Нашел информацию что 1.4 была специальной версией для более современных машин, принудительно выставлен режим VGA.
"...1.4 is a version that was changed to be more compatible with modern CPUs and operating systems. it was coded especially for the POP collection pack. POP2 was also revised in a similar manner. they forced VGA in the case of 1.4 POP1 because ALL modern cpus and dos boxes have vga support"
Prince of Persia v1.0 : 1990
Original PC version; Has original color scheme (Level 3 dungeon is dark blue)
No Setup program; uses manual command line parameters:
j (joystick); vga, mcga, tga, ega, hga, herc, cga (graphics);
stdsnd, adlib, covox, gblast, ibmg, sblast, tandy (sound)
Cheat activation code is 'megahit'
Prince of Persia v1.3 : 1992
Same levels, but with new color scheme on some levels (Level 3 dungeon is dark green)
Complete Hardware configuration startup Setup program.
You can specify Graphics Mode, Input Device, Sound Device and Music Synthesizer.
Cheat activation code is 'improved'
Prince of Persia v1.4 : 1993 (from Prince of Persia CD Collection)
Levels and color scheme identical to v1.3 (Level 3 dungeon is dark green)
Limited choice for Hardware configuration startup Setup program.
You can only set Sound Device and Music Synthesizer (PC Speaker, Sound Blaster Pro, Other Drivers).
