    Estonia,Tallinn
    258
    196 сообщений
    It is a great information for us and thank you very much for your research.. but I think that it would be preferably to make a separated document about those differences and to collect all information into the document (which you can place in the network) else all information will be just lost..
    Добавлено через 37 секунд
    Цитата Сообщение от rasmer Посмотреть сообщение
    Давно бы уже пора понять, что как делали под совковые клоны, так и будут делать...
    врядли он поймет что у нас воистину суверенный ZX-Spectrum
    Последний раз редактировалось Raydac; 20.10.2008 в 00:36. Причина: Добавлено сообщение
    Praha
    34
    15 сообщений
    And bad value of I register(adress of IM2 table) causes on original ZX 128/+2 models raining(snow) effect in screen:
    If russian software/demos will use I register in range #0-#3F or #80-#BF then software will run correct (without screen raining) on real ZX models.
    VELESOFT
    Украина, Львов
    2VELESOFT
    Классные анимации... Полагаю, закапчурено с эмулятора... Вы не можете сказать, что нужно чтоб получить поведение "реального" спектрума?.. Брал RealSpectrum beta release 14 v0.97.36 (win) by Ramsoft, выбирал +2, +3 эмуляцию, загружал "кривые" снапшоты ( с вектором прерываний во пятой странице ), но работало вроде как нормально...
    Саранск
    Мои игры: [Overload][Removal]
    Саранск
    Да пойми ты наконец (а я прекрасно знаю, что русский ты понимаешь), что нам АБСОЛЮТНО ПАРАЛЛЕЛЬНО что у вас на "ваших спектрумах" что-то идёт нетак...
    г. Минск, Беларусь
    Кому это вам? Нам, например - не параллельно
  1. Russian Bear Group
    от Serdjuk в разделе Люди
    Ответов: 54
    Последнее: 06.04.2010, 12:35
  2. NEW SOFTWARE FOR KEMPSTON MOUSE
    от VELESOFT в разделе Игры
    Последнее: 12.10.2008, 01:17
  3. X-TRACKER by CBM Software 1994
    от newart в разделе Музыка
    Последнее: 04.10.2008, 20:48
  4. Looking for Russian Games
    от CityAceE в разделе RST#38
    Последнее: 19.02.2008, 16:24
  5. SINCLAIR ZX SPECTRUM 48k RUSSIAN model MASTER NIB!
    от dhau в разделе Барахолка (архив)
    Последнее: 24.01.2006, 19:36
