Показано с 1 по 10 из 11
Тема: ZEsarUX stable 7.2
    Member
    Madrid, Spain
    По умолчанию ZEsarUX stable 7.2
    Hi!
    I have uploaded a new stable ZEsarUX version 7.2!
    You must go to the Releases section on the GitHub project to download It, as usual:
    https://github.com/chernandezba/zesarux/releases
    There are binary compiled versions for:
    -Linux
    -Mac
    -Windows
    -Raspberry Pi
    And, of course, the source code, so people can compile it by themselves:
    Don’t forget the extras package, so it contains lots of games, demos, programs and documentation.
    The Changelog is:
    Version 7.2. 10 April 2019 - Neula edition
    Improved menu environment:
    -Added new menu window type: ZX Vision. GUI Windows can be moved, resized, scrolled, minimized, closed, and change the focus to the background
    -Windows can be scrolled using mouse wheel
    -Warning and Error window messages now show an animation
    -Added first-aid help windows
    Added Z80 assembler
    Added setting to specify configuration file
    Added key to save text windows contents to a file
    Added setting to send a final space after every word in the osd adventure keyboard
    Added Dandanator CPC emulation
    Added machine Amstrad CPC 4128
    Added CPC machines support to ZSF snapshots
    Added tape to wav converter (tap, tzx, o, p to wav)
    Added text driver (curses, stdout, simpletext) for Chloe 80x24 mode
    Improved Debugger:
    -Now you can disassemble on the Step-to-step mode from the Debug cpu menu
    -Now you can assemble from the Debug cpu menu
    -Added Chloe memory Zone
    Improved ZRCP:
    -commands smartload and snapshot-load are more intelligent now
    -running in verbose or limit mode, or cpu-step command, can now update the display inmediately (having real video setting on)
    -added commands: assemble, get-cpu-frequency, get-cpu-turbo-speed, get-tstates, get-tstates-partial, load-binary, reset-tstates-partial
    Improved sprite viewer:
    -you can view sprites up to 512x512
    -you can export sprites to C source code file
    Improved file selector:
    -now it remembers the last files used
    -Windows: now you can use up to 20000 files in the same directory
    -added drive selector (press shift-d). On Windows, allows you to change drive unit. On Linux and Mac, changes to /media or /Volumes folder
    Improved disassemble window:
    -now you can export the disassemble to text file
    -you can now see the full opcode when debugging Sinclair QL
    -you can now show/hide hexadecimal dump of every opcode
    Improved hexadecimal editor:
    -now showing subzones information
    Improved audio: silence detector is disabled by default. That should fix some Windows audio problems. Check Settings->Audio->Silence detector if you have configuration autosaving enabled
    Improved vu-meters: high volumes are shown in red
    Improved MMC emulation: allow non-standard mmc file sizes
    Improved compiled Mac version: default version is faster than before (uses O2 optimization)
    Fixed visual glitches in some menus when Pentagon machine and real video, or when enabling interlaced: audio wave, visualmem, ay piano, wave piano, view sprites
    Fixed triggering "opcode" condition breakpoint
    Fixed emulating Inves interrupt bug
    Fixed segmentation fault when showing electron on debug
    Changes in TBBlue emulation:
    -Added Tiles video mode
    -Added "reveal" setting to view which pixels are used by a layer
    -Added setting to change machine id
    -Improved CPU usage:
    --Use 4% less cpu time (in my machine) when only ULA and/or Tiles enabled
    --Use 1% less cpu time (in my machine) when all layers enabled
    -Improved display emulation: now is twice bigger
    -Fixed Timex hi-res mode 512x192
    -Fixed autoload on tbblue (on normal and also fast boot mode)
    -Fixed error managing Layer 2 vertical scroll
    -Fixed audio bug: sending a sample to the DAC by using Next registers, it wasn't reseting the silence detection counter, so sound would probably be frozen (and repeated again, and again...)
    Some other minor bugfixes and improvements
    Enjoy!
    Cheers,
    Cesar
    Master Аватар для zebest
    Ладошкино
    10 сообщений
    Dear friend !
    Если уж декларируешь поддержку Pentagon-a, то доводи до ума, для начала тайминги
    во-вторых - Pentagon в других, хороших!, эмуляторах тоже умеет SNA загружать, а твой умный smart загрузчик автоматом загружает их в режиме Spectrum128
    в-третьих - давно пора сделать загрузку файлов "drag & drop" - это повысит юзабилити.
    и в-пятых - sorry for my french language!
    Последний раз редактировалось zebest; 11.04.2019 в 10:46.
    Profi v3.2 -=- Speccy2010,r2
    Member
    Madrid, Spain
    Hi
    -Pentagon emulation is experimental, but I’m trying to do my best I will try that demo
    -sna specification is for formats Spectrum 48 and 128, there are no “Pentagon” sna files, as far as I know. But you can change a ZEsarUX setting to tell the emulator not to change the current machine and you could load sna in Pentagon
    -drag and drop only works by default in Mac. You can enable it on other machines if you compile from sources and have the SDL2 libraries
    -french? Who is speaking french? XD. My text was written in English. And I can also speak Catalan and Spanish. And I just understand a little little bit of Russian and Cyrillic writing
    Veteran Аватар для sergio78
    Самара
    Цитата Сообщение от "chernandezba;
    1007597-french? Who is speaking french? XD."
    we in Russia is humor. don't be perplexed over it.
    Activist
    2zebest: А что это за дема, с загрузочным экраном от Профи?
    Последний раз редактировалось Doronetty; 16.04.2019 в 21:30.
    Как говаривал старик Палсекамыч (которого некоторые историки ошибочно называют Пепсиколычем или даже, прости Господи, Бублегумычем): "Не клади все яйца в одну... мошонку!"
    Guru Аватар для Shiny
    г. Арзамас
    13
    Just tested some demos. Please check twister
    When you fix F10 and F12 keys?
    And chess too.
    broken linear interrupts
    Member
    Madrid, Spain
    And chess too.
    I know about chess issue, thanks. Not all games work perfect
    About f10 and 12 I suppose those are used for reset etc. You can fire them from menu and also assign them to your own f function keys
    Member
    Madrid, Spain
    Look what I have just added
    https://youtu.be/iWiM3JHfNYM
    г. Арзамас
    13
    funny, it is stable xD
    Ладошкино
    10 сообщений
    Павлины, говоришь?? Х-хех... (с)
    Два года - и все "эксперименальная" версия, удобно, чО.
    Ладно, какая не экспериментальная ??
    ZX48 ?
    за те же два года твой эмулятор так и не научился запускать простейший тест Timing_Tests-48k_v1.0.tap
    а если и извратиЦЦа, при боооольшом желании, то ошибок не одна и не две.
    Учись, студент! (с)
  1. ZEsarUX-7.0
    от chernandezba в разделе Эмуляторы
    Последнее: 26.10.2018, 19:27
  2. New version emulator ZEsarUX-7.1
    Последнее: 26.10.2018, 13:14
  3. ZEsarUX 6.1 BETA March 2018
    Ответов: 23
    Последнее: 16.03.2018, 14:50
