Страница 20 из 23 ПерваяПервая ... 1617181920212223 ПоследняяПоследняя
Показано с 191 по 200 из 222
Тема: Атари ассемблер
  1. #191
    г. Арзамас
    180
    126 сообщений
    разные авторы, разные цели.
    в xasm ins удобен с опцией пропуска N байт.
  2. #192
    Ярославль
    MADS
    INS 'filename'["filename"][*][+-value][,+-ofset[,length]]
    The INS pseudo-command allows inclusion of an external binary file. The included file does not have to be in the same directory as the main file being assembled. Search paths for the file can be configurated using the /i switch (see assembly switches).
    Additionally, you can perform the following operations on the binary data:
    * invert bytes
    +-VALUE increase or decrease each byte by the value of the expression VALUE
    +OFSET skip OFSET bytes at the beginning of the file (seek to OFSET)
    -OFSET read OFSET bytes at the end of the file (seek to FileLength-OFSET)
    LENGTH read LENGTH bytes from the file
    If the LENGTH value is not specified, the default behavior is to read to the end.
    XASM
    INS - insert contents of file
    Copies every byte of the specified file into the object file and updates the origin counter, as if these bytes were written using DTA. You may specify a range of the file to insert. The syntax is:
    ins 'file'[,offset[,length]]
    The first byte in a file has the offset of zero. If the offset is negative, it counts from the end of the file. Examples:
    ins 'picture.raw'
    ins 'file',-256 insert last 256 bytes of file
    ins 'file',10,10 insert bytes 10..19 of file
    А так же у MADS
    ICL 'filename'["filename"]
    The pseudo-command ICL includes an additional source file in the assembly process. The attached file does not have to be in the same directory as the main assembly file. Additional paths are added to the MADS search path using the /i switch (see assembly switches).
    Profi 1024+CF+CPM+VGA
    ATARI 800XL+SIO2PC+SIO2SD
    RK86@Maximite
  3. #193
    Ярославль
    Шынни, можешь хоть немного о работе с P/M здесь вывалить ?
  4. #194
    г. Арзамас
    180
    126 сообщений
    если я правильно понял, то вопрос о PMG.
    мой топик на хайпъ, там же пример.
  5. #195
    Ярославль
    Угу, спасибо.
    RK86@Maximite
  6. #196
    Ярославль
    Шынни, не против если завалю здесь вопросами?
    Кстати , от чего такие реинкарнации твоих сущностей?
    RK86@Maximite
  7. #196
  8. #197
    г. Арзамас
    180
    126 сообщений
    не распарсил вопроса.
  9. #198
    Ярославль
    Шынни,
    Расположение определяется значением из PMBASE($D407), умноженным на 256
    Писано так, будто сей регистр можно читать , в то время как он WO .
    Для каждого объекта пиксель может состоять из точки шириной в 2 точки и высотой в одну, или 2х2 пикселя.
    Вообще ничего не понял. Тупею видно. Можно графически изобразить?
    RK86@Maximite
  10. #199
    г. Арзамас
    180
    126 сообщений
    верно, вечная болезнь при написании опусов. Значение, записанное в PMBASE, умноженное на 256 и есть адрес.
    в текстовом режиме (GR.0 басика) и в режиме GR.8 разрешение 320х200.
    для игрока один пиксель будет шириной 2пикселя, высотой в 1.
    Для двойного разрешения высота 2х2.
    на рисунке зеленый и красный.
  11. #200
    Ярославль
    Благодарствую.
    Твой сырец компильнулся и запустился в WUDSN с MADS без проблем.
    Изучаю твой сырец попутно читая мапинг и дере-атари и PMG для Барсика.
    Последний раз редактировалось dosikus; 12.12.2017 в 18:19.
    RK86@Maximite
  1. ПК8000 - Ассемблер
    от scaraby в разделе ПК8000
    Последнее: 16.12.2018, 11:00
  2. Ассемблер для 48к на ленте
    от newart в разделе Программирование
    Ответов: 37
    Последнее: 20.09.2015, 22:48
  3. Переведите на ассемблер
    от Руслан в разделе Программирование
    Последнее: 06.08.2012, 23:41
  4. Ассемблер Z-80
    от sergey2b в разделе Пресса
    Последнее: 11.07.2011, 23:41
