Страница 4 из 4 ПерваяПервая 1234
Показано с 31 по 40 из 40
Тема: wanted - ZS Scorpion 256/1024 Turbo PCB
  1. #31
    г. Сороки, Молдова
    129
    101 сообщений
    My PCB not assembled yet, so, I can't help you. Did you fit smd diode on the bottom side of PCB?
Название:	Diode smd 1N4148.jpg
  2. #31
  3. #32
    Berlin, Germany
    46
    31 сообщений
    Where is that one located on the 2019 board? In case it's the one that goes to the 22v10 GAL or the KS156, yup I did fit those.
    Pentagon 48 + MIKAY128 + VG93 Turbo + Stereo Covox + KJoy
    Москва 128 + AY
    Pentagon 1024SL 2.2 + ZXM-GS + Z-Controller + TSFM + Tape-In
    ZX Evolution Rev. C + ZX-MultiSound
    Compact 256 Turbo 1.1 (ZS Scorpion 256 INT, Port #FF, Port #FB) + Covox + ProfROM + NemoBus + NemoIDE + ZXM-GS
    ZS Scorpion 256 Turbo+ + GMX + SMUC + GS Classic 2MB
    Sprinter 2016S
    К сожалению, я не говорю по-русски / Sorry, I don't speak Russian
    https://github.com/zxshock
  4. #33
    г. Сороки, Молдова
    129
    101 сообщений
    I've got 2018 edition PCB. Did you get yours PCB from Pavel Raybcov? Do you have circuit diagram for that machine?
  5. #34
    Berlin, Germany
    46
    31 сообщений
    Yeah, I got the PCB from him.
    I'm currently working with the original Turbo+ schematics by black_cat (the one with the epm plds and prom).
    Москва 128 + AY
    Sprinter 2016S
  6. #35
    г. Сороки, Молдова
    129
    101 сообщений
    Anode of SMD diode connected to 24 pin of CPU (WAIT-), stil can't trace link for cathode, seems to be VD2 КД522 on diagram. Try to check yourself!
    Последний раз редактировалось andreysur; 28.10.2019 в 22:57.
  7. #36
    Berlin, Germany
    46
    31 сообщений
    That will be connected to one of the 22v10 GALs (the one programmed with turbo.jed)
    Москва 128 + AY
    Sprinter 2016S
  8. #37
    Berlin, Germany
    46
    31 сообщений
    Цитата Сообщение от andreysur Посмотреть сообщение
    How to fit V10 KT209 (BC547)[/url]
    Вложение 70259
    This is incorrect, it should be a BC557 (PNP just like KT209)
    Москва 128 + AY
    Sprinter 2016S
    Этот пользователь поблагодарил Shockwav3 за это полезное сообщение:
    Evgeny Muchkin(13.11.2019)
  9. #38
    г. Сороки, Молдова
    129
    101 сообщений
    Sorry, it's my mistake! Fixed it.
  10. #39
    Berlin, Germany
    46
    31 сообщений
    so ... what would be the best way to get a classic GS PCB (not NeoGS, not the one by Micklab)?
    Москва 128 + AY
    Sprinter 2016S
  11. #40
    362
    198 сообщений
  1. Scorpion ZS 256 Turbo+ (схема)
    от deathsoft в разделе Scorpion
    Ответов: 103
    Последнее: 23.09.2017, 19:48
  2. Запуск Scorpion ZS 1024 Turbo+
    от krt17 в разделе Scorpion
    Последнее: 03.08.2015, 14:20
  3. Обмен компьютера Scorpion ZS 256 на печатную плату Scorpion 1024!
    Последнее: 02.03.2012, 10:37
  4. Куплю Всё что связано со SCORPION 256 / 1024
    от kndbbs AKA KND в разделе Барахолка (архив)
    Ответов: 21
    Последнее: 23.02.2009, 10:21
