yes, the total buffer for lua text script to be executed is about 32kiB. I was refactoring this just for v1.15.1 to make it constant in the source, so if you are building sjasmplus from source, you should easily find the new constant and raise it (and disable the allpass warning), but I think you use only the binaries.
I'm not sure if, and by how much I should raise the script length limit, as I have little idea what limits are on the lua side (on sjasmplus side it's all about heap memory, so I can probably allocate also 10 or 100MB without issue on modern PC). Also the buffer is fixed size, allocating for every script in full length, but maybe I can check C++ `std::string` performance characteristics to see if it does deal with `append` effectively, not putting any fixed limit on the usage at all, leaving that to dynamic string allocator. Or maybe I can just use `std::vector` for this too.
There's lot of sjasmplus source which is not using basic C++ idioms and doing things manually like in C, but I never had time to rewrite some parts just to make them more C++, as I always have to hunt some bug or add feature, and also it took time to have enough test coverage to make such source rewrite reasonably safe (without test coverage the risk of breaking old stuff is too high). So maybe one day...... in sjasmplus v2.x
Ответить с цитированием
